Old Jan 19, 2009, 09:59 PM
dhauch is offline
Find More Posts by dhauch
Watervliet, Mich.
Joined Sep 2003
I use clear sign vinyl to tape my servo covers on, works great and easy to remove if need be.
The way vinyl comes, it's easy to tape the cover down with one single piece, if you cut out the pattern.
dave
dhauch is offline Find More Posts by dhauch
Old Jan 19, 2009, 10:39 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
dave
Hehehe. I just had one of our club members cut me a bunch in appropriate colors, square and round.
fnnwizard is offline Find More Posts by fnnwizard
Old Jan 19, 2009, 11:07 PM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
Originally Posted by target
Well, I have a grab bag of opinions, none too conclusive, though.....
I have time; I haven't picked up the plane yet.....
Thanks for all the feed back to this question.
T
Target,
i am in the same boat as you are. i dont have the bird yet, but i am figuring out what servos i will be running.
so far this is my proposed setup (JR's all around):
E-> DS3421SA
R-> DS368MG
A-> DS368MG
F-> DS3421MG
will the wing allow the 368's and 3421's to lie flush or is there not enough room in the wing for these servos?
any recommendations or suggestions?
i am planning on using the bigger servos for the flaps since on the Xplorer, the flaps are huge and need a little extra power, not for holding power, but more strength for inadvertent flap dragging and shock during dorking. i would like to use the DS368MG's on the flaps but the 3421's are a little tougher and bigger.
so, lay it on my guys. i would love to get this hammered out sooner rather than later.
cheers
paul
RCPC is offline Find More Posts by RCPC
Old Jan 19, 2009, 11:09 PM
RCPC is offline
RCPC's Avatar
Joined Apr 2007
dave
thats a great idea. i think i will start adopting that technique. thanks, Dave.
Old Jan 19, 2009, 11:27 PM
dhauch is offline
Watervliet, Mich.
Joined Sep 2003
after you cut out your pattern, you can apply a clear transfer material over your pattern/vinyl..
this makes it easy to apply the vinyl in the right place.
you can get this transfer material at the sign shop.
not sure if thats the correct name or not, but they will know what it is and have it.
dave
Old Jan 19, 2009, 11:41 PM
dhauch is offline
Watervliet, Mich.
Joined Sep 2003
sign vinyl is also good for added a new color to a canopy.
the orange Tomohawk came with a orange canopy and i changed that to black, for a example.
the other two pics are a AVA & a Supra, which both have nose cones, but i added some fake canopies to these, just for a different look.
dave www.rc-builds.com
Old Jan 20, 2009, 01:55 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
paul
368 will only fit in ail if you slide it under the skin. With the mounting tabs intact, you need to slide it til it butts up against the spar to clear the servo cover. No go on Greening mounts with 368.
For flaps both will fit, but 3421 need slight mod per Dave Hauch.
Old Jan 20, 2009, 05:47 AM
rrdiaz30 is offline
Find More Posts by rrdiaz30
rrdiaz30's Avatar
Austin Texas
Joined Mar 2003
Dave's comments on the 3421/Greening frames install:
http://www.rcgroups.com/forums/showp...&postcount=285
http://www.rcgroups.com/forums/showp...&postcount=287
http://www.rcgroups.com/forums/showp...&postcount=288
Rick
rrdiaz30 is offline Find More Posts by rrdiaz30
Old Jan 20, 2009, 08:09 AM
Jurgen is offline
Find More Posts by Jurgen
Europe - Belgium
Joined Mar 2005
I used this FUTABA 9650 nylon geared on an elevator and ripped some teeth entering the zoom:
Futaba Data sheet looked very promising:
Width: 15mm
Height: 28.6mm
Weight: .9oz (26g)
Can be used with 1/12 or 1/18 scale vehicles and electric helicopters
SPEED: .14 sec/60 @ 4.8V
.11 sec/60 @ 6V
TORQUE: 3.6 kg-cm @ 4.8V (50 oz-in @ 4.8V)
4.5 kg-cm @ 6V (62.5 oz-in @ 6.0V)
I pushed it hard but no abuse.
New (cheap) nylons inside and going for rudder usage.
Dunno about the JR-SA mentioned, but nylon gives me some itch after my experience
Cheers, Jurgen.
Jurgen is offline Find More Posts by Jurgen
Old Jan 20, 2009, 09:12 AM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
9650s have natoriously weak geartrains.
djklein21 is offline Find More Posts by djklein21
Old Jan 20, 2009, 09:21 AM
atjurhs is offline
Find More Posts by atjurhs
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
I'm thinking that I'd like to have two wide white bands on the bottom of the wing at each end of the center panel. Would there be anything wrong in just using paint? Dave, where do you get the sign vinyl from? I was also thinking of using Monokote trim w/ adhesive backing (I don't think I want to iron on regular Monokote), but I'm thinking that might be prone to leaving bubbles.
BTW, with the cold weather here my Xplorer flies great in my living room floor, not very high launches, but can really nail the landing spot on
atjurhs is offline Find More Posts by atjurhs
Old Jan 20, 2009, 09:32 AM
glderguy is offline
Find More Posts by glderguy
4 wheels move a body; 2 a soul
Saratoga, Ca
Joined Feb 2004
I notice after TLs post about the 3421 flap servo failing the focus has been on the servo failure aspect of his flight that day. Id be much more concerned about the 2.4 lockout they experienced that may have resulted in the plane being brought from altitude in a hurry? Whats up with the 2.4 lockout anyway? I want to switch over to 2.4 but when I read stuff like that makes me nervous.
Walter
glderguy is offline Find More Posts by glderguy
Old Jan 20, 2009, 09:39 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I think I better go with the standard 3421, just to be safe.
If it gets sloppy, I can always swap it out for an SA or one of the other 34 series servos.
Thanks for the post Jurgen.
Regards,
Target
target is offline Find More Posts by target
Old Jan 20, 2009, 09:44 AM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
Target,
Smart Move.
See Ya,
Pat
pmccleave is offline Find More Posts by pmccleave
Old Jan 20, 2009, 09:51 AM
2F@st4U is offline
Find More Posts by 2F@st4U
2F@st4U.:[BE]:.
Belgium
Joined Jun 2006
Originally Posted by schrederman
What do you guys use for attaching the servo covers in a semi-permanent fashion. I was considering clear silicone... but whudda I know?
Jack
Double sided tape ... no tape visible ... not even with the eye spot on.
And u will be amased how strong the servo covers are attached. I use it all the way round the servo cover ... just as wide as the overlap.
Greetz Tim
2F@st4U is offline Find More Posts by 2F@st4U
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
