Old Jul 16, 2008, 04:09 AM
konaboy is offline
Find More Posts by konaboy
Sweden (born UK bred Wales)
Joined Aug 2002
Help!
How best to repair EasyStar broken tail fin?
Hi!
I store my EasyStar suspended from the garage ceiling which seemed to be a safe place.
However, when taking out a ladder I whacked it up against the roof and broke the tail fin (vertical stabilizer).
Can anybody suggest how to repair and reinforce the damage?
I do have some CA glues, I attached a photo. Are these safe to use?
thanks in advance.
konaboy is offline Find More Posts by konaboy
Old Jul 16, 2008, 06:03 AM
Jurgen Heilig is online now
Find More Posts by Jurgen Heilig
Jurgen Heilig's Avatar
53859 Niederkassel, Germany
Joined Sep 2000
Just glue it back on with the CA you've got, they are safe for Elapor. I don't see a need for additional reinforcements.
Jürgen
Jurgen Heilig is online now Find More Posts by Jurgen Heilig
Old Jul 16, 2008, 03:08 PM
MumblinBerk is offline
Find More Posts by MumblinBerk
Tree Fodder
MumblinBerk's Avatar
Mount Holly Burlington, New Jersey, United States
Joined Sep 2004
Yep. Should be fine. Use the "THIN" one. Do yourself a favor, do the repair before going to bed, and let it cure over-night before flying it.
-mb
MumblinBerk is offline Find More Posts by MumblinBerk
Old Jul 16, 2008, 03:34 PM
konaboy is offline
Joined Aug 2002
cool. I thought that would be the way to go. Thanks for the confirmation guys!
Old Jul 16, 2008, 06:45 PM
Ledbetter is offline
Find More Posts by Ledbetter
Central California
Joined Aug 2003
Glue a toothpick in for support. Make SURE it's vertical when it dries.
Ledbetter is offline Find More Posts by Ledbetter
Old Jul 17, 2008, 03:15 PM
konaboy is offline
Joined Aug 2002
Seemed to be a success. Didn't use a toothpick as it wasn't a total break the tail was still hanging on by a few mm of foam. By trying to insert a pick I would probably have broken it clean off.
It's not a precise 90% vertical. Even by eye I can see it's slightly off. It could have been this way from the beginning though due to the imprecise nature of foam.
I intend to make a brace using a piece of dental floss/lightweight kite line. I will attach it to the end of the horizontal stab, up to the top of the fin and then down to the other end of the stab. THe line will be taught and held in place with a dot of CA.
I have used this technique to stiffen up my "slow stick" tail with success and you can use it to make small adjustments to the angles.
By the way that thin CA wicked right through the foam and stuck the bottom of the plane to a concrete wall that i was gluing on. It was a tough job to get it free. Good job my hand wasn't underneath. Scary stuff CA.
Old Jul 19, 2008, 09:13 AM
rcairplains is offline
Find More Posts by rcairplains
im afraid it will never be structual sound again, it might fail in flight causeing destruction and injury to private property,animals an people, the best thing would be to box it up and ship it to me, where ill properly dispose of it according to FAA rules. but if you must fly it...HAVE FUN!!!!
rcairplains is offline Find More Posts by rcairplains
Idea Quick Fix For Broken Tail Fin cheez Micro Helis 2 Nov 06, 2007 10:32 AM
Discussion how best to repair this ( easy glider) grayzeee Foamies (Kits) 3 Feb 18, 2007 09:46 AM
How to strengthen Corona tail fin tocano Electric Heli Talk 49 Feb 23, 2005 11:36 PM
Best way to repair a broken balsa wood motor mount??? rcwyant Parkflyers 13 Jul 30, 2003 09:13 AM
Need help! Broken tail fin and boom gamehaus Hand Launch 1 Feb 04, 2003 11:27 AM
