Joined Jun 2006
Hi
Ah ok, I allready have the 1.3 firmware in my nano reciever, witch is mounted in a Trex450 pro, allmost completly surrounded by the carbon fiber frames. But I still get 164 feet in the range test (reduced transmitting strenght) and that is when the reciever antenna is pointing straight towards the transmitter, it`s a very nice product you and your crew made. Regards Bo |
Joined Jun 2006
Meanwhile I use some shink tubing Regards Bo |
Joined Jun 2009
Older receivers??
Hello there
![]() I am writing from finland, so please for give me if my english is nor so good. But, anyway. I bought a JR radio from my friend. The radio has XPS tx module and two receivers. Now I like to order more receivers. I do not know what is the firmware version. Previous owner do not know How old those gears are. 1. So do I have to update all the tx module and those two reveicers? 2. Where I can order those reveicers? (From the XPS -web pages?) Regards, Kamppi
Lake Havasu, AZ
Joined Jun 2005
The only way to know what version firmware you have is by using our XDP (or Graupner's version).
You don't ever "need" to update firmware. We have added many new features since v3.0 was released. We do not sell to Europe. You would need to purchase receivers from Graupner. |
Lake Havasu, AZ
Joined Jun 2005
After putting the receiver into binding mode, you insert the jumper again and the LED will then turn solid (slave mode). You can do this as many times as you want for each slave receiver. The last receiver must be left in normal binding mode (flashing fast LED). When you then put the transmitter into binding mode, all of the receivers will bind to the transmitter and all of their LEDs will turn off. Power everything off and then back on... you have a master and as many slaves as you like.
