Old Jan 30, 2003, 02:32 AM
Guzzler
Guzzler
Guest
n/a Posts
Problem irvine 46 ABC MK3 first time start.
I was working all day on my plane and is ready.I tried to
start the engine but NOTHING.I am trying the last 30 minutes and it
doesn't
start.I am pissed with this engine!
I mounted the fuel tank.The engine is mounted too and the pipes
correcty
installed.I followed the instuctions which are:
Place your finger in the carb. air intaker and turn 3-4 times
anticlockwise(with no throutle).Place the throutle in 1/4 and connect
the
glow starter.(I am sure it is glowing).smartly flip the propeller
anticlockwise with a chicken-stick or electric starter.The engine
should start.
Well it's not.I have tried any other combination.No fliping the 3-4
first
times without starter,different heigh of fuel tank.Droping fuel in the
airtaker.(advice in instruction in case it is not starting.)It is not
heledric block,cause I removed the glow plug and I remove the
fuel.Even
fliping clockwise which makes the fuel jump from the carburator.What
the
hell am I doing wrong?Does anybody own this engine?Is it impossible to
start it without an electric starter? Is that the problem?
thanks a lot,
Guzzler
Old Jan 30, 2003, 05:02 AM
Fred Hambrecht Sr
Fred Hambrecht Sr
Guest
n/a Posts
Re: Problem irvine 46 ABC MK3 first time start.
You say, "I am sure it is glowing". How are you sure? What are you using for
the power for the glow plug?
An engine only needs 3 things to run Fuel, Air, and an ignition source. You
stated that their was plenty of fuel, unless you are on another planet we
can assume air is present. That leaves the ignition source.
The glow plug should be an orange color when properly heated. Remove the
glowplug and attach your battery and check it. Then either get a correct
battery or a new glowplug. Even if the mixture is wrong, if you managed to
get fuel in the engine, you should hear it attempt to run. At least you
should get a pop or two indicating it was trying to run.
"Guzzler" <beros_abdn@yahoo.co.uk> wrote in message
news:2ff8be1.0301300022.3b176e55@posting.google.co m...
> doesn't
> correcty
> the
> should start.
> first
> fuel.Even
> the
> thanks a lot,
> Guzzler
Old Jan 30, 2003, 01:02 PM
Dr1Driver
Dr1Driver
Guest
n/a Posts
Leave the idle needle alone. Open the high speed needle about 2 turns. Choke
the engine 3-5 turns with the throttle fully open. Choking at idle does
nothing. Close the throttle until you have about a 1/16"-3/32" opening. Using
a FULLY CHARGED glow battery, light the plug and spin the engine with an
electric starter. If it doesn't start, pack it up and send it back.
Dr.1 Driver
"There's a Hun in the sun!"
Old Jan 30, 2003, 01:32 PM
Guzzler
Guzzler
Guest
n/a Posts
Yes that's what I mean.I removed it and I checked it.I was glowing
like the sun.I could hear the fuel in the engine but I cannot
understand the sound of "trying to start".Probably it is not doing
it.How many turns should the engine turn to start?I am able to do only
one with the stick.Tried every speed.
I even droped drops of fuel directly on the cylinder,NOTHING.I ll keep
trying. The thing is that I don't know anybody here who can help
me,and the club is quit far without a car.
"Fred Hambrecht Sr" <w4jle@charter.net> wrote in message news:<v3i16a2ub5l6df@corp.supernews.com>...
> > doesn't
> > correcty
> > the
> > should start.
> > first
> > fuel.Even
> > the
> > thanks a lot,
> > Guzzler
Fred Hambrecht Sr
Fred Hambrecht Sr
Guest
n/a Posts
Your running to rich and flooding. Removing the muffler leaned it out.
news:2ff8be1.0301301057.484517f1@posting.google.co m...
> I ve got some progress.I did again and agian anything but nothing.I
> thought removing the muffler.The engine started easily!(Too loud sound
> of course).I cut it off and I tried the normal way.Agian nothing.The
> engine didn't appear trying to start like without the muffler.I
> started once with the muffler but with the pipe disconected.Is
> something with the presure?What is it suposed to be like the whole
> thing with the muffler.The pipe going from the muffler to the engine
> should be a metalic pipe going to the top of the tunk,Am i right?I
> used both pipes,the one of the muffler and the optinal one for
> refuling which i used to have it shild for leaks.The third was going
> down but I turn it going up to di the job.Nothing again.The muffler
> looks just fine.I blow in and the air is coming out.I don't thingh
> there is anything else I can test with the muffler.
> Any IDEAS?
for
You
we
to
> > > doesn't
> > > correcty
> > > the
> > > should start.
> > > first
> > > fuel.Even
> > > the
> > > thanks a lot,
> > > Guzzler
Old Jan 30, 2003, 02:22 PM
Guzzler
Guzzler
Guest
n/a Posts
Any IDEAS?
> > doesn't
> > correcty
> > the
> > should start.
> > first
> > fuel.Even
> > the
> > thanks a lot,
> > Guzzler
Old Jan 30, 2003, 05:12 PM
Lee Jarvis
Lee Jarvis
Guest
n/a Posts
I bought an Irvine .46 about 18 months ago for a Somethin' Extra. I was
impressed with how easily it started - right out of the box. An altogether
delightful engine. I may never buy another O.S.
Try choking the carb with your finger and turning the prop 3-5 times with
the throttle wide open, not at idle. Trying to choke with the throttle
closed will not work.
Good luck!
> doesn't
> correcty
> the
> should start.
> first
> fuel.Even
> the
> thanks a lot,
> Guzzler
Old Jan 30, 2003, 06:32 PM
Guzzler
Guzzler
Guest
n/a Posts
I see,I let too much fuel to get into the carb.But what do you mean
"removing the muffler leaned it out"?What should I do to avoid it?I
tried with leaner mixture through the mixture needle but the same.
"Fred Hambrecht Sr" <w4jle@charter.net> wrote in message news:<v3itk7hnldk41f@corp.supernews.com>...
> > Any IDEAS?
> for
> You
> we
> to
> > > > doesn't
> > > > correcty
> > > > the
> > > > should start.
> > > > first
> > > > fuel.Even
> > > > the
> > > > thanks a lot,
> > > > Guzzler
Old Jan 30, 2003, 07:32 PM
Fubar
Fubar
Guest
n/a Posts
Are you sure the glowplug is good, the glow igniter is good, and you are
getting a good glow? From your posting, it sounds like something you didnt
check. You say you removed it but never mentioned testing it.
Dan
AMA605992
I've heard the screams of the vegetables.
http://fubar1.freeservers.com
> doesn't
> correcty
> the
> should start.
> first
> fuel.Even
> the
> thanks a lot,
> Guzzler
Old Jan 31, 2003, 02:02 AM
Guzzler
Guzzler
Guest
n/a Posts
Of course I tested.I plug it on the starter and watch the glow for
several seconds.It is medium F5 model technics.I tested for more than
three times to be sure.
"Fubar" <Fubar1@socal.rr.comme> wrote in message news:<C8k_9.45225$h9.11766421@twister.socal.rr.com >...
> Dan
> AMA605992
> > doesn't
> > correcty
> > the
> > should start.
> > first
> > fuel.Even
> > the
> > thanks a lot,
> > Guzzler
Old Jan 31, 2003, 07:42 AM
Mathew Kirsch
Mathew Kirsch
Guest
n/a Posts
beros_abdn@yahoo.co.uk (Guzzler) wrote in message news:<2ff8be1.0301301620.46c8b0a4@posting.google.c om>...
The muffler provides pressure to the fuel tank through the tube that
connects them. That pressure helps the carburetor get an even flow of
fuel in the air when the plane is going every which way. When you
removed that pressure, you cut the flow of fuel to the carburetor by
about half, the same as you would if you closed the needle valve.
Everyone says that all an engine needs is air, fuel and fire to run.
Well, if you have too much fuel, it doesn't matter how much fire and
air you've got. That engine isn't going to run for love or money. The
excess fuel will put the fire out and all you'll have left is wet
air...
How many turns open is the main needle valve? Many engine
manufacturers will tell you to open the needle valve 3, 4 or even 5
turns for the first start. I have never been able to get an engine to
start with the needle valve open more than 2 turns. My first engine
gave me several hours of grief because the instructions said to open
the needle valve 2-1/2 turns. It would not run, let alone fire. In
desperation, I started closing the needle valve a little at a time,
and as I closed the needle valve, the engine started to run for brief
moments. When it finally caught and ran, guess where the needle valve
was set... It was exactly two turns out. I've used that setting on
every engine I've owned since, and it's never failed.
Old Jan 31, 2003, 08:42 AM
TX_QBALL@webtv.net
TX_QBALL@webtv.net
Guest
n/a Posts
The only thing that caught my eye was the choking..You said you put your
finger over the opening with the throttle closed.It's suppose to be open
(wide open) and as soon as you suck fuel into the carb then you close
it. Then open it slightly when your ready to try and start it.The high
speed needle should be open a couple of rounds or slightly less.
This one really sounds like a mystery.I have a 53 and it starts super
easy.Best engine I've had and with a 10X6,a real screamer..Good
luck...Walt
Old Feb 01, 2003, 12:32 PM
Guzzler
Guzzler
Guest
n/a Posts
I repeat.I tested it.I removed the glow plug,I attached it to the
starter with the battery and it was glowing.I waited for more than 10
sec and was glowing the same and even more after a while.I don't think
I can test anything more.
I decided it.On tuesday,I ll take it to the local model shop,the
engine and the fuselage. It is 25 minites walk but there is nothing
else I can do. At least he will know, he can tell me what is wrong and
if the engine is failed, so I ll return it and have a new one.
> Dan
> AMA605992
> > doesn't
> > correcty
> > the
> > should start.
> > first
> > fuel.Even
> > the
> > thanks a lot,
> > Guzzler
Old Feb 04, 2003, 08:42 PM
Penguin254
Penguin254
Guest
n/a Posts
Sounds like you might want to try removing the baffel in the muffler to get
it to run. It will still be louder than with the full muffler, but it iwll
be a whole lot more quiet than an open head.
It dies strike me as odd that the thing won't run though. I would get with
one of hte engine guru's at the local hobby shop or the flying field and see
what they have to say.
Mark
news:2ff8be1.0301301620.46c8b0a4@posting.google.co m...
> > > Any IDEAS?
using
> > for
source.
> > You
planet
> > we
the
correct
managed
> > to
you
it
> > > > > doesn't
> > > > > correcty
connect
> > > > > the
> > > > > should start.
3-4
> > > > > first
the
not
> > > > > fuel.Even
carburator.What
> > > > > the
impossible to
> > > > > thanks a lot,
> > > > > Guzzler
Discussion First Time Monocoating Problem modelmaster2001 The Builders Workshop 16 Apr 21, 2007 10:22 AM
Discussion First time with a Hi-start! ashdec87 Thermal 30 Mar 14, 2006 02:41 PM
Discussion Trying to start engine for first time in model, is this normal? waynekinney Fuel Heli Talk 3 Jan 27, 2006 12:42 PM
Irvine .46 ABC Free Shipping codell Aircraft - Fuel - Airplanes (FS/W) 2 Jan 24, 2005 08:08 PM
Problem Solved Slow Charging Kan For First Time chileno Batteries and Chargers 4 Apr 01, 2004 06:38 PM
