Old Jan 21, 2009, 09:57 AM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Got a quick question for experts out there. My effective "horn length" using this RDS is less than 1/4" , so does that mean my servos needs about 1/2 of the torque requirements vs one using stock horns, being stock horns are about 1/2" from center?
Nevermind, I found ut the answer.
Thanks for any feedback!
Tuan
fnnwizard is offline Find More Posts by fnnwizard
Old Jan 21, 2009, 10:02 AM
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
Originally Posted by glderguy
Yes too bad Futaba didnt make a logger. None the less, if you suffer control loss, lose the plane, logger or not its destroyed, but you will have the satisfaction of knowing, while standing over your 2500.00 worth of crumpled molded beauty, that it was totally destroyed due to 2.4 lockout. If you had a logger I mean. Beats just guessing like you would if you lost one on 72 though. BTW, didnt someone on US F3J team crash or lose control or something like that due to 2.4 issues??
Walter
As far as I know Rich had some launch mishaps not 2.4 issues.... Ben reported 2.4 worked perfectly.
Walter do you have a 2.4 system?
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Old Jan 21, 2009, 10:14 AM
Rich Burnoski is offline
Find More Posts by Rich Burnoski
Bolingbrook, Illinois
Joined Nov 2007
JR3421sa servo actual hands on experience
The JR 3421sa- the 'sa' stands for special applications. I accidently used one on my Espada R instead of a standard JR-3421. The gear train failed on the first extra hard dork landing. Apparently this is the wrong applications.
I replaced the gear set with the gear set that is used in the JR-3421 standard. Works perfect!!!
I suggest not to use JR3421sa on anything except maybe v-tails where there is much less loads.
The JR 3421 standard and the Volz Micro Max Digis have given me the best service on all my planes for competition. I never blew a gear train with any of them.
Rich Burnoski is offline Find More Posts by Rich Burnoski
Old Jan 21, 2009, 10:26 AM
glderguy is offline
Find More Posts by glderguy
4 wheels move a body; 2 a soul
Saratoga, Ca
Joined Feb 2004
Hi SJ, maybe drifting off from EXPLORER a bit. No 2.4 yet, but I do like the benefits of no freq issues w/2.4. Actually, three/four times now Ive gone online, got to the click "order" button on 9303 2.4 but reconsidered each time. I have heard of several issues, not just on this forum, of 2.4 lockout
but have also heard a lot of good things about 2.4 as well. Its just new to me but sooner or later will probably take the plunge. Not bashing it just want to be sure it is reliable, especially when flying somewhat unobtainable planes. NO MORE 2.4 POSTS FROM ME IN THIS THREAD, sorry about drifting off.
Walter
glderguy is offline Find More Posts by glderguy
Old Jan 21, 2009, 10:37 AM
Joined Nov 2007
no radio problems here!
At the WC, I flew what I knew worked flawlessly for me. My Futaba zap synthesized tx's and synth futaba recievers. Ive had the TX's since the year they came out some almost 20 years ago.
I had a hard time convincing myself and decided to not take a chance and use a somewhat new 2.4 'whisker' system.
For the record, we had to switch the teams individual positions around once we arrived at the WC.
I was going to do most of the throwing for the team but doing alot of bungy practice before leaving for the event, I did some bad nerve damage to my opposite throwing arm and couldnt throw when I got to Turkey.
I lost a Supra at practice when the power of our towers pulled the plane (stab), throught the throwers hands.
I lost another Supra during the comp. when I launched into lift in about a 18 + mph frontal wind . Richard
Old Jan 21, 2009, 10:43 AM
Joined Jan 2004
Rich,
Hope the arm is all better now? thx for the update , I think Ben was the only team member on 2.4..... you and DP on 72?
sj
Old Jan 21, 2009, 10:52 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
I had thought about this and using the 3421SA on ele for it's precision, but reading how it can fail on launch made me stop.
I can see how this is. As you dip and zoom, the servo is seeing the most stress at this time as it tries to move elevator down then up at such a quick turnaround (if dip/zooming correctly) and the stab is usually bending right around now to, that's a lot of stress on the servo. Also, being a coreless motor, it can stop and reverse faster than a std motor so that too puts more stress on the gears.
Old Jan 21, 2009, 12:17 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Thanks Tuan. I just epoxied in the first flap servo frame and will see how it all works later tonight.
Preston
jaizon is offline Find More Posts by jaizon
Old Jan 21, 2009, 12:55 PM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
At the WC, Ben was on 2.4 and although I also flew 2.4, it was not in the actual WC event, but in the Spor Yapi Cup event, held the 2 days before the WC competition began. I had no issues. The one loss that was referred to was a Junior aircraft that was on 72-mHz, range checked okay, and then when it was brought to the line, did not respond on the ground. It was ditched for that flight and then they thought they had it figured out. It got into the air and it went blind about 900-ft away and at 500 ft. Never did figure out why that I know of.
mlee8249 is offline Find More Posts by mlee8249
Old Jan 21, 2009, 03:08 PM
Larry Jolly is offline
Find More Posts by Larry Jolly
Larry Jolly's Avatar
Joined Oct 2003
Tuan, in regard to the 3421SA I want to point out that it will not just fail by itself on launch. It was designed for the Jet Guys, where slop, centering, and holding power are the prime factors in choosing a servo. Unfortunately for us it does have a combination Gear train, and it will not tolerate an impulse shock transferred through the Elevator pushrod form the mass of the Stab on a dork landing. Once a tooth on a servo is compromised it is a just a matter of time before it peels. And For you guys that are still on the fence about 2.4...... It doesn't Work, it never has, it never will, it is a vast conspiracy by the model manufacturers to sell more models. I have been secretly flying on 27 for the last 4 years because all the other guys moved on to 72mhz. Larry
Larry Jolly is offline Find More Posts by Larry Jolly
Old Jan 21, 2009, 03:21 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Finally a real answer on the dreaded 3421SA-or-not issue....
Sounds like I better go with the standard model for a contest use, but for sport flying without intentional dork landings, then the SA will be OK.
Thank you, LJ.
Target
target is offline Find More Posts by target
Old Jan 21, 2009, 03:39 PM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Quote
End Quote
OMG!!!!!!!!!!!!!!!!!!! I soo knew this all along! I bet EX pres Bush created 2.4 too.
Glad thats cleared up. Larry, dude you have balls to just bring this out like that..
webbsolution is offline Find More Posts by webbsolution
Old Jan 21, 2009, 04:04 PM
Jim Frahm is offline
Find More Posts by Jim Frahm
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
LJ has spoken!
Crap, now I'll have to buy metal gears for my 3421SA servos. Better to find out now instead of at a contest.
Now I'll go checkout the "For Sale" forum to see who's selling all their 2.4 stuff; might find some great deals!
Jim
Jim Frahm is offline Find More Posts by Jim Frahm
Old Jan 21, 2009, 04:08 PM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Lol Larry. Ok, I'll let my secret out. I'm buying a JR 9303 2.4 just because of you... and ...well...DLG that is.... They do and always have had the best and best selection of RX's in my opinion. I was flying a few JR 700's with my Futaba for a while.
SO now I should hae the best of both worlds eh?
Hehehe,
Tuan
Old Jan 21, 2009, 09:15 PM
Bro is offline
Bro
Find More Posts by Bro
Bro
Bro's Avatar
Southern California
Joined Feb 2003
Xplorer
LJ,
You promised you would not spill the beans! Now, everyone knows about the "plan"!
BB
Bro is offline Find More Posts by Bro
Site Sponsor
Latest blog entry: 2015
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
