Old Jul 17, 2008, 10:53 AM
scratchwerk is offline
Find More Posts by scratchwerk
hmm, I could modify that
scratchwerk's Avatar
flyover country
Joined Dec 2007
Question
3 Blade head set up
I need some info on 3 blade head setup. I'm looking at getting a HBK2 and installing a 3 blade head from here..rc-expert
Is working with a multi blade head that much different than a 2 blade+flybar?
What do I need to consider? Will the heli be more stable?
scratchwerk is offline Find More Posts by scratchwerk
Old Jul 21, 2008, 11:11 PM
flyover country
Joined Dec 2007
Anyone???
Old Jul 22, 2008, 08:41 AM
Super_Hornet is offline
Find More Posts by Super_Hornet
Singapore
Joined Jan 2004
Configure multibladed are actually quite straight forward. It does not matter it is 2,3,4,5,6 or 7 blades, u always use one blades as the reference.
In normal configuration, the linkages from swash plate to center of the blade grips are in 90Degree. In other word, 90Degree phasing. The linkages "Lead" the blades grip by 90Degree.
In flybar+paddles configuration, there is actually an mechanical gyro (that is the flybar + weight. The weight is actually from the paddles itself) that provide the auto stability to the heli.
In multibladed, u do not have the flybar+paddles... thus u lost that auto-stability. To make the heli stable, u use any one of these or a mixture of these:
1. Weighted tip or heavy blades.
2. Normal Gyro + eCCPM Mixer. If your heli is mCCPM, then u do not require eCCPM Mixer.
3. Auto-pilot kind of devices
4. Those V-Bar, VStabi and etc stuff.
SH
Super_Hornet is offline Find More Posts by Super_Hornet
Old Jul 23, 2008, 11:47 PM
flyover country
Joined Dec 2007
Thanks SH.
Old Jul 24, 2008, 11:54 PM
Jcopter is offline
Find More Posts by Jcopter
Jcopter's Avatar
United States, CA, Downey
Joined Jun 2005
The key is weighted rotor blades
This is the most important thing to get you blade weighted correctly
Jcopter
Jcopter is offline Find More Posts by Jcopter
Old Jul 27, 2008, 10:53 AM
flyover country
Joined Dec 2007
How do you weight/balance them? Do you put weight at the tips, or do you weight the whole blade? How do you know how much weight? Trial and error?
Old Jul 27, 2008, 05:31 PM
K2-tokyo is online now
Find More Posts by K2-tokyo
Tokyo Setagaya-Ku, Japan
Joined Jun 2004
Hi,
Concerning the blade balance: Find the heaviest blade. Then, take a balance
between another blade and the heaviest blade like a seesaw by adding some tape
to the tip of another blade.
K2-tokyo is online now Find More Posts by K2-tokyo
Old Jul 29, 2008, 11:32 PM
flyover country
Joined Dec 2007
Thanks K2.
Blade 2MC set Up ?? Chuckhead1 Slope 14 Jan 19, 2006 02:41 AM
helihobby cnc collective pitch head set up the agent Micro Helis 4 Jan 31, 2005 03:28 AM
EP 10 head set up? NickT Electric Heli Talk 1 Apr 14, 2004 08:12 AM
Anyone Got Eolo Head Set Up Pictures? Bourbon Electric Heli Talk 0 Oct 21, 2003 11:16 PM
Best 3 cell IPS set up for mini IFOs? Nowell York Power Systems 8 Aug 18, 2003 10:41 PM
