Old Jul 18, 2008, 04:53 PM
cloud-9 is offline
Find More Posts by cloud-9
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Reinforce fiberglass fuse: glass, kevlar, or CF?
Hi, I have an Electrostreak with fiberglass fuse. I have read that the wing saddle is weak and can use reinforcement. Also, I want to put a wheel in the center of the fuse to land on, which should be reinforced.
Should I use fiberglass cloth and resin, kevlar cloth and resin, or some kind of carbon fiber cloth? And any pointers to the kind of stuff I should use?
Many thanks....
Jim
cloud-9 is offline Find More Posts by cloud-9
Old Jul 18, 2008, 05:38 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I've used kevlar and cf and fg on some built up dlg's. Kevelar is very good for reinforcing small palces, (adding the wheel well), CF is good for long or larger areas.. pods,, along tops of spars (wind saddles on inside of fuse near the top of the saddle extending forwrd and back past the wing root). FG is good for all over strength.... Of course i'm no expert and this is advice is free...
Thermalin is offline Find More Posts by Thermalin
Old Jul 18, 2008, 07:41 PM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Thanks....
Old Jul 19, 2008, 07:15 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Kevlar is very strong, but not very stiff.
Carbon fiber is very stiff and pretty strong.
Fiberglass is reasonably stiff and strong.
So decide what characteristics you need.
Pinecone is offline Find More Posts by Pinecone
Old Jul 19, 2008, 09:35 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Thanks, just what I need. Since I want strong and stiff to protect the fiberglass fuse from cracking, carbon fiber sounds best. Is this an example of what I should buy? It's just like cloth, so it seems like any stiffness would come from the epoxy if I just use epoxy and this stuff. Should I use CA, or am I barking up the wrong tree with this product?
Old Jul 20, 2008, 05:06 AM
Pinecone is offline
Will fly for food
Maryland
Joined Sep 2004
The stiffness comes from the fabric being trapped in some matrix. I would use epoxy in your application.
Clean and sand the area where you are putting the reinforcement. Apply cloth and resin, then use paper towels to remove excess resin. Too much resin makes the layup brittle and weak.
Old Jul 20, 2008, 05:15 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Thanks.....
Old Jul 23, 2008, 12:55 AM
mike early is offline
Find More Posts by mike early
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
where are you purchasing your CF cloth?
mike early is offline Find More Posts by mike early
Old Jul 23, 2008, 01:06 PM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
I have only looked online, but have not purchased. There are several places.
Jim
Old Jul 23, 2008, 02:54 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
Would you mind providing a link or two?
I've searched, and am not sure what is what, really.
Old Jul 23, 2008, 10:53 PM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
I didn't save any links, but all I did was google "carbon fiber cloth".
Jim
Old Jul 23, 2008, 11:16 PM
mike early's Avatar
USA, KY, Ashland
Joined Oct 2007
err, me too
But was hoping to gain some insight as to what weights, weaves, etc are best for our usages.
Old Jul 24, 2008, 01:05 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
err, me too
Well, if I knew that I'd sure tell you, so maybe somebody else will say.
Old Aug 03, 2008, 07:20 PM
julian.i is offline
Find More Posts by julian.i
Flys like a chocolate teapot
Joined Mar 2008
as far as weights go, i dont know the plane so i cant really help but i would imagine that you would want something 120-200gsm (grams per square meter).
to get a feel for the materials, carbon has a very high tensile strength, and will crack before the epoxy arround it, fiberglass cracks at about the same stress as the epoxy around it, and kevlar holds when the epoxy has cracked leaving "rope," if you are anticipating the area will need to flex use this.
there are sevseal types of weve you could use and all the diferencees are between them are how many directions of strength they have, plain weve cloth has 2 at 90 degrees to each other, twill weve has 3 set at 60 degrees to each other, for your application, at least the wing saddles, you might want to consider tow, which is a unidirectional (one direction of strength) set of fibres like an unwound rope. this is generally used for wing spars and reinforcement in the rc world.
for the u/c wheel you will want to make a "hard point" in the bottom of the fuse, i would use cloth for this, plain weve its cheaper and doesnt make much odds, and just place a square or circle arround where the wheel is to be attatched and add resin make sure all the cloth is wetted out (soaked up the resin), dab off any excess and leave to dry, the cloth should soak up most of the resin it needs for strength so if you lightly dab some kitchen towel or similar over the cloth this should take off any unnececary weight caused by the unreinforced resin. the wheel can then bolt through this.
if i were you i would go with a lighter weight cloth than you think you need, you can always add layers, much harder to take them off.
if you decide to use cloth you can lighly use spray adhesive before the resin so the cloth does not slip arround (any adhesive soaked up by the cloth will sap strength so you might want to do a test spray)
finally; good luck, hope this helps
cheers
julian
julian.i is offline Find More Posts by julian.i
Old Aug 04, 2008, 12:55 AM
cloud-9 is offline
Prop me up
cloud-9's Avatar
New Mexico, USA
Joined Oct 2007
Julian, thanks for the excellent help, it's just what I needed. Which type of cloth would you choose for the hard spot on the bottom which will support the wheel?
Thanks again.
Jim
cheers
julian
Question where can I buy a CF, Kevlar or Fibreglass fuse? macr Electric Sailplanes 21 Jan 25, 2005 04:08 PM
Fiberglass/ S-Glass / Kevlar/ CF/CF Mix Gunny Aircraft - Sailplanes (FS/W) 2 Mar 22, 2004 08:43 AM
Making a Fiberglass fuse (or parts).... Arbo Modeling Science 10 Oct 16, 2003 10:32 PM
What's a better fuse material kevlar or carbon? soholingo High Performance 18 Jun 04, 2003 06:33 AM
fiberglass wings and fuse glass weights mothflyer Slope 4 Mar 12, 2003 05:18 PM
