Old May 28, 2011, 08:15 PM
will3kgt is offline
Find More Posts by will3kgt
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Here's some chase cam footage of F-4.
New Chase Cam, Chase Will's plane and Him at the end!! (3 min 33 sec)
will3kgt is offline Find More Posts by will3kgt
Old Jul 21, 2011, 02:10 AM
Steve2308 is offline
Find More Posts by Steve2308
Has nowhere to store his Jets!
Sydney
Joined May 2007
LOL " I got Skills"
And your flying buddy running out of the way is a laugh!!!
Great footage... you fly like I do throttle pegged to max a lot of the time!!
What sort of cam did you use?? Looks like flycam one footage.. probably wrong..
Thanks for the vid.. Awesome place to fly too!!
I'm putting in some retracts in my bird... should be a bit quicker too....
Steve
Steve2308 is offline Find More Posts by Steve2308
Old Jul 21, 2011, 07:20 AM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Originally Posted by Steve2308 View Post
LOL " I got Skills"
Steve
That was a cool vid, I was the guy running at the end... Just a little improv.
So you're putting in retracts? Please send pics or vids.
Old Aug 24, 2011, 01:28 AM
Sydney
Joined May 2007
Sorry for the slow reply......
Been looking at doing retracts into this little bird for a while...
I have these (For a while actually)
http://www.hobbyking.com/hobbyking/s..._gear_set.html
They are smaller than even I thought...
But with all the super small servoless retracts coming out I decided to buy these
http://www.hobbyking.com/hobbyking/s...teerable_.html
And
http://www.hobbyking.com/hobbyking/s...dproduct=11301
After looking quite hard at possible designs...
I've conceded that without a ton of work, it's going to be very difficult to maintain a scale outline of the F4.
The ducting to the inlet of the fan is the issue...The foam is very thin in the whole area where i would put the wheels.
I can always tilt the battery up toward the front for clearance (maybe even add the plastic rod to rotate the strut 90 degrees) But am going to have to sit on this for a while...
Maybe someone can add pictures on how they did theirs??
There was one earlier in this thread with retracts but wasn't clear enough.
Steve
Old Aug 25, 2011, 02:27 AM
Sydney
Joined May 2007
Maiden Report
Well it's been a very long time since the second one was completed and flown...lots of reasons....
But today it happened:
E-flypower fan and motor. 3 blade fan 70mm , himax 4400kv inrunner.
X-Power 60 amp opto esc, Turnigy 5 amp external BEC.
2500mah 25c 4S battery.
Spektrum DX7 running flapperon mix.
Ailerons 15mm down 7.5mm up (50% diff)
Flaps 50% 7.5mm 100% 15mm
elevator 20mm up/down
C of G set at 140mm from the L/E.
Well, I was shaking as I haven't flown a ducted fan for over a year and a half
With this setup it's just under 760watts (Not bad for 2 years++ old)
Lots of power, Lot's of speed (For me at least) and after the range test...
She tracked straight and true on rollout.
Lifted off with a tiny thought and climbed VERY strongly.
This is where I began to tremble.... Wow, what a fast one.
On half throttle she cruised perfect... no trim needed at all (??!!)
On full she was quite fast... enough to scare me anyway. on no throttle, she is a greased brick LOL... never knew exactly what that mean't till today!!
Tested the throws, Flapperons (Highly recommended!!) but surprisingly she doesn't need all that much even to cruise around!!
Took 4 attempts to land her (Came in way too hot) as I didn't want to slow her too much...
She did the most perfect landing mains first, then nose.......
Did puff the battery slightly.......hmmmmmm time to go shopping!!
We have a winner with this one....
Awesome bird....
As if you guys didn't know that already!!!
Steve
Old Aug 25, 2011, 09:45 AM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Thats awesome! Thanks for sharing that. Do you have the retracts on? I haven't flown mine in a couple months since the ESC incident. Please post pics of your retracts when installed if you haven't already.
Old Aug 25, 2011, 07:28 PM
Sydney
Joined May 2007
No retracts yet.... still in the design phase.... the fuselage is very thin where you would normally place the wheel wells.....
Still it can be done... just needs a little more thought...
Yeah she's a real pussycat..... The puffiness in the battery has "deflated" overnight....?? charging up as we speak....
It's another gorgeous and calm bluebird day to go flying!!!
Cheers
Steeve
Old Aug 25, 2011, 08:39 PM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Funny you said that, I just got in from flying. Shame it's starting to get dark around 8:20. I should put lights on my planes.
BTW, how do you feel about installing the retracts (mains) on the wings or do you feel the wings are too thin?
Old Aug 25, 2011, 09:40 PM
Sydney
Joined May 2007
Not At all
I've installed retracts with electric doors on the HET F4 Phantom:
http://www.rcgroups.com/forums/showt...43#post8169392
They are a lot thinner than the J-Power ones... It's the Fuse that's thin... cos' it's right in the intake of the fan unit.... Can be done.... just gotta sit down and seriously do some measurements and see what availableto use ATM. Could get away making a small fairing for the fuselage and narrow wheels.... would still look fairly scale...
Steve
Old Aug 27, 2011, 10:52 PM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
I'll give it some thought. Now it's another project on my long list of projects.
Old Oct 21, 2011, 01:26 AM
Sydney
Joined May 2007
Retract Mod
Well the time has come to modify this bird for retracts....
Wow... not as easy as I thought... nose gear looks a little rough ATM but I'll be reinforcing the area a little later.. right now I just cut the holes and the mains have lined up quite well.
The belly will be painted white after this is done.
The retracts: http://www.hobbyking.com/hobbyking/s...dProduct=15200
Sensational bit of kit these...
And the mounts: http://www.hobbyking.com/hobbyking/s...dProduct=15207
NOTE: I actually shortened one of the oleo legs to match the shorter one. These shorter versions are the mains where the long leg is for the nose.
It's going to look like it's on stilts when complete but unfortunately there isn't much I can do except go to wire legs....anyways....
I'll be making gear doors for both the mains and nose similar to my HET F-4 without the mains inner doors, I'll just allow the bottom of each main wheel to be seen from the belly when retracted. The nose main door will be spring loaded open with a spring hinge, and close with an elastic bungy cord that will close it when the gear is retracted.. (That's the plan)
Here are some pics.
I didn't do many measurements.. I laid the gear out and traced around everything. mains are just forward of the mounts for the standard fixed gear. Only made sure that eveything was even on both sides.
The main wheels are standard with what comes with the retract units. However due to clearance issues with the battery (Yep.. it's gonna be tight) I've used a smaller nose wheel....
This one to be exact: http://www.hobbyking.com/hobbyking/s...dProduct=10879
Now the mains will have small pieces of balsa placed fore and aft of the retracted gear as they sit too high when in position... this way I can make it much more aerodynamically smooth and hopefully quicker!!
It may look a bit more lumpy than the fixed gear equivalent... but I'm hoping to make it as smooth and faired as possible... I'm pretty gun with balsa....!!
The details... each of the main mounts have been sanded about 1/8" off the top of the mounts, so they fit in the pockets I made in the wing. These wings are very thin, so on top of mount being sanded, the retract itself will be spacered by washers to about 1/16" so they sit slightly higher so it won't punch a hole in the upper wing skin.... this way the top of the wing still looks stock and underneath I'll hide all these gaps and spaces with sanded balsa strips and gear doors... make a few fairings for this I will!!!
Hard to picture but stay tuned.... hopefully I can get this done fairly fast.
PS: the main gears oleo struts are rotated like this on purpose... If i rotated them 180 degrees the offset strut will stick out a LOT! So it's not strictly scale in the scheme of things but hey... it's a cheap foamy....
If i fail i've already got this saved in my wish list!!! http://www.hobbyking.com/hobbyking/s...dproduct=16288
Steve
Old Oct 21, 2011, 07:05 AM
pulsery2k1 is online now
Find More Posts by pulsery2k1
6 months to finish a rtf
pulsery2k1's Avatar
upstate ny
Joined Jun 2003
Steve2308
Very nice , I didn't think the wing was thick enough
for them -- but nice job
pulsery2k1 is online now Find More Posts by pulsery2k1
Old Oct 21, 2011, 08:57 AM
will3kgt is offline
will3kgt's Avatar
Grand Blanc, MI
Joined Jan 2007
Awesome work Steve. I was planning on buying anothor airframe....I think I will after looking at this. I bought the other retracts & they just didn't fit.
Old Nov 14, 2011, 04:58 PM
sniper1 is online now
Find More Posts by sniper1
sniper1's Avatar
Crawley Down, sussex, England
Joined Dec 2004
Thought id post some pics of my modified Phantom. Het 2w20 70mm 6904 fan. Shes a challenge to fly with some strange flight characteristics, but im slowley taming the beast!
http://www.rcgroups.com/forums/member.php?u=50704
sniper1 is online now Find More Posts by sniper1
Old Nov 18, 2011, 01:10 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Is that the NP 70mm F4?
If so
Good work
erh7771 is online now Find More Posts by erh7771
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 709 Jan 16, 2008 10:40 PM
AERC F-4 Phantom Building and flying thread! pilatus turbo Electric Ducted Fan Jet Talk 0 Nov 14, 2002 12:44 AM
FS: Factory New AERC F-4 Phantom Taking Pre-Orders Now gbagley Aircraft - Electric - Airplanes (FS/W) 9 Oct 16, 2002 08:50 PM
Great Planes F-4 Phantom greenshirtrwg Fuel Plane Talk 0 Jun 05, 2002 10:25 AM
F-4 Phantom II - First look... Daren Electric Ducted Fan Jet Talk 139 Mar 18, 2002 12:27 PM
