Old Mar 13, 2010, 10:26 PM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
And to add to what Tom said, not only put the servo in the frame but make sure it's bolted in (I'm sure you meant that Tom but wanted to make sure it was clear!)
Vic
...who's made that mistake before
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Mar 13, 2010, 10:54 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by tewatson View Post
Never put frames in without the servos installed. This is a guaranteed way to tweak the wing skins, regardless of how much carbon is in the layup.
Tom
I have never done it that way, nor would I ever, but it's mostly a thing of laziness for me.... Why do the extra work?
I DID figure out a new way to glue in servos in the frames. Instead of putting the servo in any type of barrier plastic as some guys do, I used a Q-tip and a little PVA on the Q-tip applied lightly to just the servo case, let it dry, and then glued it in, with the epoxy applied to the frame semi-generously. I'll not try to get the servos out unless needed, but they should be well potted and still come out easily with the PVA....
R,
Target
target is offline Find More Posts by target
Old Mar 13, 2010, 11:29 PM
djklein21 is offline
Find More Posts by djklein21
Challenge is rewarding
djklein21's Avatar
San Diego, CA
Joined Aug 2004
I like the PVA trick
djklein21 is offline Find More Posts by djklein21
Old Mar 13, 2010, 11:51 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
10 different ways to skin a cat.....
Will it be windy tomorrow at the field you think??
Xplorer/Psyko, or
Xplorer/Tracer??
R,
T
Old Mar 13, 2010, 11:52 PM
Eagle Butte User
Portland, Oregon
Joined May 2002
Target/djklein21: What do you guys use to apply weight to the frames while they're curing? I've used a small block of lead (40mmx20mm) but wondering if that is too much weight.
Thxs,
Vic
Old Mar 13, 2010, 11:53 PM
djklein21's Avatar
San Diego, CA
Joined Aug 2004
No, not really http://www.wunderground.com/cgi-bin/...weekday=Sunday
Old Mar 13, 2010, 11:55 PM
Pheasant is offline
Find More Posts by Pheasant
USA, CA, Aptos
Joined Jul 2005
PVA tends to be a pretty crappy mold release on it's own. I would wax rather than PVA the servo case. PVA over the wax would be even better.
Pheasant is offline Find More Posts by Pheasant
Old Mar 14, 2010, 12:37 AM
roydor is online now
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
I use wax, I wax the servo well and from all sides before installing in the frames then glue them in the wing. I use a plywood frame for all my servos, cheap and glues well.
roydor is online now Find More Posts by roydor
Old Mar 14, 2010, 01:52 AM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Getting 90 degrees of flap throw should be easy on the Xplorer. I can get 93 degrees.
The key is to adjust your TX to allow for maximum throws. Most servos I have tested will do 110-120 degrees of total travel. You can get a max of 95 degrees oneway ( 761, 3421, 368, 378), so that leaves at least 15 degrees for the other direction.
Now the horn on the flaps needs to have that clevis hole about 2mm in front (towards LE) of the hingline. The more the better actually. This is becasue when at full flap deflection, that horn becomes a 2mm "arm" as 2mm of that horn will be "above" the hingeline. Servos should only be canted toward LE about 5-10 degrees.
When full throw is given the the servo arm is or almost is "in-line" with control rod.
This will result in the least distortion of the top skin and the best mechanical connection when at full flap deflection. You can also wedge a piece of balsa in between servo/frame and wing spar for additional strength.
I can't find my drawing of the Xplorer flap detail, but here's one of Aspire which is basically same.
You can see the the control rod length is shorter at 90 degrees of throw in the picture. In this particular example, adjusting the horn out an additional ~1.5mm ( or going shorter servo arm) would be perfect for 90 degree flaps. On Xplorer, you would want longest flap horn possible and still give required throw.
fnnwizard is offline Find More Posts by fnnwizard
Old Mar 14, 2010, 03:14 AM
Silent-AV8R is offline
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
Orange County, CA
Joined Aug 2004
Xplorer/Psyko, or
Xplorer/Tracer??
R,
T
Wow, I wish I had those choices and was able to make that kind of decision. I'm stuck with my 3.8 Xplorer. If it's windy I can add ballast I guess.
See Ya'
Silent-AV8R is offline Find More Posts by Silent-AV8R
Old Mar 14, 2010, 03:17 AM
Team Futaba
Orange County, CA
Joined Aug 2004
Good to know. But at 75 degrees I can stop mine cold in the air so I'll have to suffer through without that extra 18 degrees. I already land short too often as it is. Good thing I don't have that extra flap travel, I'd probably never get off the winch line!!
Old Mar 14, 2010, 03:20 AM
Team Futaba
Orange County, CA
Joined Aug 2004
Thxs,
Vic
I am not either Target or David, but I use a small paper cup with a few ounce of lead shot in it. Just enough to keep pressure. Maybe 3 or 4 ounces of shot?? I also do as Tom Watson does and NEVER glue frames unless the servo is in them. I use Saran wrap on the servo to keep it from getting glued in.
I'm still sort of finding my way, but so far that method has worked for me.
Old Mar 14, 2010, 08:48 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Lucky!
R,
Target
Old Mar 14, 2010, 11:54 AM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Originally Posted by ak79 View Post
I tacked the frames in with thin CA, then went back over them with some thickened resin. After is was dry I put the servos in and hooked up the linkage, moved the flaps a bit, and wammo, some dents showed up! Oh well. I guess I shouldn't let it bother me to much, I am a bit picky.
Right now i am using some bass wood to try and tie the top and bottom skins together around the servo to try and keep this from getting worse.
I made that mistake wiht a pike perfect... no CA on those skins it sucks the skin down when it cures everytime.
Slow cure (12 hour) epoxy and some light weight to keep it in place is a better idea.
webbsolution is offline Find More Posts by webbsolution
Old Mar 14, 2010, 11:57 AM
Joined Jul 2007
Vic
NOT yet lol but I did fly an entire contest with a servo arm that was not screwed into the servo...at least I know the push rod was totally square!
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 01:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 10:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 05:44 PM
