This thread is privately moderated by JimDrew, who may elect to delete unwanted replies.
Old May 23, 2011, 10:36 AM
rebell is offline
Find More Posts by rebell
JustFlying
rebell's Avatar
Joined Dec 2005
Thanks Jim.
Since the Beta I am using offset on all my planes I am using and reversing on some. I did not notice any rebooting and it must be for the reason you mentioned as I do not fly far away and did not fly my gliders with it yet.
rebell is offline Find More Posts by rebell
Old May 23, 2011, 03:28 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
New official release is up - updater v2.8. This fixes the problem that the beta code had.
You can download the new version here:
http://www.xtremepowersystems.net/xdp/updater28.exe
JimDrew is offline Find More Posts by JimDrew
Old May 23, 2011, 05:19 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
By the way, this update does not alter your settings. So, after you do the update you will not need to re-bind or re-enter the changes you might have made for the offsets and/or reversing.
Old Aug 06, 2011, 09:14 AM
stick08 is offline
Find More Posts by stick08
nothing new under the sun
stick08's Avatar
Joined Jun 2006
XDP updater
Hello all !
I want to try to update, I am not sure what current firmware I have but I am confuse on the xps web site, they are three differents dowloading which one to download:
xdp_setup.exe
xdp_update.exe
updater28.exe
should I have to download the three, or only the updater28.exe ?
is it for my 3- 16 channel receptors ,and 20 channels.
is it ok also for the Nano ?
thank's for your help , I have read a lot in this thread but didnt found
stick08 is offline Find More Posts by stick08
Old Aug 06, 2011, 12:27 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
The updater28.exe is a PC application for updating the firmware of your XtremeLink system. The xdp_setup.exe is for installing all of the PC based applications. The xdp_update.exe is the latest version of the XDP application.
Old Aug 06, 2011, 05:33 PM
stick08 is offline
stick08's Avatar
Joined Jun 2006
Hi jim,
I tried to re install the xdp on my pc ( window 7 trough google chrome ) and got some warning messages :
1) xdp _setup.exe
"unable to execute file: C:\Program Files (x86)XPS\USB\OS_Detect.exe
CreateProcess failed; code 740"
2) xdp.update.exe
language file is missing or corrupted!
please re-install this software!
3) updater v2.8 is ok !
can I trust the updater and update all my receptors, including the Nano ?
thank's
Old Aug 06, 2011, 08:27 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Run the xdp_setup.exe in administrator mode. You don't need the xdp_update.exe at all.
Old Aug 07, 2011, 10:42 PM
GEORGE III is offline
Find More Posts by GEORGE III
Bunbury, WA, Australia
Joined Oct 2006
G'day Jim,
Tried to flash one of my V3.4 Rx's to 3.8 this morning and CPU is non flashable.
Is it worth/necessary to send back, as I want full hopping mode, and not sure whether I have it in V3.4.
Maybe easier to wait for the new system to arrive.
Cheers,
Ron.
GEORGE III is offline Find More Posts by GEORGE III
Old Aug 08, 2011, 10:04 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Full time hopping was added starting with v3.0... so, you already have it. You can see a history of changes to the firmware on our XDP page.
Old Aug 11, 2011, 08:35 AM
stick08 is offline
stick08's Avatar
Joined Jun 2006
non flashable
Hi Jim,
received today in France my RX 8 channel I am surprise xdp show it is "non flashable CPU" is it a mistake from your side ?
my IFS RX are all CPU flashable so why the one I receive from you is not ?
can you explain me whats mean " flashable CPU "
do this mean your RX are less sure than my IFS Rx I am confuse with all this technical terms ,
thank's for your explanations,
Dan
NONE of our original product line are stated as being in-field flashable. However, nearly everything we have produced since October 2008 has this ability. Because we could never be guaranteed which CPU we would receive during production, we could not make this an officlal feature with the original product line. All of our new products do have a flashable CPU.
Old Aug 11, 2011, 09:46 AM
stick08 is offline
stick08's Avatar
Joined Jun 2006
now I have an Yellow/orange led !
Hi,
I run my RX ( 8 channel ) just received today and always get an Orange/yellow solid , please do not tell me its a power issue, I am aware of this.... testing also
my IFS RX led stay solid green, this is the prove that this is not a power issue ( I flew my Hawk jet yesterday with it )
the XPS got today for one or two second is green and move to yellow/orange with or without any servo plugged, battery is a fully charged A123- 2,3,mAh, 6,7 volts.
My TX firmware is 3.8 with "CPU Flashable" maybe the reason of the issue is TX is flash able but not the XPS ?
the system works including failsafe but why with a yellow/orange...
pls help as I want to fly safe !
Dan
Old Aug 11, 2011, 01:32 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Originally Posted by stick08 View Post
Hi Jim,
Dan
This means that the CPU in that receiver can not be upgraded by using the XDP. We don't state this as a feature (as noted in the quote you provided). There is no functional difference in the receiver.
Old Aug 11, 2011, 01:33 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Hi,
I run my TX just receive today and always get an Orange/yellow solid , please do not tell me its a power issue, I am aware of this.... testing also
Dan
So, with a fully charged battery and no servos plugged in, you get an orange LED after you have connected to the transmitter?
Old Aug 11, 2011, 02:16 PM
stick08 is offline
stick08's Avatar
Joined Jun 2006
Hello Jim,
yes I got for 2/3 second green and after Yellow/orange , I connect first the TX and after the RX, if I connect first the RX I have a fast flash Red until I connect the TX
Old Aug 11, 2011, 06:46 PM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Which port are you plugging power into? Have you tried changing ports? Have you tried a different battery?
