Maybe...
Thanks. Target |
Latest blog entry: Stork 4 Pro X-tail from...
http://www.aircraft-world.com/shopexd.asp?id=784 |
Redlands, Ca
Joined Dec 2004
It is airborne!
Okay, so we had wonderful sunny California skies with highs hitting about 90f and a slight breeze every once in awhile. A complete range check was performed and then three people to rundown the control motion check. A hand toss was great and the plane was showing her to be a floater...so far so good. Only one thing left to do...winch it!
So, with normal winch line tension, I gave it a throw only to break the line 2-seconds into the launch. It didn't matter....11-minutes later, it landed! Great float, very good thermal detection, the roll rate is very nice despite having these long wings and the elevator is quite positive. It does not roll as snappy as the original X, but plenty fast enough for the majority of pilots. I did end up increasing the rudder mix from 45% to 60% and that made turns much smoother and progressive. I also added 4% more aileron up for the CROW as the plane simply floated too much. Four pilots took their turn at the sticks and all were very pleased with the handling. One of them was Bob Breaux of SUSA, and he was wringing it out with full elevator applied to a hard banked turn. The plane did not stall out. It just kept turning and burning. Launching is pretty darn stable, being almost hands off and steep. It does not carry the zoom as long as the original, but it is not disappointing, either. Now, we have been granted permission by the authorities at SUSA to release that classified information...71-oz. That makes for a wing load of a hair above 8 oz/sq-in. This is the perfect early morning, late evening, no lift condition aircraft! |
Redlands, Ca
Joined Dec 2004
To Webbsolution,
I understand what you say about not using the ailerons coupled to the flaps. And to be honest, I have been in such a habit of using coupled flpas/ailerons for so long, it is just normal for me to program them in. I reckon I'll just have to try it and see how I like it. I originally started coupling up when flying the Lazurite many years ago, and this plane simply had a lack of roll response until I coupled the controls. That cured that and I have coupled ever since. But I will try it and see. As for that trade agreement between the countries...come and get me! "You'll never take me alive, copper!" BTW, Les Ward at our field also put up his X-38 and it also was a pleasing experience for the pilot. His balance point was similar at 106-mm. Thanks to all of you guys who have asked about this plane. Sincerely, Mike Lee |
Mike, what's the lay-up of your plane? d-box?
Are the spars full strength? will it take windy launches? lets say up to 10-15 knots? more than this? Webbsolution, Mixing flaps with the ailerons actually reduces drag (up to a point), the reason lays in dampening affects of the center panel during roll rate of the wing. For example, if you create a roll rate with the ailerons and then return them to neutral, the glider will stop the roll without the need to introduce opposite aileron. This is caused by the fact that the wing going down is seeing a higher angle of attack and the wing going up is seeing a lower angle of attack. This causes an increase of lift in the wing going down and decrease of lift in the wing going up. The asymmetrical force causes a dampening affect and stops the roll. The faster you roll the grater the dampening. When you couple the flaps with the ailerons your not really creating roll, its to little a moment to create a noticeable amount of roll. It is however enough to decrease the amount of dampening from your center panel considerably and as a consequence it increases the effectiveness of the ailerons, hence grater roll rate. The longer the center panel the grater the difference. Because the dampening affect is roll rate related and while flying in very calm conditions you're flying with small stick movements, the amount of flap coupling required is reduced considerably. I use about half of the aileron movement in speed mode, a third in cruise mode and only a quarter in thermal mode with my Perfect. |
My maiden experience was similar, with a 10-12 minute flight spent at about 75-100' of altitude, much to my surprise.
I would have to say that now, I would have done much better, I think! R, Target PS. I also believe in coupled flaps to ailerons. Coming from the sloperacing discipline, I can tell you that this allows less overall throw/drag for the same response wanted. Always a good thing. For David, have you tried coupled flaps with just way less throw overall, as your light lift settings?? That's the direction I would go. |
Flaps coupled to Ail
I have tested this out on a few ships over the past couple years and will say that I always run coupled flaps with ail in all modes.
Without coupled flaps to ail, the controls were more sluggish and of course the ail needs to move much more to yield same roll rate. The key is how much to couple them. Dr. Drela had provided a scientific reason to use it and a formula but I can't find it. It goes something like this: The perfect roll movement is a twisting wing with zero twist at the root and progressing to more twist at the tips. But since our wings are made for no flexing we can "twist" the trailing edge to simulate. So it reasons that the flaps should move a percentage of the ail. According to Drela's theory, if the flaps were the same length as the the ail then a 2:1 movement of ail to flaps would be appropriate (flaps move 50% of ail). If flaps were 40% of Ail length, then flap movement would be less than 1/2 of ail movement. The only way I have found to be accurate with this is to place a piece of paper in between the center panel and tips when sliding the tips on. With a reference line drawn (LE to TE) and make mearsurements against the line. On my X the Flap/Ail are a little less than 1:2. About 2:5. Now if we extrapolate this to the Xtended tips, it should be that the flaps now should move less and/or the Ail throws should be more. Calculated wouwld be about 1:3 coupled Flap to Ail. Looks like Mike Lee is running :4. The other thing that Dr. Drela says it helps is reduce tip stalling tendecies. That, I believe is one of the best reasons to use A+F when low, slow and praying. TL |
Brea, CA
Joined Feb 2007
Flap/Ail Coupling
Tuan;
You are close but here's the quote of Dr. Drela, written by Daryl Perkins. Aileron/Flap Coupling The original question is about aileron to flap coupling. I've been using this for years, regardless of airframe. I found it to aid in all handing characteristics. Increases roll rate while reducing total throw required in all flight modes, reduces adverse yaw tendencies requiring less aileron to rudder coupling. From Dr. Drela: Deflected ailerons deform the load distribution away from the ideal near-elliptical shape, and hence increase induced drag. Partially slaving the flaps to the ailerons can alleviate this load distribution deformation, and thus mitigate the ailerons' CDi penalty. The question is what's the optimum amount of ail-> flap mixing. The lowest-drag aileron system is wing-warping as used by the Wright Brothers -- the wing is linearly twisted from tip to tip. When such a twisted wing reaches its steady roll rate, the load distribution returns to its optimum level-flight shape, and the drag penalty is zero. With a finite number of hinged control surfaces such a linear twist cannot be achieved. But it can be approximated as close as possible if each surface's deflection is made proportional to its distance from the aircraft's centerline, measured at the surface midpoint. If the four control surfaces have equal span, we then have: Surface mid-span loc. deflection L.Aile. -3/4 -100% R.Aile. -3/4 -100% L.Flap. -1/4 -33% R.Flap. -1/4 -33% So for this wing the flap motion should be 33% of the aileron motion. Using AVL I've verified that this mixing ratio produces very nearly the smallest induced drag penalty. If the flap span differs from the aileron span, the table above can be adjusted accordingly. Longer flaps will have larger travel and vice versa. BTW, this "distance-proportional deflection rule" strongly argues against stopping the ailerons short of the tip. The resulting unhinged tip portion should in fact have the largest deflection. The "distance-proportional deflection rule" can be fudged if there is a tip stall problem in a sustained turn, where some opposite aileron must is held. By increasing flap travel over its "optimum" amount, the flaps can carry a greater share of the roll power, which reduces the required downward deflection of the inside aileron, and thus delays tip stall. So if your TD glider has insufficient tip stall margin, I suggest increasing the flap mixing and you should see some improvement. The extreme case would be 100% flap mixing, which mimics full-span flaperons. Flaperons give excellent tip stall resistance, as is obvious to anyone who flies a DLG with a good 2-servo wing. A 4-servo TD wing with decent planform should not need to go to this extreme. I have some time on a Perfect. Yes, I coupled the ailerons to flaps with good results. I probably run more than Dr Drela suggests. Good luck with it!!! dp Just happened to have it in my files as I like to save useful data from talented people. Enjoy, Don |
| Thread Tools | |
| Discussion RADINA 2 by NAN models | Pinci | Hand Launch | 38 | Feb 11, 2009 12:58 AM |
| Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question | Broncomech | Slope | 20 | Jul 23, 2008 09:47 PM |
| Discussion Nan Models Shadow ( sorry for the mistake ) | Chipwillis | Thermal | 56 | Apr 19, 2007 04:44 PM |
