Old Jul 15, 2008, 03:10 AM
bloberts is offline
Find More Posts by bloberts
Joined Apr 2007
60 sized hovercraft
hi this would be my second prodject if i can build a 60 size hover craft
i have an old mds 60 engine arrould i was wondering on dimentions for a craft or could i do any and hope for the best?
bloberts is offline Find More Posts by bloberts
Old Jul 15, 2008, 06:54 PM
challenger_i is offline
Find More Posts by challenger_i
OCD: Old, Cranky and Disgusted
challenger_i's Avatar
United States, TX, Fisher County
Joined Mar 2005
Several years ago, I built a ground-effect vehicle using a K&B .60 and 12x6 prop. I used anything at hand, as I was just tinkering. The duct was a cut-down 5 gallon bucket, and the base deck was 1/4 plywood, measuring 24x36. Skirt was cobbled up from polyester dress lining. Forward propulsion was two blast tubes, made of paper towel tubes. The beast weighed 7 pounds, and would pop off the ground at 1/4 throttle.
Using better materials, and a better design, I believe you could build an impressive HC.
challenger_i is offline Find More Posts by challenger_i
Old Jul 16, 2008, 05:22 PM
zagimon is offline
Find More Posts by zagimon
Patrick Jenkins
USA, LA, 5
Joined Dec 2006
Nice idea. Ducted/Paint bucket
zagimon is offline Find More Posts by zagimon
Old Jul 16, 2008, 05:30 PM
Joined Mar 2005
I was bored, broke and used what was at hand. It was built upon the plans Roy Clough published in 1960, in Popular Mechanics. His was a tethered .020 ship. Needless to say, mine was rather bit larger...
Old Jul 18, 2008, 12:59 PM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
I had a 60 size hovercraft kit back in the 70's. IIRC it was about 2 feet wide, and less than 4 feet long. The engine was mounted 30 to 45 degrees up from straight forward and half the prop thrust inflated the skirt and half went out through 5 parallel rudders.
There was a clamshell that came down and provided reverse thrust.
Sorry no pictures.
Majortomski is offline Find More Posts by Majortomski
Old Jul 21, 2008, 03:01 AM
bloberts is offline
Joined Apr 2007
cool ill give it a go with those diamentions worst case it wont lift
Old Jul 24, 2008, 09:04 AM
Airboatflyingshp is offline
Find More Posts by Airboatflyingshp
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Use Blue foam and/or Correx as the SPAD builders do and it will be strong light and waterproof correx is also fuel acid alkali and cold and fire ressistant. Just close up the exposed ends of the corrugation tubes to stop water ingress.
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Old Feb 26, 2013, 09:15 PM
simz is offline
Find More Posts by simz
enter a new realm.....
simz's Avatar
Joined Dec 2012
test
simz is offline Find More Posts by simz
Old Oct 30, 2015, 10:58 PM
Captnpauley is offline
Find More Posts by Captnpauley
Joined Oct 2011
.60 sized RC Hovercraft kit
That kit you built back in the 70's was my XR-1 Cyclone hovercraft. I posted a video under vintage hovercraft...
Captnpauley is offline Find More Posts by Captnpauley
DNHP makes a 60 sized electric! Ben74 Electric Heli Talk 12 Jan 03, 2003 08:49 AM
Yippee! FS: Ready to fly .60 sized "militarized" GP Piper J3 Cub Pilot_Tony Aircraft - Fuel - Airplanes (FS/W) 0 Oct 08, 2002 09:15 PM
Great Planes 60-sized Extra Conversion SoarNeck Sport Planes 6 Aug 29, 2002 12:08 AM
What's the best brushless system (motor/controller) for .40 to .60 sized sport planes rsieminski Power Systems 8 Jan 27, 2002 09:54 PM
