Old Jan 31, 2003, 01:55 PM
MikeSt is offline
Find More Posts by MikeSt
Toronto,Canada
Joined Jul 2002
airspeed vs dynamic air pressure
Given "standard day" conditions, what is the relationship between impact pressure on a pitot tube and the indicated airspeed ?
I found this formuala :
velocity = square root of (2 x [impact pressure - static pressure] / air density).
To solve for Vel = 1, (1 what ?? .. ft/sec ?), I used Static= 14.7 lb/in^2, air_density= .00237 slug/ft^3
got impact_press = 14.701185 lb/in^2
Is that correct ? (14.701185 lb/in^2 pressure difference = 1 ft/sec ?
If so, how would I solve for Vel=XX. I realize it's a "basic" math question, but basic math is not one of my strong points
MikeSt is offline Find More Posts by MikeSt
Old Feb 02, 2003, 12:52 PM
Dick Huang is offline
Find More Posts by Dick Huang
Dick Huang's Avatar
Dallas,TX, USA
Joined Mar 1999
Hi Mike,
I use the equation for dynamic pressure(q) where
q= 1/2 Rho*V^2
q is in lbs/ft^2, Rho is in slugs/ft^3 or lbs-sec^2/ft^4 and V is in ft/sec.
If we assume 88 ft/sec (60 mph) for V,
then q=0.5*0.002377*(88)^2=9.20 lbs/ft^2. which will be the total pressure on a pitot tube.
Dick Huang
Dick Huang is offline Find More Posts by Dick Huang
Old Feb 02, 2003, 02:47 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Total pressure is static + dynamic (q).
A conventional airspeed indicator subtracts (it's vented to static) static from total to show "airspeed", which is actually the dynamic pressure. The bent tube that runs the needle in the airspeed indicator reads total directly.
The altimeter shows static pressure.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Feb 02, 2003, 06:00 PM
MikeSt is offline
Toronto,Canada
Joined Jul 2002
Originally posted by Dick Huang
Hi Mike,
q= 1/2 Rho*V^2
Dick Huang
Thanks Dick.
I've read about "q" before, time to review it again
Old Feb 03, 2003, 08:39 PM
Sail 'n Soar is offline
Find More Posts by Sail 'n Soar
Cincinnati, OH
Joined Aug 2002
QUOTE]Given "standard day" conditions, what is the relationship between impact pressure on a pitot tube and the indicated airspeed ? [/QUOTE]
An interesting discussion, but why do you ask?
In terms of modeling, the important thing to know is "q", calculated as Dick Huang suggests. Seeing that q is a function of the velocity squared, in terms of Standard day, 20 fps (13.6 mph) equates to about 7.6 oz/sq ft, 40 fps to 30.4 oz/sq ft, and and 60 fps to 68.5 oz/sq ft. These are the numbers that relate to stall speeds for a given wing loading, design CL, etc.
Sail 'n Soar is offline Find More Posts by Sail 'n Soar
Old Feb 04, 2003, 02:12 AM
MikeSt is offline
Toronto,Canada
Joined Jul 2002
Old Feb 04, 2003, 02:13 AM
MikeSt is offline
Toronto,Canada
Joined Jul 2002
Why is the sky blue ?
Nothing really to do with *practical* modeling (airspeed question).
But I figured someone here would know the answer.
Old Feb 04, 2003, 06:00 AM
Capt. Electron is offline
Find More Posts by Capt. Electron
Senior Moment Member
Virginia Beach, Va.
Joined Jan 2002
To add a little more to it, 'indicated airspeed' on the dial is not true airspeed. True airspeed is indicated airspeed adjusted for temperature (density). Full scale pilots use indicated airspeed plus outside air temp to compute their true airspeed.
Jimmy
Capt. Electron is offline Find More Posts by Capt. Electron
Old Feb 04, 2003, 11:37 PM
gleasonll is offline
Find More Posts by gleasonll
Ridgecrest, CA
Joined Feb 2003
just to add a little confusion--don't forget to add calibrated airspeed (indicated airspeed corrected for position error) between indicated and true.
gleasonll is offline Find More Posts by gleasonll
air pressure needed for AMT air start ?? wojtek Fuel Jet Talk 15 Nov 22, 2004 08:17 PM
Land "vs." Air Frequency tenover Electric Plane Talk 155 Nov 18, 2004 05:45 AM
air pressure behind spinner? nupeswv Modeling Science 2 Oct 11, 2004 04:28 PM
MF480.....static vs dynamic stegla Electric Ducted Fan Jet Talk 12 May 30, 2002 05:04 PM
airspeed vs groundspeed vs flutter. DeaninMilwaukee Power Systems 13 Apr 11, 2002 01:29 PM
