Old Jul 19, 2008, 08:45 PM
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
Originally Posted by aaron_gx
dundamnitpete, sorry about your loss. I had one myself today. I've flown my easystar FPV 4 times previous to today, and launched the plane into the wind, turned around and got it stable. I grabbed my glasses, put them on, and there was nothing but a whiteout. Confused, I ripped the glasses off, just to spot the plane upside down, heading STRAIGHT into the ground.
I got to the plane, and found it literally sticking out of the ground, tail in the air, nothing holding it there, except the nose burried 4" into the soft dirt. Nose is split in 6 places, but amazingly no other damage. The gorilla glue is currently drying, with splints clamped on either side to attempt to straighten. I presumed it to be a total loss, but my lipos are still ok, motor, cam, tx are ok aswell. I will be more careful next time!!!
The great thing about this hobby is, for the most part, you never make the same judgeemt error twice.
sounds like today just just a bad day overall for FPV
good thing all yor equipment is ok
gundamnitpete is offline Find More Posts by gundamnitpete
Old Jul 19, 2008, 08:50 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Originally Posted by mdw21
Nice one. Reminds me of my second FPV flight. All 15 seconds of it. Crash caused by low voltage cutoff due to using a Lipo that wouldn't give enough amps for the heavier setup with onboard cam and downlink.
Wild Hawk crash (onboard camera) (0 min 17 sec)
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Jul 20, 2008, 10:47 AM
Funjet2008 is offline
Find More Posts by Funjet2008
plus vite plus loins
Funjet2008's Avatar
Canada, QC, Trois-Rivières
Joined Jun 2008
i dont understand heavy setup cam and Tx
cam and Tx pull no more 500-1000mah!!!!!!
Funjet2008 is offline Find More Posts by Funjet2008
Old Jul 20, 2008, 11:41 AM
Joined Oct 2006
I meant heavy weight. My video tx is 4 oz. and my camera is 4 oz. To produce the extra thrust to pull this extra weight, the motor was probably trying to draw more amps than the lipo could give.
Old Jul 20, 2008, 12:08 PM
Funjet2008's Avatar
Joined Jun 2008
ok i understand.....
i have good news for you..
I use mini brushless for my Easyglider with APC 8x4 and i pull only 10 amp with FULL FPV (dragon, osd, gps, tx 500mw, cam, etc.........
My Cub (92" wingspan) ***7 kilo*** pull only 29 amp with other brushless with APC 15 x 8
you need to select the best brushless for your plane.
Old Jul 20, 2008, 12:24 PM
Joined Oct 2006
Which mini brushless are you using? 10 amps would be sweet.
Old Jul 21, 2008, 10:05 AM
Funjet2008's Avatar
Joined Jun 2008
this one... the best for easystar and easyglider.. with 7 x 4 or 8 x 3
not much power but very little consumption.. 10 amp full trottle
Old Jul 21, 2008, 11:21 AM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Darth,
That was really nice video right up to the crash, what did you use to record it ??? The transmitter looks big, there are much smaller ones available that would be lighter. I also get rid of all the connectors, and solder wires, its more reliable and lighter. Dont give up on FPV, once you get your setup working, and if you have skills, its very rare to have a crash. I went 2 years flying FPV a lot with no crashes, I am sure VR FLyer and others get similar results. Most people at the RC field fly several 10 or 15 minute flights, less than an hour in the air all day. I saw 4 or 5 " Normal RC " crashes at the field yesterday, which is typical for a Sunday ... I flew my plane in the air a total of 3 hours, no problems.
JettPilot
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Jul 21, 2008, 11:38 AM
AndrésMtnez is offline
Find More Posts by AndrésMtnez
AndrésMtnez's Avatar
Madrid, Spain
Joined Dec 2004
The motor current doesn´t bother about the plane weight. If it´s heavy you´ll need to keep the throttle higher to fly, but the current at WOT will be the same if it weights 10oz that if it´s 30oz
There are lots of threads recommending setups for FPV easy stars, use the search for more details, but you´ll need a motor around 1500kv 15A to 2500kv 30A depending on how much power do you want. Obviously the battery have to be of enough capacity and C´s for the motor/prop you´re going to use, wich seems the part that failed in your setup...
AndrésMtnez is offline Find More Posts by AndrésMtnez
Old Jul 21, 2008, 12:28 PM
Joined Oct 2006
I was recording with an onboard Pentax Optio s5z. Picked it up on eBay a couple months back for $55 bucks. It has A/V out which I tap into to send to the tx. You're right about the tx being big (and it weighs 4 oz.) and all the extra weight with the connectors and such. I'm thinking about getting a Range Video 900mHz 500mw setup, in part because it's lighter but also because my current downlink, which is 2.4Ghz, is interfering with my Spektrum.
Discussion My new FPV ground station and first flight with new OSD jonpet55 FPV Talk 7 Jun 04, 2008 03:04 PM
Discussion My first FPV flight, 45mph winds and I crashed into a tree, why is video crappyKX-191 jasper7821 FPV Talk 24 Apr 27, 2008 01:08 PM
Discussion My first really FPV flight vladz FPV Talk 5 Jan 01, 2008 04:29 PM
Discussion assembling my first FPV rig, need guidance JayJay76 FPV Talk 4 Feb 09, 2007 04:32 PM
My first flight!! First crash also spyder6166 Micro Helis 18 Jan 17, 2005 07:14 AM
