Old Jan 30, 2003, 04:47 PM
St. Louis, MO
Joined Oct 2002
E-Flite Maxx 25 ESC how many servos can this thing handle
I have a E-Flite Maxx 25 ESC from a Electrajet that crashed and I want to use in on another plane. Does anyone happen to know how many servos this ESC can handle running? I would like to put 4 servos.
KenP is offline Find More Posts by KenP
Old Jan 30, 2003, 05:01 PM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Alot is going to depend also on how many cells and what type of servos. Many BEC setups are rated at 1-1.5 amps.
If the surfaces and linkages are very free and you use good servos (like Hitecs) and you keep the cells to 8 or less with good ESC cooling. Testing the servos under load is a good idea, trying to keep the load less than 1/2 the BEC output.
You also don't want to use a servo that is to small for the job, but not to heavy either.
4 servos should be OK if you keep the above in mind.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Jan 30, 2003, 05:02 PM
St. Louis, MO
Joined Oct 2002
Cool
I was planning on a small dual 280 plane using 4 HS55 servos with 7 cells.
Thanks.
how many servos can a receiver handle? schaubro Radios 2 Jan 07, 2005 10:51 PM
How many servos can I run off a TMM 40e-3ph controler ? RandyK1 Power Systems 5 Jan 01, 2004 12:20 PM
E-Flite Maxx 25 ESC $21 shipped Peter Khor Aircraft - Electric - Airplanes (FS/W) 3 Dec 06, 2003 09:40 AM
E Flite Maxx 25 ESC Tom Korn Electric Sailplanes 2 Sep 16, 2003 07:56 PM
How many servos can I use with a Pixie 20 ESC? try2fly Foamies (Kits) 3 Feb 15, 2002 03:43 PM
