Old Apr 15, 2009, 09:44 PM
Ezza is offline
Find More Posts by Ezza
DS= -$ & :-)
Ezza's Avatar
Byron Bay, Australia
Joined Feb 2006
Originally Posted by Francesco
On a friend's Xplorer I noticed that the joiner boxes are significantly "deeper" (about 15 cm) than the joiners themselves (7 cm). Can you confirm this observation? Do you think that having that much empty space may result in a weak spot? I am asking this because two days ago I witnessed a structural failure upon launch in the joiner box of the center panel of my friend's Xplorer, and I am trying to trace down the cause.
TIA,
Francesco
Thanks Francesco,
I would like to hear comment on this as well.
Measured my dbox version. Centre panel joiner box, is 140mm deep. On the tip panels, the joiner boxs' are 115mm deep. The joiner only extends 75mm into each box? Anyone know if this creates a weak point?
You also have to be careful to get the centre of the joiner, lined up, whilst assembling or there could be alot of stress on the joiner box.
Eric
Ezza is offline Find More Posts by Ezza
Old Apr 15, 2009, 10:00 PM
ClayH is offline
Find More Posts by ClayH
ClayH's Avatar
92840
Joined Mar 2003
It's always a good idea to mark the top centerline of your joiners. I also put an arrow on the tip side of the joiner pointing towards the tip, and mark them left and right. Silver magic marker works good for this. Lastly, to avoid stressing the joiner box during assembly, always install the joiner into the tip first then into the center panel. On some planes it doesn't matter as much as others, but it makes a difference on the Xplorer!
Clay
ClayH is offline Find More Posts by ClayH
Old Apr 15, 2009, 10:03 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by SmokinJoe101
Target,
I will help you get on the TD fast track No need to learn the hard way,
I will share some of my secrets and tips, you open Friday?
sj
Yup!
T
target is offline Find More Posts by target
Old Apr 16, 2009, 02:21 AM
Francesco is offline
Find More Posts by Francesco
Francesco's Avatar
United States, CA, Mountain View
Joined Apr 2001
Originally Posted by target
Was it a D box, or an all carbon Xplorer?
I can measure for you.
T
Hi target,
it was a D-box centerpanel.
Francesco
Francesco is offline Find More Posts by Francesco
Old Apr 16, 2009, 07:10 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Francesco-
Hello, and thanks.
While working on my center panel last night, I casually stuck a pencil in the joiner box, and it is in fact much longer than the joiner.
I don't know that this is a bad thing though; I would think that it would need to be a bit longer.
Target
Old Apr 16, 2009, 07:15 AM
Francesco's Avatar
Joined Apr 2001
Francesco-
Hello, and thanks.
Whils working on my center panel last night, I casually stuck a pencil in the joiner box, and it is in fact much longer than the joiner.
Target
Thank you for trying, target. My concerns about the joiner box length is that there would be a strong discontinuity as for the ability to take bending load between the first 7 centimeters, the following 8 centimeters, and the remaining part of the wing, thus creating possible failure points.
Old Apr 16, 2009, 09:59 AM
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
Francesco-
Hello, and thanks.
Target
Yes, it is a bad thing but easily corrected with longer joiners or fill the joiner box.
Just add this to the X mod list, BUT still shorter than the Supra's mod list.
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Old Apr 16, 2009, 10:06 AM
ClayH is offline
ClayH's Avatar
92840
Joined Mar 2003
I suppose you could glue a wooden dowel in the center panel joiner box to take up the additional space - easy fix.
Clay
Old Apr 16, 2009, 10:08 AM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
No it does not have to be a negative thing to have a longer joiner box. Some of the earlier days F3B models had full span joiner box for ballast.
Actually it would be a very good thing to have space for a little ballast in the joiner box. In turbulent conditions some models with light tips would like ballast out there.
jojoen is offline Find More Posts by jojoen
Old Apr 16, 2009, 10:12 AM
Joined Jan 2004
JoJo.
Tell that to Francesco's Buddy
sj
Old Apr 16, 2009, 11:54 AM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
JoJo.
sj
Off course there can be a problem on his model. Or maybe the failure came for another reason? There must be more to the story here.
If a wing fuse goes in two pieces on a landing is it a poor constructed fuse or a hard landing? You will have to see the landing to know or not?
I just say that a long joiner box does not mean a weak spot.
We should atleast learn how it was damaged and in what way.
Maybe the joiner box was not well wrapped or glued in the wing? One should be able to tell by looking or take it apart.
I would send it to the producer and tell what happened. then hope for a new piece or a good price on a new one.
Old Apr 16, 2009, 04:00 PM
Francesco's Avatar
Joined Apr 2001
Thank you for the insight, Jo.
I'm pretty sure the producer will be able to sort out the matter and replace if applicable, I just wanted to ask the community to see if the "box length" matter was present in other models. It is also worth mentioning that I do not blame by any means this to be the cause of the mishap, I'm just curious and I'm investigating.
Old Apr 16, 2009, 04:26 PM
lineofsight is offline
Find More Posts by lineofsight
Chris Lee
United States, MO, St. Louis
Joined Oct 2005
I have seen the inside of two Xplorer joiner boxes. The joiner boxes (both center panel and tips) are composed of carbon tow wrapped around a joiner form. This box is then epoxied in between the carbon spar caps with end grain balsa continuing where the box ends. There is no wrapping material that ties the top and bottom spar caps together at any point along the length of the spar.
A picture can be seen here.
Chris
lineofsight is offline Find More Posts by lineofsight
Old Apr 16, 2009, 06:53 PM
podrieger is offline
Find More Posts by podrieger
Sarasota, FL
Joined Jan 2006
What is the consensus on this plane? Regular D-tube or Carbon wings? I just ordered an Xplorer with D-tube as I do not regularly fly competition and when I do I don't go for broke on the launches.
The club has several Shadows and everyone loves them.
Phil
podrieger is offline Find More Posts by podrieger
Old Apr 16, 2009, 07:10 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Chris
From reading the description, there was a crash and repair of one of the tips joiner box previously, but the owner did not inspect or maybe did not see damage to the center panel's joiner box which now was stated as compromised.
I have both D-box's and think the strength is fine. I've launched off of mono on an FLS winch in 12MPH wind and though I was a little apprehensive the first time, I have no doubts that th Dbox X can handle it.
On a side note, I flew the X just this Tuesday in 20-25mph turbulent and very gusty wind with no ballast but was still able to penetrate, even if just barely. . Love my X!
T
fnnwizard is offline Find More Posts by fnnwizard
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
