Old Jul 11, 2008, 02:18 PM
critterhunter is offline
Find More Posts by critterhunter
critterhunter's Avatar
Joined Oct 2006
TGY DP 3a 1 Gram Brushless ESC ($20!)
Has anybody started a thread on this little guy yet? I'm tempted to start building some micro flyers that don't involve me stripping down more Aero Aces or my Piloto. Do they also carry cheap RXs, servos, and accuators? Haven't looked yet.
http://www.hobbycity.com/hobbycity/s...idProduct=7184
critterhunter is offline Find More Posts by critterhunter
Old Jul 11, 2008, 03:13 PM
Tim Cullip is offline
Find More Posts by Tim Cullip
Tim Cullip's Avatar
United States, NC, Pittsboro
Joined Aug 2003
I've ordered one (along with their new <5gm brushless motor), it has shipped, but hasn't arrived yet. Really looking forward to this.
Tim
Tim Cullip is offline Find More Posts by Tim Cullip
Old Jul 12, 2008, 01:29 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
bah, its only a single cell controller. it wont work for any bl edfs or anything like that.
derk is offline Find More Posts by derk
Old Jul 12, 2008, 06:05 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
Correction: It won't work for any 2 cell bl edf's....
NitroCharged is offline Find More Posts by NitroCharged
Old Jul 12, 2008, 06:35 PM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Bidproduct has what appears to be the same controller AND a 2g motor...Hummmm..??
http://bidproduct.com/part/Product_v...%20ESC_95.html
http://bidproduct.com/part/Product_v...MOTOR_238.html
I've had problems with small single cell brushless setups in the past. They didn't like starting the motor consistently. I had a Microbatics controller that worked with the motor, but only worker properly with the Microbatics RX and then someone offered me $100 for the controller (guess what happened to the controller).
Do I assume that the bidproduct combo has actually been tested, or do I assume too much??
Tim Wolff is online now Find More Posts by Tim Wolff
Old Jul 12, 2008, 07:11 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Hopefully, Tim C will give it a good work out and let us know the results.
Old Jul 12, 2008, 07:46 PM
Tim Cullip's Avatar
Joined Aug 2003
I'll gladly report on the ESC when it arrives (supposedly shipped on the 10th).
Now that 2gm motor sure looks inviting - I'll have to consider it soon. What a combo my 1gm MicroInvent Rx, 2 1.6gm Falcon servos, 1gm ESC, the 2gm motor, 100mah cell would make - the possibilities would be intriguing.
What I'd really like to see is someone come up with a lightweight small brushed esc output to brushless esc input converter so I could hook this 1 cell brushless esc up to a Parkzone cessna brick. Seems like it would an easy thing to build out of a simple microprocessor (just converting a high frequency brushed esc output PWM into a servo PWM input - one input, one output, simple program?).
Tim
Old Jul 12, 2008, 08:09 PM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Tim
If its a 2khz PWM motor output there are converters made to generate a standard PWM signal to drive a brushless ESC. Lots of people use them to convert the Walkera 4#3 helicopter to a brushless main motor, it runs on 1S Lipo.
I also have two of the 1 gram ESCs and two of the 2 gram motors coming, I am going to see if they can be used for tail drive on the Walkera 4#3 helicopter. Reliable starting is the challenge. I have a brushless 1S esc that starts the small motors 100% of the time perfectly but you need to assemble it yourself.
TheSteve is offline Find More Posts by TheSteve
Old Jul 13, 2008, 04:43 AM
methuso is offline
Find More Posts by methuso
A.K.A sir Crashalot
methuso's Avatar
Ístersund, SWEDEN
Joined Sep 2005
what 2 gram motor... what have i missed ??
/Ulf
methuso is offline Find More Posts by methuso
Old Jul 13, 2008, 09:38 AM
CA'ed fingers is offline
Find More Posts by CA'ed fingers
CA'ed fingers's Avatar
Montreal, Canada
Joined Feb 2003
this one: http://bidproduct.com/part/Product_v...MOTOR_238.html
CA'ed fingers is offline Find More Posts by CA'ed fingers
Old Jul 13, 2008, 09:48 AM
Tim Wolff's Avatar
Joined Sep 2002
Dang it. Ordered 'em both since they were in the cart
Added a note to my PP payment for the 3300 KV motor since I saw no other way to specify my choice.
Got a confirmation e-mail the next day. Will ship on 7-22 and take 12-22 days. I've also got nothing to put it in LOL.
Old Jul 15, 2008, 05:09 PM
busta1 is offline
Find More Posts by busta1
Joined Jul 2005
anyone received a 2gram motor or esc yet?
busta1 is offline Find More Posts by busta1
Old Jul 15, 2008, 07:28 PM
Tim Cullip's Avatar
Joined Aug 2003
I received the ESC and motor (the 5gm motor from UH, not the 2gm from the paypal site).
Here is some very preliminary impressions and measurements.
The ESC is tiny! Without any wires attached, the board is 0.8gm, with a connector and wires to attach it to my Falcon Breeze block it weights 1.0gm.
It could be made even lighter if you removed all connectors and soldered the wires directly to it - but I'm not going to bother with that.
The motor without mount is 4.8gm and with mount it is 5.0gm, include a parkzone cessna prop and it tops out at 5.3gms.
I don't have a fully charged single lipo cell, but I did hook it up to one that was at about 3.6v and the motor ran at 8000rpm on a GWS 3x3 (didn't measure the rpm of the cessna prop yet). Haven't hooked up a watt meter yet to see what amps it pulled (I'm pretty sure it is under an amp).
Start up and throttle response was pretty smooth (most of the time, some times the motor wanted to cut out above 3/4ths throttle, but I think it was something in the connections rather than an inherent problem of the motor/esc combo - but I'll have to investigate it further to convince myself of that. Haven't even read the manual yet to see what programming features are available for the ESC (timing is the main thing I'll look into).
Overall, I'm very pleased with the ESC and would buy more of them in the future. The motor is nice, but 5gm motors aren't that hard to come by these days and it'll take more time and testing before I am convinced it is something special.
I'll report later when I've run more tests (various props, amps, thrust, etc).
I'm real tempted to order one of the 2gm motors, I think that weight motor with this 1gm ESC would be quite a combo (especially if you hooked it up to a MicroInvent receiver and used actuators - you could have a whole flight system rx/esc/motor/battery/actuators at about 7gms).
Tim
Old Jul 15, 2008, 07:36 PM
Tim Cullip's Avatar
Joined Aug 2003
By the way, this is the motor I'm referring to: AD-C5 Micro Motor 4.6g Weight 3700Kv
Old Jul 16, 2008, 01:34 PM
busta1 is offline
Joined Jul 2005
thanks for the report Tim. I am gutted the 2 gram motors sold out before I ordered. They would be perfect for my plantraco servo rx and two toki servos aswell . Its amazing how quickly these brushless motors are being developed.
I brought the turnigy 4.5 gram motor from HC last month and thought 'great' but a two grammer! WOW!
Sold Great Planes Silver Series 12A Brushless ESC -$20 Etonic Aircraft - Electric - Power Systems (FS/W) 1 May 14, 2006 09:41 AM
Sold Jeti JES 18-3P brushless ESC, $20 Hoppla! Aircraft - Electric - Power Systems (FS/W) 0 May 03, 2006 02:54 PM
Discussion How to attatch 4-1 to Brushless ESC? BeechSkipperDude Micro Helis 1 Apr 17, 2006 12:03 PM
For Sale NIP TP 15A brushless esc $20 hotairflyer Aircraft - Electric - Power Systems (FS/W) 0 Mar 29, 2006 10:19 AM
Sold FS: Eflight brushless esc, 20 amp foss1997 Aircraft - Electric - Airplanes (FS/W) 1 Oct 01, 2005 06:09 PM
