Old Nov 02, 2008, 11:34 AM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
Dave,
If I understand you correctly you are saying that you fly in cruise mode with a little reflex in and then go back to neutral for themalling? I looked at my wing and you are right there is a lot of under camber in the wing at neutral setting. I wonder if they set this wing up like the Zentih guys did with a little extra camber for normal thermal mode when the wing is clean. Their premise for doing this is that you will be spending more time thermalling than cruising therefore keep the wing clean in thermal mode and move the surfaces in cruise mode. I will experiment more with this to see what I think about.
See Ya,
Pat
pmccleave is offline Find More Posts by pmccleave
Old Nov 03, 2008, 08:44 PM
andreis is offline
Find More Posts by andreis
andreis's Avatar
Monza, Italy
Joined Dec 2006
Originally Posted by pmccleave
Dave,
See Ya,
Pat
Veeery interesting considerations !!!!
To use slight Reflex on camber in normal cruise searcing for thermals....
Mmmmhhhh, can you please better detail your meaning ?
I remind a friend of mine tell me about the Ceres, and in detail relevant its reflexed airfoil with flap in Neutral position.
But at that time, we still was without any clear understanding on so particular concept choice.
Is it something similar to Dave assumption ??
I don't know so mutch about F3B, and I don't wont make up any confusion, but I heard that Ceres is very well performing in any of its relevant tasks.
Is it depending on airfoil reflex ???????
How it's working the reflex base idea ?
Many thanks in advance for any clarification, or mor deep explanation.
Antonio.
andreis is offline Find More Posts by andreis
Old Nov 03, 2008, 10:16 PM
USA, KS, Wichita
Joined Sep 2002
Antonio,
Below is an excerpt from www.f3x.com about the Zenith Secrets. Maybe this will do a better job of explaining what Dave and I was talking about. Please understand, that is just my assumption that this may be what the Xplorer Designer was trying to do.
"Zenith secrets: For years I have been telling customers to set reflex and use it. The Zenith is a thermal machine and what the designer did was to make his wing mold with an HQ airfoil with 3% camber. Why? When you enter a thermal with your current model you probably roll in a little camber for a better climb. The Zenith is MOLDED in with that added camber already. This keeps the airfoil extremely efficient because when you camber in your current model there is a "kink" at the hinge line and the airfoil is compromised for higher lift. The Zenith's "extra camber" is molded in and since this is a thermal model and spends more time circling in a thermal the designer didn't compromise the airfoil by "kinking" it. He chose a high camber airfoil series that is efficient while climbing.
If you hear a Zenith owner complaining that it doesn't have "legs" he is doing it wrong! The HQ 3/8.5 when reflexed 3 deg will keep up with about any F3J model out there. But the pilot has to enable it. How does your current model cruise out with thermal camber active? It doesn't. Neither will the Zenith until you get into reflex. The designer wisely thought that the high cruise portion of the flight was where to live with the kink."
See Ya,
Pat
Old Nov 04, 2008, 12:48 AM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
Originally Posted by dhauch
then when i hit lift
dave
www.rc-builds.com
That was all you did Saturday with the Xplorer. Granted you could only ride it so high and then it was like a glass ceiling. No matter what you and Bob could get no higher.
They come in RED!!! hmmm.....
Me you ask, I was happy to get the Merlin going and Tiz's Falcon flying not to mention keeping the K2 alive!
Joe
Thermaler is offline Find More Posts by Thermaler
Old Nov 04, 2008, 07:46 PM
webbsolution is offline
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Joe
You know when I got the chance to fly an xplorer myself I could not get used to the camber setting on the futaba radio and since it was nto my plane (or radio) I did not want to start looking away to find the right switches etc. I decided to just fly it "clean" I was very surprised to find it would signal quite well and climb out quite fast without camber...makes sense now that i read this thread. I can't wait to get mine in the air.
webbsolution is offline Find More Posts by webbsolution
Old Nov 07, 2008, 05:00 PM
brownecg is offline
Find More Posts by brownecg
Joined Jul 2004
Testing Tomorrow
My Xplorer is ready for range check and hand tossing tomorrow - and I'll try to get all of the flight modes adjusted so that I can put it up on the winch as well. I don't yet have any ballast, but the forecast for tomorrow is for winds well under 10 mph, so I shouldn't need any. I'm going to start with the throws that Mike Lee recommended, but I've started with the cg at 108 mm. I'm looking forward to getting it flying.
Browne Goodwin
brownecg is offline Find More Posts by brownecg
Old Nov 07, 2008, 09:35 PM
Jim Frahm is offline
Find More Posts by Jim Frahm
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
Xplorer #1
Here's Xplorer #1 ready for radio setup. I'm using a Futaba 12Z for the first time so I have some learning to do. So far I really like the features of this radio, now if I can just learn how to use them.
Good luck to all the other Xplorer owners out there.
Jim
Jim Frahm is offline Find More Posts by Jim Frahm
Old Nov 07, 2008, 09:53 PM
USA, KS, Wichita
Joined Sep 2002
Browne,
If yours is anything like mine was it will fly right off the board. You will be impressed I am sure. Good luck with your first flights and make sure you give us a report tomorrow night. Instead of flying tomorrow, I get to spend 6 hours on a bus and 8 more watching a Cheerleading Competition. Oh Joy.
See Ya,
Pat
Old Nov 08, 2008, 06:59 AM
Jurgen is offline
Find More Posts by Jurgen
Europe - Belgium
Joined Mar 2005
Sorry no NAN topic but adding to what is said before: my Zenith X-tail 3.5m (no XXL) thermal flying secrets:
- Cg at 96mm (yes folks, that forward!), decalage 2 degrees
- Get rid of the winglets, use the flat ones
- fly center panel without reflex
- fly only tip panels with reflex (2mm or flat-line underside)
- never use more chamber (exept on launch maybe a bit)
- use this for both cruise & thermalling, for speed = reflex the center panel too
This might look odd setup but for this bird only (and my taste) it actually really works.
I'm not surprised that the "newer" XXL uses same unchanged center panel and new tips with lesser chamber, my setup simulates this improvement.
Cheers, Jurgen.
Jurgen is offline Find More Posts by Jurgen
Old Nov 09, 2008, 10:12 AM
Wing-span is offline
Find More Posts by Wing-span
Chuck it and see!
Wing-span's Avatar
UK, Cambridgeshire, Huntingdonshire
Joined Sep 2006
I wonder if any of our German colleagues in the F3J scene that are experienced with the model would like to chip in with their findings and trim settings regarding the Xplorer. Calling Team Germany F3J !!!?
Wing-span is offline Find More Posts by Wing-span
Old Nov 09, 2008, 10:37 AM
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
Jim
Jim,
Nice CLEAN shop like the rolling bench
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Old Nov 09, 2008, 10:46 AM
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
Originally Posted by SmokinJoe101
Jim,
sj
Thanks!
It didn't look like that 2 weeks ago.
I just finished building the cabinets and wall units and then I put the bench on casters. I have enough room to park 2 SUVs when not using the garage for modeling.
Jim
Old Nov 09, 2008, 11:56 AM
Joined Jul 2007
Thanks!
Jim
I am in the process of shop improvements as well. I have a 15 foot cieling in the shop and nothing using that space so i am considering some cool plane racks etc.
Your shop looks good Jim. I vote everyone in the NWSS heads over to yoru place for a build clinic!
Old Nov 09, 2008, 01:18 PM
wixy3 is offline
Find More Posts by wixy3
Joined Mar 2006
I Have a limited supply of cnc turned ballast for the Explorer.Please see photo
weights are 13mm Aliminium Bar 170grm----6oz
Part Ali /Steel 280grm----10oz
Steel 450grm-----160z
Cost UK Pounds 20.00 per set (12 pieces)plus postage
Paypal accepted.
wixy3 is offline Find More Posts by wixy3
Old Nov 09, 2008, 01:44 PM
MSgt, USAF Ret.
Jim Frahm's Avatar
USA, WA, Spokane
Joined Nov 2003
Dave,
I have a 10ft ceiling, here's what I did. (see photo) I used a HiLoft storage unit and then added 1X1 with half" dowels and pipe insulation.
BRO,
These garage photos and posts are a bit off topic; feel free to delete if you like.
Jim
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
