Old Nov 13, 2012, 03:34 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Originally Posted by ScotY View Post
Where do you guys get those hollow pushrods?
can you run a bit of thick cyano down it?
What I have done in the past is to clamp the pushrod to the fuselage by attaching rare earth magnets on the outside, which causes the metal pushrod to clamp to the fuselage, so it will glue better.
the problem might come if the glue wicks in to the end of the tube, but I think you should be okay, if you use keep the fuse pointing down - the glue won't flown up. you have to make sure the metal rod is wholly within the outer tube though.
If your pushrod is not a magnetic metal that you can insert a bit of piano wire instead.
satinet is offline Find More Posts by satinet
Old Nov 13, 2012, 06:07 AM
Ib Jensen is offline
Find More Posts by Ib Jensen
Ib Jensen's Avatar
Forest Lake, Minnesota
Joined Apr 2003
Thanks for the suggestions.
I have used the thread through the hole method on long booms with good results. I have also used EPP plugs in the boom on slopers and it worked very well. I carved the plug to shape with notches for push rods and holes for ballast tube but I did not glue the plug in place, I let the friction fit hold it in so I could remove when needed. Its been working for years on my old Fun 1.
I think I will try the magnet approach to insure good placement andl use gorilla glue mixed with a trace of water to get it foaming. If I place it in in the end of a tube and injecting it points along the push rod I should get good results.
I nth past I have used a small light bulb on the end of a stick pushed down the boom so can see the shadow of the push rod through the boom for proper placement of the holes for the string tie down method. I have seen flexible shaft bore scopes and a YouTube video of how to make your own. Anyone ever tried this?
Ib Jensen is offline Find More Posts by Ib Jensen
Old Nov 13, 2012, 06:29 AM
aussief3b is offline
Find More Posts by aussief3b
Ricky Windsock
aussief3b's Avatar
United States, FL, DeLand
Joined Nov 2008
Lots of manufacturers. Search for Hypo tube. You want 18g or .050" outside dia .030"id in 304 SS at 60" long.
Amazon Supply -Part Number - h0050010t304who 5' http://www.amazonsupply.com/dp/B0013...sp_dp_g2c_asin
$9.27
Component Supply with HTX-18R x 60in
http://www.componentsupplycompany.co...FQf0nAodtEQAVQ
.050"od and .030"id
OR MicroGroup with 304H18H
http://www.microgroup.com/Products/S...mic_tubing.asp
Have fun shopping
Gordon
aussief3b is offline Find More Posts by aussief3b
Old Nov 13, 2012, 07:02 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You don't really need a hollow pushrod to attach a music wire L to the end.
I just used a piece of aluminum 1/16" id tubing about 40mm long and have 20mm of pushrod and 20mm of music wire inserted into it.
Use JB weld or rubberized CA to glue it after roughing up the parts and then cleaning them with acetone or alcohol...
Or, you can overlap the pushrod and music wire, rough both pieces up, clean, and use shrink tube over the overlap, and wick in thin CA from both ends.
The last method may sound scary, but test it out on some scraps, and try to pull them apart....
R,
Target
target is offline Find More Posts by target
Old Nov 13, 2012, 05:14 PM
MikeKucera is offline
Find More Posts by MikeKucera
Niagara Falls, Ontario, Canada
Joined Jun 2002
Here are a couple of animations that some might find interesting.
In the first illustration, the pushrod is connected to where the center of the ball link would be, while the second is of my setup which provides a more symmetrical movement. These are close approximations.
I have ignored the mechanical limits of using the ball link in the manner that it is used in the Xplorer.
MikeKucera is offline Find More Posts by MikeKucera
Old Nov 13, 2012, 08:32 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Love the GIF files with the moving parts!
R,
Target
Old Nov 13, 2012, 09:00 PM
vespa is online now
Find More Posts by vespa
2015 Mukbang Cup Semifinalist
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
That's some fancy CAD'ing Mike. What's interesting here is that according to your measurements of the factory rudder horn a servo deflection of +/-50deg produces a rudder deflection of 33deg/46deg -- a significant difference. Of course you could do a lot of math and offset your servo arm to compensate for most of that asymmetry but it's a lot easier and better to just install a proper horn as you did. Speaking of asymmetry, the slight asymmetry in your "correct" gif is due to the short pushrod, which in reality is infinitely long.
Another drawback of the stupid ball link (there are an infinite number) is that it allows the pushrod to buckle in any direction whereas a clevis, or even a L-bend fully constrains and supports the pushrod in all axes except one. This is likely a contributor to the loose pushrod issue brought up by Jensen. By the way, what I do to fix them is bend the rudder 90deg, look inside with a small keychain flashlight, use a long stick to smear a drop of Gorilla glue near the right spot, wiggle the pushrod to smear accordingly, spray a little water, reconnect pushrod and dry centered. It's harder than it sounds and you'll surely poke your eye out.
vespa is online now Find More Posts by vespa
Old Nov 13, 2012, 09:47 PM
Joined Jun 2002
I used a program called C.a.R. aka Compass and Ruler. It's not the easiest piece of software to master, but I managed to learn enough to create these "constructions" as they are called. The animations were created by cropping and assembling screen saves.
Old Dec 01, 2012, 06:04 PM
Ib Jensen's Avatar
Joined Apr 2003
I have finally gotten around to fixing my loose rudder push rod. I was wrong as to where the sleeve pulled loose. It was not at the tail but at the wing saddle. I made a light on a stick I could run down the ballast saddle and found that the sleeve was loose where it loops over the ballast bar end loop just behind the trailing edge of the wing saddle.
It was easy to dab polyurethane glue along the sleeve to hold it in place.
Old Dec 13, 2012, 06:34 PM
VirTus is offline
Find More Posts by VirTus
United States, NM, Albuquerque
Joined Aug 2008
Guys
can anyone advise a safe starting CG for a X 4.0 V-tail?
Cheers
Marco
VirTus is offline Find More Posts by VirTus
Old Dec 13, 2012, 07:02 PM
webbsolution is online now
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Originally Posted by virtus View Post
guys
can anyone advise a safe starting cg for a x 4.0 v-tail?
Cheers
marco
120
webbsolution is online now Find More Posts by webbsolution
Old Dec 13, 2012, 08:43 PM
S-1-11B is online now
Find More Posts by S-1-11B
Sean Worthington
S-1-11B's Avatar
Campbell, CA
Joined Sep 2004
Hi Marco,
I have a 4M V tail and 4M X tail. I run the V at 113 and the X at 120. I was running the V farther aft to get weight out of the nose but noticed the launch was suffering due to down trim, was harder to thermal smoothly and then did a dive test and saw a pretty pronounced tuck. I then put weight back in to get it to 113 and live with my 69oz "pig". The X tail was very tolerant of CG (running aft of 125 for a while) but the V started to not behave for me about 7mm farther forward.
Sean
S-1-11B is online now Find More Posts by S-1-11B
Old Dec 16, 2012, 01:06 PM
xplorer F3J is offline
Find More Posts by xplorer F3J
xplorer F3J's Avatar
Belgium, Vlaams Gewest, Aalst
Joined Sep 2011
Xplorer X-tail
Hi i fly my xplorer 4m X-tail cg on 110 mm and use a lot of camber winy condition or without wind
And whit this settings have i won two stage's in the Belgian F3J league this year
Greetzz
xplorer F3J is offline Find More Posts by xplorer F3J
Old Dec 17, 2012, 12:15 AM
AlpineDSacro is offline
Find More Posts by AlpineDSacro
registered user
Russia, Tomsk Oblast, Kargasoksky District
Joined Sep 2008
A little video of 3.8 Xplorer...
explorer sunday F3J supra & Vulture (5 min 9 sec)
AlpineDSacro is offline Find More Posts by AlpineDSacro
Old Dec 17, 2012, 01:31 AM
DrFragnasty is offline
Find More Posts by DrFragnasty
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Great stuff. Love the 4-legged line retriever. Where's your amazing field? Bris?
Chris.
DrFragnasty is offline Find More Posts by DrFragnasty
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
