Old Jul 06, 2008, 06:38 PM
Mike Fortin is offline
Find More Posts by Mike Fortin
Drones Yaay!
Mike Fortin's Avatar
United States, FL, Orlando
Joined May 2006
DIY Brushless ESC
Does anyone know where I can find some info on a Brushless ESC?
I am interested in trying to build one of my own.
Thanks.
Mike Fortin is offline Find More Posts by Mike Fortin
Old Jul 06, 2008, 09:45 PM
Tomapowa is offline
Find More Posts by Tomapowa
R/C Electro-Gadgeteer
Tomapowa's Avatar
N.E. USA
Joined Oct 2003
Do an advanced search here in the forums for "DIY BRUSHLESS" (search title only). A few that should pop up are:
http://www.rcgroups.com/forums/showthread.php?t=181247
http://www.rcgroups.com/forums/showthread.php?t=140454
Tomapowa is offline Find More Posts by Tomapowa
Old Jul 07, 2008, 03:56 AM
David T is offline
Find More Posts by David T
UK
Joined Aug 2000
I found Bernhard Konze's 'Flea' code one of the simplest to understand. Although my goal was to convert it to a FF timer I put a great deal of effort into commenting his code and it still works as a normal ESC http://www.flyelectric.ukgateway.net/avr_ff_timer.htm
The first few pages of this Microchip paper (AN1160) is quite good at explaining some principles http://www.microchip.com/stellent/id...pnote=en533912
This thread will help you appreciate how hard it was designing these from scratch http://www.rcgroups.com/forums/showthread.php?t=200567
Regards, David.
David T is offline Find More Posts by David T
Old Jul 07, 2008, 10:51 PM
bnrusso is offline
Find More Posts by bnrusso
early retired & loving it
USA, AZ, Kingman
Joined Aug 2005
REMOVED, posted in wrong area.
bnrusso is offline Find More Posts by bnrusso
Old Jul 08, 2008, 03:02 AM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Several diy designs:
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Jul 08, 2008, 03:13 PM
mjsas is offline
Find More Posts by mjsas
Joined Nov 2007
You may find it much easier to modify an existing ESC. You can add the test points for in circuit programming and just work with the code on an existing design. Or you can replace the FETs with larger and higher voltage FETs to make a much larger ESC from a small one, just start with a design that uses IRF FET drivers.
You can find a smoked ESC and rebuild it, generally only the FETs get smoked or sometimes the BEC circuit.
It is much easier to take small steps instead of trying to gobble the whole thing at once.
mjsas is offline Find More Posts by mjsas
Old Jul 08, 2008, 09:36 PM
Unterhausen is offline
Find More Posts by Unterhausen
5 miles from the geographical center of Pennsylvania
Joined Aug 2005
I like the idea of starting with an existing design. There is source code floating around for some of the commercial units.
Unterhausen is offline Find More Posts by Unterhausen
Old Jul 09, 2008, 09:46 PM
mjsas is offline
Joined Nov 2007
Since a development system will be needed the difference in cost between a cheap ESC and a processor board is only a few dollars, so why not use an ESC. The lock bits in the micro may be set, I think that means the micro has to be replaced with an unlocked micro.
To build a DIY ESC means working with surface mounted parts so it should not be a problem.
Old Jul 29, 2008, 04:48 AM
megamatt is offline
Find More Posts by megamatt
must build something!
megamatt's Avatar
in front of a computer!
hey guys,
im really interested in the idea of a diy bl esc,ive got and old 12amp bl esc,but an fet on one of the 3 phases blew,could i remove the dead fet an one from each of the other 2 phases?i know it will reduce the amout of amps it cvan take but i only want to run a 4 amp motor on it.can anyone help?thanks.
megamatt is offline Find More Posts by megamatt
Old Jul 31, 2008, 10:27 AM
megamatt is offline
megamatt's Avatar
i think ive wasted my time posting here.
FAQ five(5) diy brushless ESC designs Ron van Sommeren DIY Electronics 109 May 12, 2016 01:16 PM
Diy brushless esc slowflyer90 DIY Electronics 66 Mar 25, 2006 07:56 AM
Best DIY Brushless ESC Kit? gfcermak DIY Electronics 10 Aug 25, 2004 01:23 AM
group order for diy Speedy-BL brushless ESC family Ron van Sommeren Electric Plane Talk 5 Jul 27, 2003 10:56 AM
