| Rotorspan: | 340 mm / 13 3/8" |
| Weight: | 230 g / 8.25 oz. |
| Length: | 435 mm / 17 1/8" |
| Servos: | micro |
| Transmitter: | 4 channel 72 MHz |
| Receiver: | Piezo electric flight stabilization |
| Battery: | 7.4 volt 800 mAh LiPo |
| Motor: | Twin brushed |
| ESC: | 4 in 1 with gain and portioning |
| Available from: | Hobby Lobby |
| MSRP: | $119.00 |
The big, colorful, easy to fly Coast Guard edition of the Twister Helicopter comes with everything you need to successfully fly a helicopter. The features don’t stop there, though: it includes a downloadable flight simulator, low battery warning light, motor overload protection, a 4-in-1 on board 6 channel receiver with Piezo electric gyro, mixers and speed controllers, safe start and fail-safe plus all the extras.
As soon as you receive the package you can tell this is a great quality product. There is a sticker on the outside of the box that clearly states that the helicopter has been flown and tested so it is ready to go.
Mine arrived with no damage, and refreshingly little or no plastic was used in the packaging. It appears to use recycled paper for the molded containers.
The kit is complete with many extras. First, the helicopter is fully assembled.
You also get all the necessary support items.
The kit includes
Kit requires
The only assembly is the addition of the tail, and this is more of a cosmetic addition. The tail rotor is attached, but I suggest you use some thread lock and lightly attach the rotor so it spins. A longer screw would allow more security. The elevator slips into place.
The rotors come off via two screws, one on each side of the rotor. The fly bar pops off with a slight twisting motion. In most accidents, this will come off so be on the lookout.
I thought I would take the body off and provide readers a better look inside. After removing the rotors you have to gingerly flex the body and spread the opening to get the chassis out.
The rotors are driven by two motors and their corresponding rotor gears from the underside of the chassis.
The rotor shaft swash plate is plastic and is connected to the servos in a 120 degree separation.
Once removed, the body is a very flexible and lightweight plastic. The interior uses the foam tape to secure wires to the sides of the fuselage.
The receiver is ready to go.
To complete the Twister all that is needed is to make sure your controls are correct. The instructions provide all the details for recognizing the movements of the swashplate. There are also instructions for Mode 1 and Mode 2 transmitter setup. I suggest you read through the instructions as they provide some good advice for your first flights. The instructions begin with a discussion of how helicopters fly and familiarize you with the stick movements and associated helicopter responses.
Training is detailed and begins with one of the best pieces of advice I can think of: Find plenty of room to fly! To begin, you are instructed to keep the helicopter on the ground. You quickly understand that watching the nose of the helicopter helps to correct yaw movement with your control inputs. You also learn to realize that ground effect influences flight. Following the flight training, you learn to walk the helicopter around on the floor and then begin to transition to hopping prior to hovering. I thought the sequence was well written and will help any new helicopter pilot.
I struggled with the download of the FMS simulator. I was not sure of which version I needed, and I chose the version 2.0 Alpha 8.5. I was able to get the fixed wing aircraft to work, but not the rotorcraft. I also tried to download the Blackhawk from another listed site, but that was in a foreign language. I was redirected to another foreign site, but never got the download. A corrected and updated link should be provided on the Hobby Lobby website or the software should be included.
You begin the process by turning on your transmitter, placing the Twister on the ground and plugging in the battery. You will see I have the battery routed through the window so I could place the helicopter on the ground in the correct position for the gyro and heading fix. The video shows the helicopter on its side and plugged in from the bottom, but my experience has been to make sure the helicopter is sitting as you want to fly it when you plug it in.
I had no problem flying the Twister. I did need to dial in some yaw control as my trim for the rudder was maxed out, and I was still fighting the torque. A very slight adjustment moved the trim back to center so I had more control. You will be constantly adjusting your trims, and you will at times feel like it is perfectly dialed in and at other times using the same settings it will seem slightly off, so don't be afraid to make some trim adjustments. You may find it is easier to settle to the ground to make the adjustments.
This bird is very durable. On the maiden flight I thought I had the battery charged, and while in the pattern on the second trip around the battery gave out. The light was bright outside and I could not see the warning lamp lit on top of the canopy to tell me the battery was low, and out of the sky it fell maybe 40 feet right on the nose. Well I don’t think you can see any of the damage in the video as it was slight even for such a long fall. The airframe, motor mounts, battery holder, rotor shaft and even the body faired really well. I did not even break a rotor.
The Twister is really easy to control. I found no tendencies for it to misbehave. Once I had it trimmed I could hover and fly the pattern with no problem. The gain adjustment on your 4-in-1 receiver is for stabilization, and you most likely will not need to make any adjustment here. The factory setting is at 90%.
The Twister lifts off at about one quarter throttle and has plenty of power to work with. Landing is much more difficult than taking off, which is as expected.
This helicopter does not have any aerobatic capabilities.
Yes it is! Practice will make you very proficient, and the extremely long flight times on the 7.4 volt LiPo will keep you flying long enough to learn.
Having the opportunity to fly the Twister Coast Guard edition just reinforced my liking of helicopters and my desire to get better at flying them. I felt I was always in control and outside of ground effect, the Twister was very stable and consistent.
Pluses:
Minuses:
| Thread Tools |
The CX is proving quite popular..thanks for the review!
Latest blog entry: A good watch...
Looks very like a CX mechanic. I wonder if a spektrum 6100 receiver could be installed so the heli flies on 2,4 ghz ? On the blade the receiver and the gyro are two units but in this one it seems they are one.
Has anyone tried ? Carguy |
Latest blog entry: Mystery summit FPV adventures
Just bought a CX2 and looking at the pictures it is the same machine except for some aluminum part on the head and the 2.4 ghz ar6100 receiver on the blade. So I guess e-sky just makes all of them and they are sold under different names.
Anyway they are fun machines ! Carguy |
| Thread Tools | |
| Article Hobby Lobby's TB-20 Brushless RTF Park Flyer Review | dawnron1 | Parkflyers | 357 | Dec 16, 2011 08:14 AM |
| Article Hobby Lobby's Pitts Bipe RTF Biplane Review | sun.flyer | Parkflyers | 436 | May 02, 2010 02:18 AM |
| Article Hobby Lobby's Honey Bee II Micro Heli RTF Review | Stocker | Micro Helis | 22 | Jul 27, 2009 12:05 PM |
| Discussion Twister Skylift, Coast Guard & Hawk now in US | RCScaleModel | Coaxial Helicopters | 6 | Jun 24, 2008 09:23 PM |
| Article Hobby Lobby's SkyGo Beginner's RTF Review | Stocker | Electric Plane Talk | 32 | Dec 31, 2007 02:38 PM |
