Old Jul 17, 2008, 09:03 AM
dash8pilot is offline
Find More Posts by dash8pilot
United States, AZ, Queen Creek
Joined Dec 2007
SU-35 or any twin EDF with thrust vectoring
Anyone here experimented with an EDF SU-35 (or any twin EDF) using thrust vectoring nozzels? I figure that with tail flaperons, it would be a fairly straight forward modification to extend the control linkage for nozzel control....that way each nozzel would only rotate around one axis for pitch and roll control. Vectored rudder control would be the challenging part, but could be done by programing my DX7 with counter thrust (not very effective on my GWS A-10 though). Curious if anyone out there has contemplated this idea in an EDF.
I've seen the profile foamies and turbine OVT options, but I'd like to try this in the EDF arena.
Clint
dash8pilot is offline Find More Posts by dash8pilot
Old Jul 18, 2008, 08:12 AM
Bobber Bob is offline
Find More Posts by Bobber Bob
Kat Builder
Bobber Bob's Avatar
Bellflower, Calif.
Joined Apr 2004
Hi Clint...
I used a twin ducted fan system mounted on the elevons of a swing wing TomKat, and it was a lot of fun with the increased control in the pitch and roll modes, but, of course, they were not any help in the yaw mode.
Bob Reynolds
. "ComeUpHere"
Bobber Bob is offline Find More Posts by Bobber Bob
Old Jul 18, 2008, 08:21 AM
Joined Dec 2007
Got any pictures
Bob,
Would you happen to have any pictures of your work...lookin to drum up some ideas to make this work and a picture works the best. Thanks.
Clint
Old Jul 18, 2008, 11:50 AM
cray2602 is offline
Find More Posts by cray2602
Fan-atic
cray2602's Avatar
Plain ole KS
A few guys are experimenting with thrust vectoring on their SU-27 EDF twins in this thread http://www.rcgroups.com/forums/showt...7#post10169629 . One has had a few flights on his setup and claims it works very well.
cray2602 is offline Find More Posts by cray2602
Old Jul 18, 2008, 06:53 PM
Andrew McGregor is offline
Find More Posts by Andrew McGregor
Christchurch, New Zealand
Joined Jun 2006
Take a look at how the real SU-35 does it. You don't need the variable size nozzles, of course, but Sukhoi only pivot the nozzles on one axis. The trick is, the axes are turned inward at almost a 30° angle, which gives them much more roll moment. You could do the same thing with vanes on an EDF, or you could move the whole nozzle.
No, I haven't done this myself, but my next project is a parkflier '35, so I will be going there soon.
Andrew McGregor is offline Find More Posts by Andrew McGregor
Old Jul 18, 2008, 08:05 PM
Kat Builder
Bobber Bob's Avatar
Bellflower, Calif.
Joined Apr 2004
Hi Clint...
Always glad to share some of my work !!! I am more of a gadgiteer, then I am a builder (more function then form).
I developed a line of swing wing TomKats, ranging in size from 16" to 42", and in weight from 1/2oz to 16oz, and single and twin, using mostly GWS 30 and 40mm fans.
I tossed in some background pictures before the "vectored" one...
Bob
. "ComeUpHere"
Old Jul 19, 2008, 12:24 AM
Joined Dec 2007
Very cool BB
Great stuff BB....do you get a wicked center of pressure change from WOT to cut-off? Same consideration with the swept wings changing from spread to swept. How does it perform power-off?
Andrew....not looking to shape the nozzel. Just want to direct the thrust with a single axis gimble mounted cone....I'm looking to do something fairly basic in design.
I've looked around on google, rc sites, etc. and havent found much out there along the lines of this interest....anyone come accross anything scale (non profile) EDF thrust vectoring in nature?
I did find this.....
EDF thrust vectoring (0 min 27 sec)
I'm looking for minimal servos so a single gimble should work fine, connected to the elevons. Thoughts?
Clint
Old Jul 19, 2008, 12:49 AM
Joined Jun 2006
Well, something like that with the scale pivot alignment should work just great. I can't find a picture right now, but the nozzle pivots are turned inward by 16° on each side (so when you pull up, the nozzles converge). You could do that by linking the nozzles to the servo with their own linkages to allow the different angle of rotation. I gather the reason they did this was to give an automatic yaw moment with roll.
Old Jul 19, 2008, 01:17 AM
Joined Jun 2006
Wow: http://www.rcgroups.com/forums/showthread.php?t=808482
Old Jul 19, 2008, 08:20 AM
Kat Builder
Bobber Bob's Avatar
Bellflower, Calif.
Joined Apr 2004
Hi Clint...
The thrust line of the EDF's placement on all of my designs is on the center of drag line, so there is very little, if any, trim change with power variations.
The wings center of pressure change was solved by NASA, and Grumman. NASA found that if the wing's pivots where about i/3 of the extended span apart, a full flying elevator would handle the trim changes without undue drag penelty.
Gruman found out that the placement of the hortz stab below the wing, would pick up a down load, as the wings swung aft, taking care of most of the trim change needed, automatically.
And that all works very well at model scales, at least it does for me. The trouble with a lot of the model swing wing aircraft, is they are designed by power plane pilots, so the CG is always located TOO far fwd.
Us Glider Guiders, know the benifits of a more rearward CG, for controllability and efficiency (the plane flies "lighter", less down load on the tail to be carried by the wings).
Bob
. "ComeUpHere"
Old Jul 19, 2008, 08:55 AM
Joined Dec 2007
Andrew....thats an incredible link, thanks. 3 servos is the way to go, but I like your idea of altering the gimble throw (yaw direction) to get the desired effect....you could simply make a set of slightly angled guide tracks to mix yaw in with pitch....maybe have it on an adjustable mount IOT make small tweeks on the ground.
BB...great stuff. I learn something new everyday in this hobby.
Clint
Old Jul 21, 2008, 07:32 AM
New Yorker is offline
Find More Posts by New Yorker
Electric Advocate
New Yorker's Avatar
big Apple
Joined May 2008
Figure skating in the air
Clint
TV is awesome! Hanging in the air, sudden 180 turn...
Here's http://www.rcgroups.com/forums/showt...7#post10167823
New Yorker is offline Find More Posts by New Yorker
Build Log X-31 EDF Park Jet with Thrust Vectoring System jetset44 Foamy EDFs 427 Jun 29, 2014 10:00 AM
Wanted Looking for an EDF SU-35 with thrust vectoring dash8pilot Aircraft - Electric - Jets (FS/W) 0 Jul 15, 2008 07:24 PM
Build Log Mig-35 Twin EDF w/ Thrust Vectoring tailslide5_0 Foamy EDFs 23 Aug 27, 2007 09:20 PM
Video X-31 EDF Park Jet with Thrust Vectoring System jetset44 Electric Plane Talk 4 Apr 25, 2006 02:24 PM
Idea Mr. Boogies JSF F-35 with thrust vectoring tow Electric Ducted Fan Jet Talk 26 Jan 16, 2006 07:45 PM
