Old Sep 02, 2008, 03:04 AM
bunggorb is offline
Find More Posts by bunggorb
Rush
Joined May 2007
I now have a HET 6904, 2w-20, 72amp esc on the F4. Very big improvement over the stock setup and she is now fast! no videos of it flying but everyone that watched it was pleased at how fast it was going. Peak power at 935 Watts at 65 amps which is stretching the motor limits and esc. Settled down to 800 watts after a bit when the lipos had dropped down. But still fast enough for me.
The HET drive kit was a direct drop in. I only had to make a new hole in the top hatch for motor wires as i couldnt run it through the original access hole.
Flew on a Rhino 4S1P setup and i know have been able to modify the battery compartment to fit 4s2P 2350 Rhino Lipos from HC, or 4S1P FP 3700's or 4250 evolites. CG moved forward by and inch or so but i believe still flyable but will need to watch trims when i take her up on 4S2P.
The only problem i have now is that the ESC is cutting out. On the maiden it cut outin 2 mins of flight time and i was lucky enought to land the F4 with minimal damage. Just broke the nose gear.
I am not sure if this is due to ESC settings or due to Overtemp cutoff of the Tsunami 75amp ESC. I assumed the ESC was plug n play and did not require any programming. I ran a few static tests today with it using only mid throttle range, and after a minute or so, the esc would cut out. Does anyone have any idea why the ESC would cutout only after 1-2 mins? When i close the throttle, the esc will start-up again. Does anyone have an idea or do i need to program the esc?
Appreciate your inputs... lovely bird now. Flies as it should and beautiful in the air. Replace the stock servos... they're definitely not strong enough....
bunggorb is offline Find More Posts by bunggorb
Old Sep 02, 2008, 06:00 AM
bunggorb is offline
Rush
Joined May 2007
ESC fixed i think... i cut away shrink wrap around the esc being exposing the board to more airflow. i also cut away at the metal plate/heat sink exposing it to air as well. This seems to have solved the problem.
Those Rhino Lipos are a bit of a shock. they can give 60amp at burst, 935 watts peak and hod better voltage than my flight powers. My 25C FP 3700 and Evolite 4250 packs which have around 40 cycles cant match these burst and contrinuous current draws that the Rhino Lipos have. What gives? Thought FP packs were superior to the Rhino/Zippys as they were certainly way more expensive than them....
I havnt cycled all the zippy packs i now have but power wise, they are better than FPs and value wise, far far better and they hold voltage better.... go figure
Old Sep 02, 2008, 03:48 PM
rick88ss is offline
Find More Posts by rick88ss
Miami,FL
Joined Jun 2007
Are you using bullet connectors between the motor and ESC? Try soldering the 3 motor to ESC wires. Had that happen on a 40A setup and soldering the wires fixed the problem.
rick88ss is offline Find More Posts by rick88ss
Old Sep 02, 2008, 08:25 PM
AR1516 is offline
Find More Posts by AR1516
Amped UP!
Saint Cloud FL
Joined Jan 2007
Need to check your LVC. The cut off point might be set too high, the controller see's this as low voltage and cuts off. I say this since you indicated that cycling the throttle turns the motor back on. In the event of over-heat it would take a while to reset.......just my .02 worth.
AR1516 is offline Find More Posts by AR1516
Old Sep 03, 2008, 01:35 AM
bunggorb is offline
Rush
Joined May 2007
I cut away the heat shrink around the Tsunami 72amp esc. This seems to have solved the problem as on static test runs, this seems to have solved the issue of the power cutting out.
The tsunami ESCs are a bit of a pain as they cant be stick programmed. I need to buy that stupid USB adaptor to be able to program it. The drive kit is preprogrammed for 4S with the 2w20 motor. I got the 72 amp esc version just so that i had extra capacity to avoid thermal cutoff, but apparently, it wasnt enough.
I'll try to get a video of the phantom this week flying on 4s2p.
Regards & Thanks
Old Sep 08, 2008, 11:48 AM
gtanoira is offline
Find More Posts by gtanoira
gtanoira's Avatar
Florida
Joined Aug 2008
hi bunggorb,
I am having the same problem as you with a Tsunami 72A esc mounted in HET F-18. The rest of the power package is the same (6904 fan with 2W-20 motor).
Did cutting out the heat shrink solved the problem?
I suspect that my esc is overheating because it gets really hot in a few seconds although I am just running around 45A at full throttle on a 72A rated esc.
I've done some bench measures and minimum cell voltage during the cut-offs was 3.7V per cell so I don't think it is an LVC issue, although I cannot confirm as I don't have the PC cable to check the esc configuration.
BTW, does anyone has the schematics of the tsunami ESC-to-PC cable?
thanks,
Gaston
gtanoira is offline Find More Posts by gtanoira
Old Sep 08, 2008, 11:52 AM
LuckyDuc is offline
Find More Posts by LuckyDuc
LuckyDuc's Avatar
United States, WI, Hustisford
Joined Dec 2005
Are you guys running a separate switching BEC? I had to with my Tsunami as its BEC can't handle the heat.
LuckyDuc is offline Find More Posts by LuckyDuc
Old Sep 08, 2008, 12:18 PM
bunggorb is offline
Rush
Joined May 2007
Yup, running separate UBECS as i dont like linear becs.
Cutting away the heat shrink cools the esc down more than before but I still have ESC cut offs in flight but not as much as i used to. I have also managed my flights with less WOT bursts in order to keep esc temperature down. Note that my esc is not directly in the airflow. I can also hold the esc after use so i dont think it gets as hot as it could and i'm drawing about 60A bursts, 900+ Watts on my F4. I am now flying it WOT, 50% then glider mode to cool the ESC down but this is not my preferred way to fly!
If LVC is set at 3.7V then this is to high. I would prefer LVC to be about 3.3V and not cut off. I would rather it is set on reduced power if it hits 3.1V/cell.
Does anyone know the stock program settings of the tsunami 72A ESC?
I'd hate to have to buy that $(#@@! programming cable. Stick programming works fine for the most part. less hardware to bring to the filed as well!
The only other option left is to cut open the F4, relocate the esc directly in the airflow i think. but its a bitch as its an arf kit version....
Old Sep 08, 2008, 12:33 PM
LuckyDuc is offline
LuckyDuc's Avatar
Joined Dec 2005
That is a bummer. Looks like you need to pick up one of the programming cables to make sure the LVC is set to a lower voltage.
Old Sep 08, 2008, 12:50 PM
gtanoira is offline
gtanoira's Avatar
Florida
Joined Aug 2008
bad news. I cut out the heat shrink and put the esc on the air flow and it still cuts out after only 30s of applying power with maximum current of 45A
I think my ESC is busted and now that I've cut out the shrink I won't be able to return it
I hear recommendations of ESC + BEC or ESC with onboard switching BEC. What 60A ESC would you guys recommend?
thanks!
Gaston
Old Sep 08, 2008, 01:00 PM
Socomon is offline
Find More Posts by Socomon
Joined May 2006
Any of the Hobbywing ESCs sold under various brand names:
Pentium, Turnigy, ThunderPower, etc.
Socomon is offline Find More Posts by Socomon
Old Sep 09, 2008, 07:08 AM
bunggorb is offline
Rush
Joined May 2007
If you can find someone with a programming cable, might be good to check the settings. I think it might be the LVC setting of the esc is to high. I will on average drop a lipo voltage below 3.3V on WOT for extended periods of WOT. This is on normal flyouts with low speed passess, vedrticals, etc... which is common enough for jets.
I have asked HET what the stock settings are on the 72amp esc but no reply from them... Ihope this isnt normal customer service from HET.... if it is i'm switching to WEMO
Old Sep 09, 2008, 10:58 AM
gtanoira is offline
gtanoira's Avatar
Florida
Joined Aug 2008
I don't think is a LVC issue. I am pretty much convinced now that the ESC is busted. Yesterday I noticed that it gets hot just by plugging the battery with only the receiver connected to it. no motor connection...
HET customer service is really bad so I bit the bullet and ordered a Turnigy 60A which includes a 3A switching UBEC for less than $50.
Old Sep 09, 2008, 11:02 AM
LuckyDuc is offline
LuckyDuc's Avatar
Joined Dec 2005
Where are you ordering the Turnigy from?
Old Sep 09, 2008, 11:28 AM
gtanoira is offline
gtanoira's Avatar
Florida
Joined Aug 2008
hobbycity.com
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 709 Jan 16, 2008 10:40 PM
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 0 Nov 14, 2002 12:44 AM
FS: Factory New AERC F-4 Phantom Taking Pre-Orders Now gbagley Aircraft - Electric - Airplanes (FS/W) 9 Oct 16, 2002 08:50 PM
Great Planes F-4 Phantom greenshirtrwg Fuel Plane Talk 0 Jun 05, 2002 10:25 AM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 12:27 PM
