Old Jul 26, 2012, 09:14 AM
lagarto is offline
Find More Posts by lagarto
Joined Jun 2012
oh I used 1.5 mm balsa wood for the flat part of the win and 1 mm balsa wood for the curve part. I will try another way becauso the flat part took an unwanted curve and I beleave that is not right
lagarto is offline Find More Posts by lagarto
Old Aug 09, 2012, 09:05 AM
mattconn24 is offline
Find More Posts by mattconn24
mattconn24's Avatar
United States, TN, Murfreesboro
Joined Dec 2008
Anyone have any plans for these small dlg rc gliders? I would love to build one and I have an ar6400 just sitting around but I am not very good at free hand building. I need a plan to follow.
mattconn24 is offline Find More Posts by mattconn24
Old Aug 11, 2012, 03:39 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
Lagarto:
Nice plane and nice construction of the wing.
And i want plans too
A Question. Do You finish the wing with dope or something?
methuso is offline Find More Posts by methuso
Old Aug 17, 2012, 04:31 PM
Roy!! is offline
Find More Posts by Roy!!
Roy!!'s Avatar
Ocala,Fla
Joined Jan 2009
ok im doing a 950mm with a flying stab so at least i won't have to worry about incidence like my last one where no matter how hard i threw it did a loop into the ground
Roy!! is offline Find More Posts by Roy!!
Old Aug 30, 2012, 05:16 PM
Roy!! is offline
Roy!!'s Avatar
Ocala,Fla
Joined Jan 2009
ok just need some extensions and i can be flying
Old Aug 30, 2012, 07:06 PM
autoking is offline
Find More Posts by autoking
autoking's Avatar
United States, FL, Ocala
Joined Aug 2012
man that look's cool
autoking is offline Find More Posts by autoking
Old Sep 26, 2012, 02:06 AM
insertcoin1978 is offline
Find More Posts by insertcoin1978
Joined Sep 2012
Originally Posted by Charos View Post
I have been watching this thread with great interest Micro_Builder.
Like yourself I am also interested in Micro-HLG's and thought I would share
a few pics of a 20" projected span design im currently building.
I have modified a Free Flight HLG called "Bliss" with a new Y-Tail and altered fuselage.
Looks like my AUW will be 35g. I guess that translates to approx 8g/DM^2.
Which is a just a tad heavier than yours.
Im using a Vapor DSM2 Brick and a Bahoma 90mah Lipo.
All RC gear will be fully enclosed bar the Lipo which is flush with the side of the fuselage for easy replacement.
Here is a couple of pics.
Hi!
I'm a new user of the forum and I'm very interested in this kind of mini DLG.
Could You pleas post the project of the BLISS?
Thank You so much!
insertcoin1978 is offline Find More Posts by insertcoin1978
Old Oct 20, 2012, 10:25 PM
micro mini man is offline
Find More Posts by micro mini man
micro mini man's Avatar
Joined Feb 2012
i have been building these micro planes for a long time never thought to take picts of the build. i dont make these hlg planes im a sloap soar man fly mostly at long beach. so its time for me to start a new plane now that the weather is in favor. ill drop some picts and videos.
micro mini man is offline Find More Posts by micro mini man
Old Oct 24, 2012, 01:28 PM
mattconn24's Avatar
Joined Dec 2008
Awesome man can't wait to see your plane.
Old Oct 24, 2012, 02:04 PM
littlephoenix is offline
Find More Posts by littlephoenix
littlephoenix's Avatar
Joined Aug 2007
hey Lagarto, very nice build, i saw your video and she flies great, it does seem a little heavy though...i have calculated for a 21inch wing span DLG, best weight is to keep it under .8oz, so i assume the balsa wings are a bit to heavy.
this is a .8oz 21inch wingspan same size as yours, its glide is softer, but its wings are blue core
Micro DLG Glider AR6400 21inch wing span (4 min 32 sec)
i think for a 30" DLG, balsa wings would be optimal.
cheers
littlephoenix is offline Find More Posts by littlephoenix
Old Oct 25, 2012, 04:47 PM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
What's the best way to go about adding small amounts of carbon tow for wing reinforcement?
Cheesehead is offline Find More Posts by Cheesehead
Old Oct 25, 2012, 05:11 PM
Joined Aug 2007
i use Z-poxy and just go around the wing zigzag, seems to hold just fine, here is a picture below. if you take your time, you can actually burry the carbon tow so it doesnt extrude out, unless you apply a thin coat of tow so it sits flush with the wing surface.
Old Oct 26, 2012, 01:22 AM
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
What's the advantage of wrapping it in crosses as opposed to a strip down the length of the wing? Torsional rigidity?
Old Oct 26, 2012, 01:48 AM
Joined Aug 2007
i believe most pro DLG gliders will have both strip carbon and crisscross tow all over the wing, of course along with vacuuming and glassing etc.
if your dlg is a smaller size and not vacuumed, you can get away with just using tow, you can zigzag a bit more than i did in the pic for more rigidity, if your plane is micro sized, no carbon is needed.
here is a quick video of 30" dlg above
30" Mini HLG DLG Glider radio control RC plane (1 min 31 sec)
Old Oct 26, 2012, 12:59 PM
mattconn24's Avatar
Joined Dec 2008
Description: so at work they were having to use a lot of super glue for something so I took like 20 of the plastic part of the packaging. Anyone else thinking easy canopy pod for gliders!!!
Micro Hlg ???????? AIR MOVER Hand Launch 14 Aug 04, 2009 09:28 PM
bug micro hlg f/s ERGO60SX Aircraft - Electric - Airplanes (FS/W) 8 Nov 27, 2002 09:01 PM
Micro HLG Conversion Q's RB Scratchbuilt Indoor and Micro Models 1 Nov 10, 2002 09:44 PM
Anyone Fly the DAW Dragonette Micro HLG??? webguyjv Electric Sailplanes 9 Feb 20, 2002 12:44 AM
Albatoss micro HLG? cheapflyr Electric Sailplanes 6 May 26, 2001 11:52 AM
