Old May 10, 2009, 09:16 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Thanks, Rick. I must have missed that somehow.
Regards,
Target
target is offline Find More Posts by target
Old May 10, 2009, 03:21 PM
mlee8249 is online now
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Rick,
Thanks for the assist!
I was thinking about what Smokin' Joe said about having to be current. Well, if you're going to be "Jones-sy" with the fast crowd that's really a poor perception of what to do. There are many very good aircraft designs now available, all of which can win a contest on any given day with the right pilot behind the transmitter. You don't have to be current to win or even be competitive. A foamie won the Rose Bowl one year and I beleive a Duck has won the AMA Nats within its' class more than once. I didn't see pilots scrambling to buy a foamie nor a Duck when that happened. I have always been of the opinion that if what you fly does not deliver the performance that you demand and are capable of using, then by all means, upgrade. But if you simply think that having the latest and greatest model will win a contest for you, then think again. You have to know how to use that tool to make the tool work for you. Based on that theory of mine, I say that having the original version Xplorer is no handicap, by any means. It remains one of the most potent airframes in the arsenal.
mlee8249 is online now Find More Posts by mlee8249
Old May 10, 2009, 03:53 PM
SHVentus is offline
Find More Posts by SHVentus
Hawaii
Joined Feb 2009
OMG, now an Explorer 4000:
http://www.nanmodels.com/
Can the 5000 be far behind?
SHVentus is offline Find More Posts by SHVentus
Old May 10, 2009, 04:24 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Looks like the X4000 has a 120mm (4.75") longer fuse, while the 3800 shares the same fuse with the 3.5M original.
Target
Old May 10, 2009, 06:10 PM
Tappet is offline
Find More Posts by Tappet
Crestview, Florida
Joined Dec 2005
Ok, ok.....
if it's span you want..... leskycomposite.at
Tappet is offline Find More Posts by Tappet
Old May 10, 2009, 08:05 PM
webbsolution is online now
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
X 4000
wow 4 meters, hrm, not sure I can dip into the funds for a new model for the extra .2 M ...
is the airfoil the same?
webbsolution is online now Find More Posts by webbsolution
Old May 10, 2009, 08:40 PM
seanpcola is offline
Find More Posts by seanpcola
ein flugel schplinterizer
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
I'll admit to being lazy tonight but can you guys chime in on what you settled on for CG without me going back through the whole thread?
I have one I need to finish by Wednesday and just need a close starting point.
Thanks in advance,
Sean
seanpcola is offline Find More Posts by seanpcola
Old May 10, 2009, 09:01 PM
ACooper is offline
Find More Posts by ACooper
Banned
ACooper's Avatar
USA, NJ, Wantage
Joined Jul 2008
Thanks in advance,
Sean
Started @ 105 and settled @ 108
ACooper is offline Find More Posts by ACooper
Old May 10, 2009, 09:16 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I'm at 108mm.
T
Old May 10, 2009, 09:47 PM
Joined Jul 2007
Originally Posted by target
I'm at 108mm.
T
106 early morning- then I change canopies with some lead under the afternoon canopy for 108.
DW
Old May 10, 2009, 09:55 PM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
CG Location for Xplorer
I started at 108 and have not felt any reason to change it as it flys great there. Also can put either set of ballast and not change it at all.
See Ya,
Pat
Thanks in advance,
Sean
pmccleave is offline Find More Posts by pmccleave
Old May 11, 2009, 05:59 AM
seanpcola's Avatar
USA, FL, Pensacola
Joined Sep 2004
Thanks folks!
Sean
Old May 12, 2009, 03:07 PM
Led Zeppelin is offline
Find More Posts by Led Zeppelin
Led Zeppelin's Avatar
Toronto, Canada
Joined Mar 2008
standrd vs' electric
Folks, how does the 3.5M standard Xplorer compare to the electric version? How does the added weight from the power sytem affect the thermaling of the electric version? I hesitate which version to opt for? Is there a thread dedicated to electric Xplorers?
Led Zeppelin is offline Find More Posts by Led Zeppelin
Old May 12, 2009, 03:36 PM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
Ok I like it. I had my maiden this afternoon around 12 noon. Its a great day out with 5 knots of wind. I did a range check and got 120 paces and thought that was good enough. I hand tossed it and tried the flaps. Ineeds a lot of elevator comp for full flaps. I did 2 tosses and was gonna break out the zip starter. As Im sitting there I feel a thermal come thru. I stepped on the fiels and threw into it and specked out. Now thats a good way to start out the maiden. I land take a break and wait for a few guys to fly. They land and I see some barn swallows at about 70 feet just east of the field. Grab the Xplorer and throw into it again and thermal out.
I didnt even need the zip starter. 2 good flights and I called it the day. I needed to come hoime and beat the kids when they got off the bus.
The DLG stuff really pays off. My arm is a little sore from throwing hard into the 2 thermals but well worth it.
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old May 12, 2009, 05:25 PM
SHVentus is offline
Hawaii
Joined Feb 2009
Goinav8n,
How bad were the kids, that you had to beat them as soon as they got off the bus?
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
