Old Jul 10, 2008, 11:29 AM
oct2633 is offline
Find More Posts by oct2633
Joined Jul 2005
BESC vs. UBEC
Can someone help me on the definition/function of these two items? Are they interchangeable (same thing), or separate electronic devices with different uses?
oct2633 is offline Find More Posts by oct2633
Old Jul 10, 2008, 01:19 PM
ronin4740 is offline
Find More Posts by ronin4740
Wandering IT geek
ronin4740's Avatar
United States, NV, Reno
Joined Aug 2005
Well, I'll take a stab at this and hopefully someone will pop in and correct whatever errors I make with my explanation.
Some, but not all, modern ESC's have a battery eliminator circuit built into them. There are two basic types of these BEC's - linear and switched. The linear BEC's tend not to like higher voltage or higher amp draw from the servos and are usually only good if you're planning to run 4 servos up to the voltage that a 3 cell Lipo can provide. I believe this has to do with the amount of waste heat that a linear BEC produces when stepping voltage down to the 6V that the RX wants to see.
Switched BEC's seem to be rated to drive more servos at higher input voltages (4 cell Lipo and up) and can handle the amp draw of more servos (manufacturers have different specs on this). Newer ESC designs seem to have Switched BEC's rather than Linear BEC's
Finally there's the UBEC. This is a separate component that can be installed in the event that the BEC in the ESC is not rated for the application you're using it in. For example if you were using a Castle Phoenix 35A ESC with 6 servos and powering the motor/ESC/RX with a 4 cell Lipo you'd want to buy and install a UBEC as the Phoenix's BEC's are only good up to 3 cell Lipos and rated for 4 servos. Various UBEC's install similarily - they all tap the power lines coming from the battery to the ESC in some form. The ESC may or may not pass through them.
For more info on UBEC's see DimensionEngineering's site. Good info there:
http://www.dimensionengineering.com/
ronin4740 is offline Find More Posts by ronin4740
Old Jul 10, 2008, 01:35 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
To answer the question oct actually asked, BESC usually stands for Brushless Electronic Speed Control....it drives a brushless motor and is not really in any way related to a UBEC.
A UBEC is a standalone Battery Elimination Circuit which allows the main power battery to produce a lower voltage to drive the receiver and servos.
Some confusion may arise because many ESCs (brushless or not) have a built-in battery elimination circuit or BEC as ronin4740 says.
Steve
slipstick is offline Find More Posts by slipstick
Old Jul 10, 2008, 03:43 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
UBEC is a bandnameof switching BEC.
SBEC is both a brand name and a generic term for switching BEC.
SBECS generate interference, but a fairly constant amount of heat independent of load and supply voltage.
Linear BECS generate no interference, but a lot of heat, which gets worse with load and higher supply voltages.
Linear BECS are very cheap and come built into most ESCS.
Switching BECS are more expensive, and are usually sold separately, but more are being built into ESCS.
Both will shut down and crash your model if you exceed the ratings, but linear BECS will do it at surpsringly small loads, due to heat.
Old May 10, 2016, 03:24 AM
cougar33 is offline
Find More Posts by cougar33
cougar
cougar33's Avatar
waterloo . Ontario
Joined Sep 2005
now i am total confused here...
so dumb this down for me. BEC means you dont have to run a seperate battery pack to run the reciever.
opto means you HAVE TO RUN a battery pack...
UBEC means you dont have to run a battery pack ( because you are running a 2 cell or 3 cell MAX battery??
cougar33 is offline Find More Posts by cougar33
Old May 10, 2016, 05:55 AM
Staffs, UK
Joined Nov 2003
Old old thread but nothing much has changed in the last 8 years .
ESC with BEC built in means the ESC can supply power from the main battery to the receiver/servos so no separate battery needed.
OPTO ESC doesn't supply power to the receiver/servos so you either need a separate battery pack OR a separate BEC (sometimes called a UBEC). Nothing to do with 2 or 3 cell maximum though, most modern BECs can handle much higher voltages.
Steve
Old May 10, 2016, 08:33 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
There are two kinds of BEC, internal to the ESC or external to the ESC.
There used to be a external BEC that was sold as the "UBEC" meaning Universal BEC. The term UBEC has become a generic term that is used by some to refer to external BECs of any make or brand.
An external BEC can be connected to the same battery as the ESC to get more current than you can get from the ESC's internal BEC. The different connection types and schemes are well explained on Castle Creation's BEC page:
http://www.castlecreations.com/products/ccbec.html
Click on the "CC BEC Wiring Diagram" to see an image of the connections, there are other images there also.
Jack
jackerbes is offline Find More Posts by jackerbes
Discussion external battery Vs ubec pimaa Power Systems 0 Mar 17, 2008 09:24 AM
Discussion ESC Vs BESC VS UESC ashish7202 Power Systems 3 Mar 12, 2008 09:16 AM
Smartbec vs UBEC power Electric Ducted Fan Jet Talk 5 Oct 30, 2005 12:25 PM
SBEC VS UBEC for HV setup? tabbytabb Electric Heli Talk 16 Nov 10, 2004 11:48 AM
