HI Ryan,
I can give you the over all dimentions of the tips. Nick and I just sorta free handed it, useing the TLAR method. It's baiscly a mix of an AVA tip and a Tango tip put together. It's 6" wide at the trailing edge and the cord is what ever the last rib is on the Riser wing. The angle of the rib is about 30 degrees. Here is the photo for you. Bob in Seattle |
Ryan, i don't think Bob has much in the way of drawings, it was done on the TLAR method. There's a possibility that his vert stab area my be a little bigger than the stretched tips require, and will need trimming. He's due to test fly this weekend. Before jumping in and going V tail, suggest we see how it flies. Either that or engineer in some way of changing the V angle. I've done that before by joining the two halves with 1/4 scale hinges, and using two screws through the hinge axis to attach them to a V shaped saddle. That way V angle could be changed for trimming flights with a couple of packer strips. The added advantage is that the V tail can then be taken off and stored flat if need be.
Question: when does a Riser cease to be a Riser? If span is changed, planform is changed, tail type is changed, and a motor is added, is it still a riser? How about pod and boom using a cf golf wood shaft? Pretty sure they're all spiral wound, and they're actually easier to attach a v tail to IMO. I picked up 6 for $5 from my local pro shop. Nick |
USA, MO, Lee's Summit
Joined Sep 2001
Don, I'll take a Chysalis 120 or whatever you've got going on. But, if I need an in between project, the Riser 112 will do just fine. Of course, designing Riser 112 Vtails isn't going to help your cause any.
Bob, Thanks again. I think I'm going to work on the Chrys, if I can get the kids to bed at a reasonable time. Ryan |
No v-Tail squadron, we need to nip this mole in the bud. We must discredit him in some way so he will not persuade those doubting the cause. The mole reminds me of that arcade game where the rodent keeps popping his head up out of different holes and you keep smacking him back down with a mallot.
We need a bigger mallot. Didn't someone in the Chrysalis build say you could use the Chrysalis fuselage as a bat? Bob get that Chrysalis fuselage built, we need it!!! PS Remember Don this is all in good fun. Wayne |
| Thread Tools | |
| 'V' Tails | John Price | Modeling Science | 3 | Dec 02, 2002 09:31 AM |
| Where to get control horns for v-tails? | ferradas | Electric Sailplanes | 5 | Apr 24, 2002 07:56 PM |
| V tails and T Tails? | RCFlybry | High Performance | 1 | Mar 23, 2002 09:36 AM |
| V-tails | mudhead | Power Systems | 2 | Jun 20, 2001 09:49 AM |
| V-Tails vs Standard | DocMac | Electric Sailplanes | 2 | Jun 07, 2001 11:30 AM |
