Old Jul 20, 2008, 10:58 AM
attack_pilot is offline
Find More Posts by attack_pilot
Joined Jun 2007
Question
Spektrum DX7 Radio setup for TRex 450 SA
I have a Trex 450SA, with Align BL 430L motor, Align BL35G ESC, and Align 2100 mAh LiPo battery. The heli also has an Align RCE-500X gyro, 4 HiTec HS-65HB servos, and a Spektrum AR6100 receiver. What I am looking for is detailed programming/setup instructions for this equipment on the DX7 transmitter. Swashplate, gyro sens, servo reverse, throttle hold, throttle and pitch curve settings for normal, ST-1 and ST-2, and travel adjustments for aileron, elevator, rudder, and throttle. In short, everything I'd program for sport or 'normal' flying with this helicopter using the DX7. I originally contacted Horizon Hobby for assistance since they sell all of these components, but received no response. I believe that if this helicopter is assembled per instructions and the radio is programmed to 'beginner' or normal ranges, I should succeed in learning to fly it. Please, no references to online videos as I do not have access to high speed Internet where I live. I do have several of the Helifreak "Finless Bob" videos, but those are no specific to this helicopter/radio combination.
attack_pilot is offline Find More Posts by attack_pilot
Old Jul 20, 2008, 11:17 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
DX7 SETUP FOR BELT HELI Updated Dec. 31, 2008
* Before setting up, bind your receiver to the transmitter. This is done by plugging the bind plug into the BATT socket in the receiver. Then plug the battery to the esc and/or bec. Then press the transmitter bind button at the back as you turn on the transmitter. Wait for the flashing receiver lights stabilize. When it has bound, the esc will arm. You can release the bind button. Turn off the transmitter and unplug the heli’s battery. Remove the bind plug from the receiver.
I. System Setup Mode
1. Enter the System Setup Menu by pressing Scroll Down and Select keys while turning on the transmitter.
2. Press UP or Down keys to navigate.
3. Go to [TYPE SELECT] and choose HELI for your model.
4. Go to [MODEL SELECT] and assign a model number for your heli. Use the Increase or Decrease keys to toggle between choices.
5. Go to [MODEL NAME] to assign a custom name. Use Increase or Decrease to select letter. Press Select key to move to next letter.
6. Then press the Down key to go to [SWASH TYPE] menu. Use Increase or Decrease key to toggle to 3 SERVOS 120º.
7. Next go to [INPUT SELECT] menu by toggling UP or Down keys. It should be
AUX2>AUX2 and GEAR>GEAR.
II. Function Mode
1. Enter the Function Mode menus by pressing Down and Select keys after turning on the transmitter.
2. Use the UP or Down keys to toggle between menus.
3. Go to [REVERSING SW] menu to set your servo reversing switches.
Ch1 : Throttle (esc)
CH2: Aileron (left cyclic servo)
CH3: Elevator (front or rear single cyclic servo)
CH4: Rudder (gyro)
CH5: Gear (gyro remote gain cable)
CH6: Aux1 (right cyclic servo)
*Note that this is for individual servo reversing. For collective cyclic reversing, go to [SWASH MIX] menu.
4. Go to [SWASH MIX] Menu. Use Select button to toggle between functions.
5. Initially set AILE, ELEV at 50%. – or + values changes the servo directions. Increase or decrease the value so that when you apply max aileron or elevator, you get a maximum pitch interaction (pitch movement from current blade position) of 6 deg. Set PIT value so that you get maximum (10-11 deg) + and - pitch without bottoming mechanically or have the servos buzzing. Again – or + values reverses the collective direction.
6. Leave EXP in INH.
7. Go to [TRAVEL ADJUST]. Use Select key to toggle between functions.
8. For THRO, set High (H) value just high enough so you get a max motor output (ESC led flashes) at max stick input. At times, this can be less than 100%. Set Low (L) value just low enough that the esc arms. At times, this is less than 100%. This provides best throttle resolution.
9. AILE, ELEV, and PIT. adjusts the cyclic servo maximum throw. Initially adjust all three pairs of H and L in identical values. Values for AILE, ELEV, and PIT. must also be identical. This puts you into the ballpark for max -/+ pitch. Make sure swash is level at max negative and max positive pitch. If not, adjust the offending channel. If your max pitch is not correct, adjust all 3 until it is. Recheck swash leveling. Do the same for max negative pitch. Recheck these settings after centering the servo arms at mid stick using the [SUB TRIM] menu.
10. Adjusting the RUDD endpoints, controls the piro rate not the servo throw. Remember that the servo receives a command signal rather than a proportional
signal. Adjust L and R piro rates so that you get the same piro rate turning left or right. IT is normal to exceed 100% for both values.
11. GEAR is used to adjust gyro gain. + value is hh mode. – value is rate mode. Set these initally at +72% and -28%. Readjust after a test hover.
12. AUX2 is unused for now. The channel is unavailable in the AR6100. The switch, however can be assigned to a function like throttle hold. This frees up the use of the Rudder D/R switch for other functions like dual piro rates.
13. Go to [SUB TRIM] menu.
14. Adjust AILE subtrim to center the left cyclic servo in mid throttle stick.
15. Adjust ELEV subtrim to center the front or rear single cyclic servo at mid stick.
16. Adjust PIT. Subtrim to center the right cyclic servo.
17. Adjust the RUDD subtrim if servo arm drifts in hh mode during tests.
18. Leave [AUTO D/R EXP] in default settings for now.
19. Go to [D/R & EXP] menu. Use Select keys to toggle between functions. Use Increase or decrease to change channel and change values.
20. Expos if used changes command sensitivity. + values makes command less sensitive. Lower value down to a negative value increases sensitivity. More sensitivity makes the heli twitchy. Full stick, however always yields the maximum programmed servo throw.
21. AILE and ELEV expos affect the cyclic. RUDD affects the piro or turn rate.
22. D/R adjusts the maximum servo arm travel of the affected functions. Reducing AILE and ELEV rates for example reduces the maximum swash plate angles. These can be toggled in flight using the marked D/R switches. Leave these at 100% for now for both on and off switch positions of the various D/R switches.
23. Note that you have two switch positions for both expo and dual rates. Toggle the
actual physical switches when setting values for each switch position. It will be indicated in POS-1 or POS-0.
24.Go to [PITCH CURVE] HOLD. Use Select key to move between throttle positions. Use Increase or Decrease keys to change values. This menu sets the main blade pitch range when the Throttle hold switch is turned on. This gives you maximum positive and negative pitch. This is useful for setting blade pitch using a pitch gauge. Mid stick is zero degrees.
25. Note that 0 to 50% gives you negative pitch. 50% to 100% gives you positive pitch. 0% is maximum negative pitch. For most helis this is -10 deg.
26. In HOLD position, set pitch range as 0-INH-50%-INH-100%.
27. Go to [PITCH CURVE] ST-2. This is for 3D. Set this for maximum head speed and fast collective response for flipping, tic tocs, etc. The S-curve is ideal for this.
28. Set ST-2 at 0-15%-50%-85%-100%. This is an S-curve. Pitch rapidly changes around the mid stick for fast vertical transitions.
29. Go to [PITCH CURVE] ST-1. Let’s keep this linear. Set it at 0-INH-50%-INH-100%. This give a smooth and predictable collective response. This is good for sport flying and mild aerobatics.
30. Go to [PITCH CURVE] NORM. Let’s dial out negative pitch or at least most of it for proper spool up. You can put a few degrees of negative pitch if desired. I prefer zero on spool up. Set this at 50%-50%-50%-INH-100%. This gives zero degrees pitch up until mid stick. Then pitch increase above it.
31. Go to [THRO CURVE] ST-2. You can keep this flat for max head speed. Or use a conservative v-curve for moderate speed. I use 100%-INH-80-INH-100%.
32. Go to [THRO CURVE] ST-1. Set this so that you get a comfortable hovering speed. I set this at 100%-INH-60-INH-100%.
33. Go to [THRO CURVE] NORM. Keep this linear unless you have an unusual motor response. Set this at 0-INH-50%-INH-100%.
34. Go to [THRO HOLD]. Use Select key to toggle between throttle hold value and desired activating switch. Set throttle value at -5.%. It is a negative value to ensure that the throttle is zero in case the esc setting drifts. Choose your desired switch. I selected SW: RUDD D/R simply because I am used to that position. You can use AUX2 if you wish to use the RUDD D/R for dual piro rate control.
35. After all settings are final, bind your receiver to the transmitter once more while keeping the transmitter sticks in your desired failsafe settings. This does away with the cyclic servos being crooked and buzzing while the receiver arms.
36. Fine tune after your test flight.
37. Go fly your heli! Congratulations.
ADDENDUM
I did some head tuning earlier this week. I was surprised to see that my cyclic max angles weren't equal. So here's what I did.
• adjusted links lengths as per user's manual
• adjusted tx subtrim to center servo arms
• made sure I had zero pitch for both blades at midstick idle up
• checked for max pos and neg pitch symmetry (equal values)
• re-adjusted links since they were not.
• checked max aile cyclic for left and right
• adjusted tx servo endpoints to make aile cyclic equal
• adjusted tx swash mix to yield 8 deg max pitch
• did same for elev
• adjusted tx swash mix to get +/- 10 deg pitch max pitch range.
Notice that I prioritized the use of servo endpoints for cyclic symmetry rather than swash leveling. I left that duty to the servo links and tx subtrim.
Gino CP is offline Find More Posts by Gino CP
Old Jul 20, 2008, 11:19 AM
JustinMoore12 is offline
Find More Posts by JustinMoore12
JustinMoore12's Avatar
USA, VA, Woodbridge
Joined Sep 2007
Haha, gino beat me to it. GOOD JOB BTW GINO!
JustinMoore12 is offline Find More Posts by JustinMoore12
Old Jul 20, 2008, 12:53 PM
p4ddy is offline
Find More Posts by p4ddy
RC4Life not just 4 xmas
p4ddy's Avatar
southampton uk
Joined Jun 2006
II. Function Mode
CH4: Rudder (gyro)
9. AILE, ELEV, and PIT. adjusts the cyclic servo maximum throw. Always adjust all three pairs of H and L in identical values. Values for AILE, ELEV, and PIT. must also be identical. This ensures no unneeded output interaction when controlling the cyclic action. You can adjust these to give you more or less cyclic angles. Max these out without having the servos buzzing. Recheck these settings after centering the servo arms at mid stick using the [SUB TRIM] menu.
Ha Ha!! Hey Gino, How long did that take to write
p4ddy is offline Find More Posts by p4ddy
Old Jul 20, 2008, 01:23 PM
USA, VA, Woodbridge
Joined Sep 2007
Did you really have to quote it?
Old Jul 20, 2008, 06:00 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
About 5 seconds. I have that stored in my Mac. Wrote that a long time ago. I will put it in my RCG blog soon.
Old Aug 17, 2008, 12:56 PM
brian94066 is offline
Find More Posts by brian94066
VBARRRR
brian94066's Avatar
USA, CA, San Bruno
Joined Jul 2007
this should be stickied
i'm getting an SA too
brian94066 is offline Find More Posts by brian94066
Old Aug 17, 2008, 04:46 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Suggestion: Change the first line to "DX7 Setup for Trex450, Belt, and most other mini helicopters" or the equivalent.
Very good stuff. Thanks.
Daedalus66 is offline Find More Posts by Daedalus66
Old Aug 25, 2008, 11:05 PM
richord is online now
Find More Posts by richord
United States, FL, Jacksonville
Joined Jun 2008
I think I read somewhere that the physical gain on the Gyro should be set @ max. (100%) and then use the settings in the TX?
richord is online now Find More Posts by richord
Old Aug 25, 2008, 11:15 PM
USA, VA, Woodbridge
Joined Sep 2007
Depends on what gyro you have, some need to be set at 50% and most higher quality do not have a gain pot on the gyro itself.
Old Aug 25, 2008, 11:39 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
There are no absolute number on where gyro gain should be set. The tail has mechanical gain influenced by how much the slider is moved in relation to servo movement. How much mechanical gain you have affects the gain needed on the gyro.
If you find that you need more than 80% gain on the gyro until the tail wags then you have a low mechanical gain. Move your links farther out on the servo arm.
If you find that you need 40% or less gyro gain then you have a high mechanical gain. Move the link closer to the servo output shaft's center.
Again the numbers are ballpark figures. Numbers may differ from one gyro to the other or one tx to another, etc. Tail response will tell you if you are spot on or not.
Old Dec 30, 2008, 10:41 PM
Glenford Esty is offline
Find More Posts by Glenford Esty
USA, GA, Atlanta
Joined Nov 2008
Gino, great article but I have a question. I have 2 helis using futaba GY401 and Art-tech V3 gyros with AR6100 receivers and DX7 transmitter, where do I set the limit / gain on the gyro itself in respect to the settings you recommend for the radio?
GE
Glenford Esty is offline Find More Posts by Glenford Esty
Old Dec 30, 2008, 10:49 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
The GY401's gain is set remotely through the DX7. You can assign the Gear channel for gyro function or program gyro settings in each individual Flight Modes. With the Gear switch, you can quickly switch from hh to rate regardless of flight mode. Great for setting up.
I have no experience with the Art-tech V3 gyro.
Old Dec 30, 2008, 10:50 PM
Skarn is offline
Find More Posts by Skarn
Maryland
Joined Nov 2006
The 401 does not have a gain pot on it...the gain is set directly on the radio.
The limit pot is used to ensure no binding in either direction.
LOL I see Gino beat my by one minute
Skarn
Skarn is offline Find More Posts by Skarn
Old Dec 30, 2008, 10:58 PM
USA, GA, Atlanta
Joined Nov 2008
Perfect!!! I know the GY401 doesn't have a gain pot... was really checking the limit setup for that one. The question of gain settings was mainly for the V3 but I ordered another GY401 so i'll just wait until that arrives. the V3 is taking too much to setup. I just tried the suggested setup for the 401 and with some fine tuning tomorrow the heli should be perfect.
Thanks again!!!
Discussion DX7 Radio Setup for 3D Xptical 3D Flying 6 Jan 03, 2008 09:29 AM
Discussion Screen by screen setup for Trex 450 SE and a JR 6102 Dave K Mini Helis 4 Jan 14, 2007 12:26 AM
Discussion Spektrum DX6 radio setup for Honeybee Cool/King - Flight Test Results cgschaefer Mini Helis 2 Jun 02, 2006 05:31 AM
Question Spektrum TX Programming Question for Trex 450 XL HavingFun2002 Mini Helis 11 Feb 19, 2006 08:42 PM
Discussion Spektrum TX Programming Question for Trex 450 XL HavingFun2002 Radios 0 Feb 19, 2006 09:21 AM
