Old Jan 31, 2003, 03:08 AM
Little Black Duck is offline
Find More Posts by Little Black Duck
Little Black Duck's Avatar
Thornleigh - 20k N of Sydney,N.S.W.,AUSTRALIA
Joined Aug 2001
Smaller dia spinners for folding props
G'day all.
Are there any smaller dia spinners than 30mm, with lugs incorporated for folding blades, available as I want to fit a long g/box into a narrow-nosed 2.8m sailplane design and keep the frontal cross-section as small as possible - preferably obtainable in my part of the world?
The g/box has a 1/4"/ 6.2mm shaft with prop driver similar to a small i.c. motor with beam mounts on the shaft housing and the motor mounted in back with reversed polarity and is 3.8:1.
If you're interested go to - www.alphalink.com.au/~mbuck/Publish/page2.html, where there is a picture of this motor/g/box and a link to a reasonably clear diagram with dimensions, as I believe one look is worth a thousand words - and I'm wordy enough - ROTFL.
TTFN - Regards from Oz - Daffy
Little Black Duck is offline Find More Posts by Little Black Duck
Old Jan 31, 2003, 02:35 PM
flight999 is offline
Find More Posts by flight999
flight999
England
Joined Dec 2002
HMV do spinners and hubs from which you should be able to get a fit.
Don't know about you part of this planet, but here in Europe:-
Hoellein
Gordon Tarling
Steve Metam
all should be able to help.
flight999 is offline Find More Posts by flight999
Old Jan 31, 2003, 02:40 PM
flight999
England
Joined Dec 2002
Sorry. nothing locally.
In Europe try:- HMV
via:- Steve Metham (Electric aeroplane Co.)
Gordon Tarling
Der Himmlische Hoellein
Old Jan 31, 2003, 04:04 PM
Joined Aug 2001
Thanks for the info.
Will get Gordon Tarling's and Steve Metham's ctcs from Q&EFI and take it from there.
Just as a matter of interest did anyone take a look at the site I noted earlier?
Rgds from Oz - Daffy
Old Jan 31, 2003, 04:09 PM
Joined Aug 2001
Old Jan 31, 2003, 07:34 PM
Lance is offline
Find More Posts by Lance
I hole jumped him!!!
Lance's Avatar
United States, TX, Plano
Joined Dec 2001
here's an option
Daffy/Dave (yet another Dave!)
I tried the link, but it didn't work. As far as spinners, try Dave at aircraft world www.aircraft-world.com for a 26mm spinner. I have two of them, and run one on my navajo glider. Check folding props, then spinners and yolks, it's near the end of the list (he's got a lot of them). I think dymond also makes some small folding prop spinners...I've got one. I can get a pic if you want.....
Lance
Lance is offline Find More Posts by Lance
Old Feb 05, 2003, 06:23 AM
Joined Aug 2001
Thanks Lance
Sorry for delayed reply
To access the site I gave you earlier just type: web 8 in the addr bar as I found that the long addr didn't work either.
I've tried a couple of links to various suppliers - here and o/seas to find a suitable small dia spinner to no avail - so it looks like I'll have to fabricate a special spinner shell by vac-forming or something similar and fit it over a prop pivot bar of the right size
Smallest spinner dia I can fin to suit a 600 motor/g-box combo is 29mm - still too big !!
Ah well - them's the breaks.
Rgds - David
Question Using Big Spinners for Folding Props on Scale Aircraft Bosk Power Systems 2 Mar 31, 2007 04:36 PM
What spinners for APC props? Coder Power Systems 2 Jul 14, 2003 08:37 PM
Purpose of twisted offset yokes for folding props? planekrazy High Performance 9 Apr 22, 2003 07:29 PM
FS: "NEW" Lite Spinners & Folding props 50% off rck Aircraft - Electric - Airplanes (FS/W) 11 Mar 10, 2003 09:27 PM
spinners for folding props Woodi Electric Plane Talk 3 Jan 20, 2003 10:15 PM
