Old May 17, 2009, 11:57 PM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Hi Roydor,
The layup of this model is a full carbon skin wing. This is very evident with this model as they used a minimum of paint in the mold, making the skin just a bit easy to see the CF fabric underneath. Will it take windy day launches? I would sincerely hope so, as she is made to handle the extremes of F3J competition. If flying from a winch, and in windy weather, I would be more afraid for the winch line snapping. I realize the the 2-man tow can be brutal, but I also have confidence in the design and construction of this model. Many pilots advised me that the wings of my Shadow model flexed too much,....better not do an F3J launch with it. I reckon that was some misguided info, as many Shadows, including mine, flew in the WC events and despite some wing flex, they launch just fine. So, I'm not worried about the strength of the wings under severe conditions. For the most part, I would just opt for flying the original version instead. The X-38 is for light, or no thermal type conditions. Thanks for asking.
Telling from the long posts concerning the coupled flaps and ailerons, I reckon I'll just leave mine the way they are. Thanks for that, guys.
MIke Lee
mlee8249 is offline Find More Posts by mlee8249
Old May 18, 2009, 12:24 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Just my opinion, if anything, Mike, I'd try to get some differential in the flaps. Not sure if you'd notice the change, but it should help in theory, anyhow.
For a hot roll rate, come fly my Ceres on the slope; it'll do a roll in a second on low rates... Yeah, the flaps are mixed on it. Flying close to an ocean cliff, I find it comforting to know that I have some good roll authority when i can get turbulent.
VR,
Target
target is offline Find More Posts by target
Old May 18, 2009, 04:52 AM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
Mid Air Repair
I figure no Xplore thread is complete without some pictures of repairs. Here's some of the repair from a midair. I am missing a whole set of pictures and can't find out where they are ... but these should be enough to give an idea.
I'll show how I finish the repair within a few days, but I wouldn't hesitate to fly it with the replacement part just taped on .
I know there are easier ways to do this. This is just one way. Enjoy!
T
fnnwizard is offline Find More Posts by fnnwizard
Old May 18, 2009, 05:22 AM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
What am I missing?
Mike, how is the 3.8m X coming out so light? My 3.5m dbox is going to weigh around 75oz. 71oz for a 3.8m span seems very light. What's going on?
Cheers
Paul
RCPC is offline Find More Posts by RCPC
Old May 18, 2009, 05:33 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Very nicely done, but I would not trust exactly that kind of repair. Firstly the part you molded is glass, not carbon. Secondly, the repaired part is not not overlapped with skin, making gluing area very small. Fortunately the damge is in tip panel... (?)
The integrity of a wing depends mostly on spar and L/E joint. Spar is not an issue here, but I hope you wicked plenty of green ca to L/E both sides of the damaged area to re-glue all possible small damages.
A more simple way to repair similar damage is to hack away the damaged part of a wing, glue block of rochacell in place, and sand it to shape (0.5mm less than skin). Then cover with 45 deg carbon cloth, seams slightly original overlapping wing skin around the area. Sand/paint to final finish as you wish.
Tuomo is offline Find More Posts by Tuomo
Old May 18, 2009, 07:11 AM
andreis is offline
Find More Posts by andreis
andreis's Avatar
Monza, Italy
Joined Dec 2006
Tuan,
Nice job, but as Tuomo suggest, it could be improved quite a bit ...
OK yes, you had has already done it , but if would like to improve it...
Tuomo proposal is simple, quick, strong enough, but not so ligth !
But since you was already build a proper mould of the damaged area, instead of a simple gfk layer glued only to the head (may about 1mm or less lguing surfaces between parts..), your mould should be re-used to make-up a suitable piece of a "sandwich" inlay, may with a wider gluing surfaces
To do a top quality reparation, without adding valuable weight to the tip terminal, the edge of the demaged area removed, must be beveled with a low angle respect the external surfaces, in order to offer a good/enough gluing surface to support the new sandwich inlay (4 to 6 mm of bevel should be nice).
The sandwich material will be cut to size of the cut, and its contour will be beveled with the same angle applied to the corner edges of the cut itself.
With the mould you can replay an inlay quite exactly the same as a cut-out from an other original tip.... , to be glued in position when already hardened, and with its edge sanded to perfectly sit on its proper place
Antonio.
PS: unfortunately I doesn't have any picture to explaing that job, may I should get it as soon as I'll arrange some more reparation on moulded wing pieces... , in the meantime I hope the above shoul be enough clear
andreis is offline Find More Posts by andreis
Old May 18, 2009, 09:17 AM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
One layer of 3.2 oz. carbon on a bias laid inside your fiberglass, and overlapping inside will be strong enough, and add only a few grams to what's there already.
schrederman is offline Find More Posts by schrederman
Old May 18, 2009, 09:31 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
I agree, using a block of rochacell adds weight. But not much - a small piece is only 2-3 grams.
Using a mold is more elegant solution, but as said also by andreis and schrederman, what we want is the srength of carbon and well overlapped glue joints
Flyingwise small weight increse (less than 10g) or little rough surface is no issue, but nicely done repairwork adds planes resale value. Maybe this is why why I sell my competition planes so cheaply...
Old May 18, 2009, 09:43 AM
mlee8249 is offline
Fly R/C writer
Redlands, Ca
Joined Dec 2004
To Paul, RCPC,
How is the 3.8 coming out so light....I can only tell you that you need to ask SUSA about that. I know what you're talking about, as my original production prototype is in at 74-oz., full carbon. This latest model is not the only lightweight X in my hanger. Number 2 is also very, very light.
FNNWizard...when did you get into a midair? Or is this the injury you suffered back in Phoenix?
Thanks!
Old May 18, 2009, 09:58 AM
RIP MC
fnnwizard's Avatar
Joined Dec 2003
Mike: Yep that is the ding from Phoenix.
Andreis, Tuomo, Shrederman: I am not done with the repair yet. The part is just taped on for now. I still need to add some ~ .7mm balsa to the inside of the molded part so it matches the wing's skin thickness. Then another layer of glass, then 1/2" of "seaming" to bond the part to the repair area.
Thanks for the pointers though!
T
Old May 18, 2009, 02:16 PM
jojoen is offline
Find More Posts by jojoen
jojoen's Avatar
Norway
Joined Dec 2003
In competitions and especially wc's we collect parts when people crash. When we get a damage like this we cut out the broken part and do a similar part from crashed models. Doing as small overlay on the inside (just some skin pieces) and glue it all together with CA. This is almost as good as original.
To fix this kind of leading edge damage only takes 10-15min if you have done it before. Use medium or thick CA and you can scratch of the CA sticking out before it is fully cured.
Delamination is also fixed with CA. Lots of small holes are punctured in with a needle and thin CA is applied and the skin pulled or squizzed in the right position. Scratch off the CA with a knife 90 degrees to the surface before it is fully cured.
Yes I can post here now as I will have a 3800 Explorer in my house soon... And my own design. Thanks to Primoz and Nikolay
jojoen is offline Find More Posts by jojoen
Old May 18, 2009, 02:53 PM
gliding Oz is offline
Find More Posts by gliding Oz
Fly, Fish or F#@%
gliding Oz's Avatar
Houston
Joined Dec 2006
Nice color design Jojo.
Please let us know how you like the Explorer 3.8 and how it compares to the other aircraft in your fleet after you get some stick time.
Cheers,
Who the is Thomas Cooke
gliding Oz is offline Find More Posts by gliding Oz
Site Sponsor
Old May 18, 2009, 03:08 PM
jojoen is offline
jojoen's Avatar
Norway
Joined Dec 2003
Off course abi.
Those who know me know that I say what I mean and see
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
Very nice is the wing Lay-up any different that original Explorer?
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Old May 18, 2009, 03:19 PM
atjurhs is offline
Find More Posts by atjurhs
agony sweetns the victory
atjurhs's Avatar
Any Flying Field Across America
Joined Jul 2005
Purrrty!
atjurhs is offline Find More Posts by atjurhs
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
