Old Feb 11, 2013, 06:48 AM
The43rdHammer is offline
Find More Posts by The43rdHammer
The43rdHammer's Avatar
United Kingdom
Joined May 2010
Originally Posted by Tartago View Post
If you take care of doing a smooth take off, the nozzles can be left alone.
I couldn't agree more, I have 2 that fly extremely true with the proper application of throttle / elevator mixing.
Andy
The43rdHammer is offline Find More Posts by The43rdHammer
Old Feb 11, 2013, 09:27 AM
Rangerfan is offline
Find More Posts by Rangerfan
Rangerfan's Avatar
United States, TX, Grapevine
Joined Jul 2012
True. But it takes less time to do the mod than it does to program the mix. I think I did my mod in maybe 30 seconds.
Either way will work.
Rangerfan is offline Find More Posts by Rangerfan
Site Sponsor
Old Feb 11, 2013, 11:18 AM
United Kingdom
Joined May 2010
30 seconds... a new sport, speed moding!
Old Feb 11, 2013, 05:35 PM
jb0005 is offline
Find More Posts by jb0005
FLY HARD OR FLY HOME TO MUMMY
jb0005's Avatar
Joined Jan 2011
ok maybe a little longer than 30 seconds, but a lot easier than trying to find the correct elevator/throttle mix, and it takes the stress out of hand launching..full power and throw with no pitch up. i agree the plane is flyable with the nozzles in their original position, but the gentleman asking if its a good FIRST edf does not want to be compensating for bad flight manners or going through the first dozen or so flights trying to get the throttle elevator mix right. the good thing with the nozzle mod is that you can hold it vertical as i have described and test it before you fly it to make sure you have the right angle and no unwanted yaw from crooked nozzles. having said that if you cut 5 mm off the bottom (5 degrees) you wont go wrong, i'll bet its spot on first try. anyhow, you don't have to believe me, try looking at some pictures of real f4's and you'll see mcdonnell douglas has done the homework for us. the real f4 has the exact same nozzle angle as i'm describing
jb0005 is offline Find More Posts by jb0005
Old Feb 12, 2013, 03:04 AM
Tartago is online now
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
I don't use any mix, just gentle on the elevator with 25% DR.
Tartago is online now Find More Posts by Tartago
Old Jun 03, 2013, 10:07 AM
United Kingdom
Joined May 2010
Some photos from this weekends flying.
Old Jun 04, 2013, 09:46 AM
Plane crazy
Tartago's Avatar
Joined Apr 2006
Nice planes there!
I have the same two (+ the german 50 now but nib).
I installed retracts on the camo one. She looks so nice!
Old Jun 04, 2013, 08:31 PM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Nice planes there!
OMG! Where did you get those retracts?!
will3kgt is offline Find More Posts by will3kgt
Old Jun 05, 2013, 02:10 AM
Plane crazy
Tartago's Avatar
Joined Apr 2006
Small servo less retract with metal trunnion and really cheap alloy struts from Hobbyking.
Old Jun 21, 2013, 08:21 PM
zeroin1shot is offline
Find More Posts by zeroin1shot
United States, MI, Waterford Charter Township
Joined Oct 2007
Many Thanks to Sniper1 for all his help!
140 mm CG.
35 ounces AUW.
HET 2W-20.
6904 Fan.
60 Amp Turnigy Plush.
5S-2700 mah Battery / 1211 Watts - 70 Amps.
4S-3000 mah Battery / 775 Watts - 53 Amps.
Both Batteries weight 325 grams.
Cheater hole with screen in front of the fan.
zeroin1shot is offline Find More Posts by zeroin1shot
Old Jun 21, 2013, 11:34 PM
DonQ8401 is offline
Find More Posts by DonQ8401
Why am I addicted!!!
DonQ8401's Avatar
United States, IL, Columbia
How did the 6904 fly?
DonQ8401 is offline Find More Posts by DonQ8401
Old Jun 22, 2013, 04:34 AM
sniper1 is offline
Find More Posts by sniper1
sniper1's Avatar
Crawley Down, sussex, England
Joined Dec 2004
959 Watts
51.82 Amps
140 mm CG
37 ounces AUW
HET 2W-20, I Suspect the KV on this one is low at 2980 or so.
6904 Fan
5S-2700 mah Battery
Stunning Phantom mate!
Well done!
Im going to need a wingman the next time im cleared hot on a danger close napalm run! Although the flak may spoil your paintjob!!
sniper1 is offline Find More Posts by sniper1
Old Jun 24, 2013, 10:04 AM
United Kingdom
Joined May 2010
Sorry, just seen this
The 6904 flies well, it's my favourite of the two (I think) as there's bags of power and obviously far more efficient than the CS10 - I get over 5 minutes on the 6904 versus 3 minutes on the CS10.
You do have to live with a little bit of a whine from the motor though, but I can live with that (I've actually grown to like it!)
Andy
Old Jul 08, 2013, 02:40 AM
United Kingdom
Joined May 2010
F-4 Phantom over Hampshire, UK
Some footage from yesterday's flying:
FMS F-4 Phantom - Andy Smith - 7 July 2013 (4 min 53 sec)
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 709 Jan 16, 2008 10:40 PM
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 0 Nov 14, 2002 12:44 AM
FS: Factory New AERC F-4 Phantom Taking Pre-Orders Now gbagley Aircraft - Electric - Airplanes (FS/W) 9 Oct 16, 2002 08:50 PM
Great Planes F-4 Phantom greenshirtrwg Fuel Plane Talk 0 Jun 05, 2002 10:25 AM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 12:27 PM
