Old May 15, 2009, 10:05 AM
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
Originally Posted by Keith Kindrick
You have got to be kidding me that lead is used in that epoxy pigment. No wonder I fly Samba
Most EUOPE model builders shoud be using non lead base paint by now or there just using what they have on hand till there out of the old lead base paint.
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Old May 15, 2009, 11:23 AM
Keith Kindrick is offline
Find More Posts by Keith Kindrick
United States, CA, La Verne
Joined Feb 2007
Mike I just went up and spoke to one of the materials and process weenies about doing a test for prohibitive materials on the Samba paint using the XRF Analyzer. Guess what no lead on the canopy or stab. SAMBA is GREEN baby!
Keith Kindrick is offline Find More Posts by Keith Kindrick
Old May 15, 2009, 12:21 PM
fnnwizard is offline
Find More Posts by fnnwizard
RIP MC
fnnwizard's Avatar
United States, CA, Midway City
Joined Dec 2003
My tips came out to:
Right tip 174.3 g (6.11oz)
Left tip 173.3 g (6.15oz)
Stabs 54.2g (1.91oz)
Yes garage floor is nasty. It was that way when we bought the house
fnnwizard is offline Find More Posts by fnnwizard
Old May 15, 2009, 06:24 PM
RCPC is offline
Find More Posts by RCPC
Throw it like you hate it
RCPC's Avatar
United States, CA, Castro Valley
Joined Apr 2007
Originally Posted by mlee8249
So, I do not use any retainer or wheel collar to keep the pushrod in place. It is simple, easy and effective.
i dont think you should have an issue but since i keep asking all the questions, i decided to give back a little nugget of engineering i use.
on all L-bends, i take a clipping of a servo arm and drill a hole slightly under-sized for the rod. i then push the piece of plastic over the L-bend and i am done. i sometimes put a little glob of 90 sec (yes 90 seconds) epoxy on the tip of the L-bend and plastic to be sure everything stays were i left it. i use 90sec because it is much more rubbery and doesnt pull away from the metal or plastic from shock. you have to work fast though. i used to use JB and even 5 and 30 min epoxy but i found the 90sec gives a bond that is less prone to shattering or pulling away from the plastic or metal.
i use this technique to keep wheels on small parkfliers too. i always thought that collars are too expensive and heavy. they also take up a lot of room on the pushrod. i used on pushrods too in many of my powered planes. here is a pic of how i used it with my rudder pushrod on my X. i havent added the 90sec to the keep the retainers on, but i will do that soon.
cheers
paul
RCPC is offline Find More Posts by RCPC
Old May 15, 2009, 11:43 PM
GNieuwoudt is offline
Find More Posts by GNieuwoudt
GNieuwoudt's Avatar
Joined Apr 2003
Originally Posted by RCPC
on all L-bends, i take a clipping of a servo arm and drill a hole slightly under-sized for the rod. i then push the piece of plastic over the L-bend and i am done. ....................
I use piece of heatshrink or pushrod sleeve which fits tight. With some cyno it newer comes off and can make a tight fit.
Cheers
Gert
GNieuwoudt is offline Find More Posts by GNieuwoudt
Old May 16, 2009, 01:55 AM
mlee8249 is offline
Find More Posts by mlee8249
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Well, today was a day off from the office, but a day in for the workshop! We left off with the aileron servo being installed, and we pick up right there with the right aileron getting the same treatment. In the process, we extended the wires to reach the wing joint and I use regular servo plugs when joining the wings together. i never did trust myself to install the kind of plugs that other guys use that simply connect when you join the wings. Okay, so I plug my wires in by hand everytime, but if I ever need to change a servo in the field quickly, it's a bit easier with the loose wire and connector.
From there, we assembled the wing wiring harness. Now, I don't know if this is absolutely true, but my local Radio Shack told me that they are no longer going to be carrying the 9-pin DB-9 connector except in the kit form. The kit form is the one where the pins are not inserted into the body of the connector. I have not had very good luck with the kit version, and always went after the completed one. Luckily, this store had a set left and I got it. After chasing wires down into the wing to the center section, we connected up the DB-9 and began the "Mission Impossible" task of getting it to fit inside wher it is supposed to go. OMG, I did it without a hitch! First time for that feat! (Well, at least for me it was.) Felt so good about that one, that I took my sweet time on the mating connector.
Here ya go:
mlee8249 is offline Find More Posts by mlee8249
Old May 16, 2009, 02:10 AM
mlee8249 is offline
Fly R/C writer
Redlands, Ca
Joined Dec 2004
Our next step was to install the flap servos, knowing that the wire harness would work. Plus, I used it to center up the JR 3421 servos before rigging the flaps. Using the very same technique used on the ailerons, the flap install went smoothly. From here, I went to install the fuselage DB-9 connector.
Okay, we finally came down to earth...this was not so smooth. I should have taken this caution, but I did not. I should have fitted the DB-9 to the fuselage first before doing up the wiring just to make sure it fits into the hole. It didn't. And so I ended up doing the trial and error fitting. In my case, I had to insert the wires each time I fitted it and remove the entire thing if it did not fit....which was more that a few times. When it finallly fit down inside, I mated the wing to see the fit between them...no dice. The fuselage connector was sticking up too much. I then milled down the mounting area with a dremel and router bit, removing a couple of mm. Now it fits.
Old May 16, 2009, 02:17 AM
mlee8249 is offline
Fly R/C writer
Redlands, Ca
Joined Dec 2004
We are now on to the battery. I use a 2S lithium-Ion pack of Relion cells, and then use a Castle Creations BEC to regulate the power. This pack is rated at 2600-mAh and for proper fit into the X, we had to reconfigure it a bit. Once done, everything was tossed into the nose with a Spektrum AR7000 receiver and a single satellite rx up inside the canopy. It all barely fits inside. We had to add a couple of ounces of nose weight to achieve a balance point of 106-mm, and from there, we can adjust it to our likings at the field. It's now past midnight in California, so time to rest.
Old May 16, 2009, 04:55 AM
davidleitch is offline
Find More Posts by davidleitch
Tragic case
davidleitch's Avatar
Sydney Australia
Joined Feb 2002
The Graupner or Multiplex 6 pin plug is a great alternative to DB9. The Graupner version comes with a nice plastic mount.
davidleitch is offline Find More Posts by davidleitch
Old May 16, 2009, 08:06 AM
SaltyOne is offline
Find More Posts by SaltyOne
Stamford, CT
Joined Feb 2002
I like the Multiplex much better than the DB9. It seems like a more reliable piece to me. It is also designed for many cycles of connecting and disconnecting. The DB9 is not. Some of my friends that like DB connectors and want more redundancy on the on the power connectors have gone to the DB15 connector, also sold at Radio Shack.
George
SaltyOne is offline Find More Posts by SaltyOne
Old May 16, 2009, 09:46 AM
podrieger is offline
Find More Posts by podrieger
Sarasota, FL
Joined Jan 2006
Mike, we really appreciate you taking pictures and explaining your installation. Could you also post what you set your control surface throws to? Also what you recommend for launch settings.
I just got my Xplorer from Bob and it looks great. Great packaging and had all the equipment I ordered (thanks Annette). Plane is absolutely beautiful.
Thanks again Mike.
Phil
podrieger is offline Find More Posts by podrieger
Old May 16, 2009, 11:38 AM
ACooper is offline
Find More Posts by ACooper
Banned
ACooper's Avatar
USA, NJ, Wantage
Joined Jul 2008
X2!
ACooper is offline Find More Posts by ACooper
Old May 16, 2009, 11:46 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I'd be interested in that, David.
Will it fit in the same space that the DB9 will??
Never seen one in the USA.
Target
target is offline Find More Posts by target
Old May 16, 2009, 01:38 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Originally Posted by pmccleave
I started at 108 and have not felt any reason to change it as it flys great there. Also can put either set of ballast and not change it at all.
See Ya,
Pat
Which ballast set is that? the one from SUSA or Wiky3? Thanks.
Preston
jaizon is offline Find More Posts by jaizon
Old May 16, 2009, 03:57 PM
ACooper is offline
Banned
ACooper's Avatar
USA, NJ, Wantage
Joined Jul 2008
Target
Possibly this?
http://www.hobby-lobby.com/quick-fix...chQueryId=1131
Discussion RADINA 2 by NAN models Pinci Hand Launch 38 Feb 11, 2009 12:58 AM
Question Speed 1.5 /Nan Models. Alex Mini 1.5 setup question Broncomech Slope 20 Jul 23, 2008 09:47 PM
Discussion Nan Models Shadow ( sorry for the mistake ) Chipwillis Thermal 56 Apr 19, 2007 04:44 PM
