Old Jun 21, 2009, 11:03 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Originally Posted by pmccleave
Tuan,
The following information is taken from each plane's general websites.
Xplorer: Area = 75.83 dm2, Weight = 1950 G
Orca: Area = 72.28 dm2, Weight = 1960 G
I would guess both of my planes are slightly heavier than the projected weights but I am guessing the differences would be similar. The Orca definately has a little heavier wing loading unballasted. It also has a faster airfoil, that responds very well to camber. Also, the Xplorer airfoil when set neutral is slightly cambered similar to the airfoil used on the Zenith. I will try to get actual weights of my two planes to see how they compare to the projected weights.
See Ya,
Pat
Excellent info Pat, thanks for the additional info. I have had a few opportunities to fly in avg 10mph wind with gusts up to 15, but not in 20mph yet.
In 10mph constant wind, I find adding about 6oz of ballast to my Dbox (72oz) helps maintain decent energy in the turns.
But, recently, I have been opting to use reflex instead of ballast and find it is quite a surprise to see how good the X is in up to 10mph with no ballast.
I am lots of time thermaling in reflex in gusty conditions, becasue the avg wind may be only 5, but the gusts get up to 15, so ballast for the most part is not very efficient.
I'll report more I later.
Again, thanks for your insight!
T
fnnwizard is offline Find More Posts by fnnwizard
Old Jun 22, 2009, 12:14 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Tuan,
See Ya,
Pat
My v-tail Orca weights 2000g. As a comparison Aspire has 79.9dm2 and weights 2250g and has a superior floating performance. I think Aspire would float better than Orca even when ballasted to 2500g... Airfoils are different, wing planforms are different, tails are different...
I would not compare Orca to Explorer. Orca is really a quite special F3J plane with F3B-like flavour. Its speciality is very good distance flight performance at low wing loadings.
Tuomo is offline Find More Posts by Tuomo
Old Jun 22, 2009, 10:49 AM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
Tuomo,
It is good to compare all planes to each other especially when trying to decide which planes to pick for which conditions. I have noticed that my X-tail Orca floats surprisingly well for a plane designed to be more speed and distance geared than designed to be a floater. It also seems to launch faster and higher than the Xplorer. I do believe the Xplorer to be a better floater than the Orca and so far it seems to be easier to land accurately than my Orca. Could be that I have more time on the Xplorer. I am really looking forward to getting my hands on the New Satori from Aero-Tec to see how it compares as well.
See Ya,
Pat
pmccleave is offline Find More Posts by pmccleave
Old Jun 22, 2009, 11:04 AM
jrerickson is offline
Find More Posts by jrerickson
jrerickson
jrerickson's Avatar
Valencia, CA
Joined Jan 2005
Hey Pat,
Can I be your caddy? You know, I'll carry your new planes to the field and then we can size up thermals and I'll tell you which side of the sky I think looks better.
You are the man for the reviews of the new planes! Keep 'em coming! Sounds like the Orca is similar to the Lightspeed DLG that I fly. Maybe a bit like the NYX? Need to keep it moving but you are rewarded with great distance capability.
I think everyone looks for a plane that minimizes their weakness, so currently I'm looking around for the most stable, predictable plane in landing. I like my Onyx JW a lot, and prior to that I flew my Icon successfully. From what I've seen the Xplorer lands better than either, at least slower. What do you think?
John
jrerickson is offline Find More Posts by jrerickson
Old Jun 22, 2009, 11:22 AM
USA, KS, Wichita
Joined Sep 2002
Hey John,
I have seen you fly, I think maybe I should be your caddy. As far as landing goes, I rank my Xplorer up there with my old Icon which personally I always use as the Standard for easy to land planes. I think the Xplorer is just really easy to keep on line even in gusty conditions and it slows down well in dead air landings. In the winds like we had yesterday, I could just fly it clean right into within a 5-10 feet of the spot and then dump the flaps and stick it. The Orca is a little quicker in the zone and could possibly use a little bigger rudder for keeping the plane tracking straight. I need more practice with the Orca before I make any definetive opinion on the rudder. I may just need to add a little more throw in my landing set up. The Xplorer just like the Icon was easy to land straight off the bench. Needless to say, I really like both the Xplorer and my Orca.
See Ya,
Pat
Old Jun 23, 2009, 02:57 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
It is good to compare all planes to each other especially when trying to decide which planes to pick for which conditions...
Yes but no... Comparing Aspire/Exlorer/Perfect is kind of an easy task. All planes perform just about the same. You cannot go wrong. Just pick the one that feels/looks right for you - or has better availability than the others.
Comparing Orca to the rest of the bunch is a different kind of task. Orca has different kind of performance than the others. When choosing between A/E/P and Orca, you are not only making a choise of a plane, you are also making a choise between slightly different approaches to F3J.
Old Jun 23, 2009, 04:50 PM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
Great day in the mountain farm today. No need for a winch. Just some spotting before the throw and up it went. Flew Xplorer 3800 with small dihedral.
This is up in 950m and the dustdevils (without dust) flew around me today. So easy to take a good photo...
Regards Jojo, jojoen.no
jojoen is offline Find More Posts by jojoen
Old Jun 23, 2009, 05:07 PM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
beautiful pictures
Thanks JoJo. You do have other things than ice and snow... . Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Jun 23, 2009, 05:19 PM
webbsolution is online now
Find More Posts by webbsolution
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
Those are great pics JOJO!
I have yet to throw my plane into a thermal and get away into spec altitude. The thermals here are not concsistantly that strong although I am sure people do it.
It seems like anytime something strong enough to handlaunch and spec out comes my way I am already up in the air! ...maybe today
Going out to put in some more flights on my new Airtronics SD10G wooot!
DW
webbsolution is online now Find More Posts by webbsolution
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
Another one showing the valley
Old Jun 23, 2009, 05:22 PM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
DW
It is slightly downhill here so a little cheating. But a good throw was needed and without spotting the good air it was only a turn and I was down. My problem is that my back can not take too hard throwing...
Old Jun 23, 2009, 05:42 PM
rrdiaz30 is offline
Find More Posts by rrdiaz30
rrdiaz30's Avatar
Austin Texas
Joined Mar 2003
Airtronics SD10-G setup for Xplorer X-Tail
I found this on the Kanoh Model Sailplane Workshop site in Japan.
Airtronics SD10-G setup for Xplorer X-Tail:
http://model-sailplane.dialog.jp/10g-01.html
http://model-sailplane.dialog.jp/10g-04.html
http://model-sailplane.dialog.jp/10g-05.html
http://model-sailplane.dialog.jp/10g-06.html
Rick
rrdiaz30 is offline Find More Posts by rrdiaz30
Old Jun 23, 2009, 08:03 PM
Joined Jul 2007
Rick
There are some itneresting numbers there.
Old Jun 23, 2009, 08:09 PM
Joined Jul 2007
Sweet weather for a one hour flight.
I had just enough time to spike a histart down and launch and do alittle more range testing on my X with the new Airtronics SD10-G
This time I took it way up wind and spec'd it out and then started to range....no issues at the full extent of my vision so I started to have some fun....an hour later I realized I had kids to pick up and work to do and had to come down.
Its a sweet day when you have an hour to fly and you only need one launch
Of course compared to JoJo's post using a highstart is really cheating.
DW
Old Jun 24, 2009, 12:55 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Wow what pics! Thanks for sharing and concgrats to the photographer
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
