Old Aug 14, 2008, 05:26 PM
Elliot9 is offline
Find More Posts by Elliot9
Joined Jan 2006
Josh, I want to add my appreciation to all the others on this thread. Brilliant!! IMO you are one hell of a nice guy!
I've read most of the thread and downloaded the videos so far. They are making 3D much clearer for me. I'm a newbie to 3D and your clinic is already making me focus my stick twidling to get something close to Elevator, Harriers and Hover. Well, at least on the simulator!
Got to replace the prop on my Katana MD and get out there and try again for real. Just struggling with wing rock. Gonna move the c of g back a bit and i think you're right, too much expo can cause over compensation, so i'll cut that down.
Please keep up the great work!
Elliot
Elliot9 is offline Find More Posts by Elliot9
Old Aug 14, 2008, 05:30 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Thanks Elliot.
BoneDoc is offline Find More Posts by BoneDoc
Old Aug 25, 2008, 10:27 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
New VIDEO added to the Harrier Clinic
3D CLINIC VIDEO #1d: HARRIER TIPS FROM BEN "BLUCOR BASHER" AND WHAT MAKES THE 47" SHP A GREAT HARRIER PLANE
Old Sep 09, 2008, 08:45 AM
propnut07 is offline
Find More Posts by propnut07
United States, FL, Palm Harbor
Joined Feb 2007
I think the video is fantastic .it's easier to learn by example sometimes than simply reading a book,I would like to suggest you and Ben make a video outlining a goodset up for a 3Dhobby plane,by way of video take us thru an install with tips for a good 3d set up on throws balance props etc,
propnut07 is offline Find More Posts by propnut07
Old Sep 09, 2008, 10:20 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
In the planning stages (at least in my mind ).
Old Feb 21, 2010, 10:27 AM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
I paid my bills, so they're good . Some comps with blocked access can't open them because they think my website is not good for work... for some odd reason .
Old Jun 30, 2010, 08:13 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Good info
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Dec 06, 2011, 04:45 PM
phil alvirez is offline
Find More Posts by phil alvirez
Windsor, Canada, near Detroit
Joined Jul 2007
faster to download videos?
am trying to watch these videos but my pc when is in the mood to accept trying, takes over 5 minutes to download each 1.
is there a faster way to watch them?
thanks
edit: just learned that they are easily available at another forum. just had to register.
phil alvirez is offline Find More Posts by phil alvirez
Old Oct 14, 2012, 03:01 PM
yaktork is offline
Find More Posts by yaktork
French Polynesia, Windward Islands, Papeete
Joined May 2012
Radio setup
Originally Posted by BoneDoc View Post
A question arose about my radio setup, and here's what I use:
High Rates:
Ailerons 45 degrees with 45% Expo
Elevator 50 degrees with 60% Expo
Rudder 50 degrees with 70% Expo
Ailerons 25 degrees with 30% Expo (almost never used)
Elevator 25 degrees with 30% Expo
A recommendation made by 3DH on their aircrafts
Low/Precision Rates (in degrees and inches) and Corresponding Exponential
Aileron 15 degrees 30% Expo
Elevator 13 degrees 30% Expo
Rudder 45 degrees 75% Expo
High/3D Rates (in degrees and inches) and Corresponding Exponential
Aileron 28 degrees 75% Expo
Elevator 45 degrees 85% Expo
I tend to use lower less expo than what the consensus. I compensate for that by making smaller movements. The only time I really use lo rate ailerons is if I'm trying to make precision rolling circles. Otherwise, the elevator is the only thing I switch back and forth.
There's no real "right" / "wrong" answer about this. With the aileron high rates on at all time, it allows me to make cleaner and faster snaps, which helps a lot when I'm doing my KE to KE snaps. The less expo on ailerons also allows me to make my corrections early when the plane rocks from the wind gusts. The down side is that if you're not used to it, you can potentially over corrects. I tried the same setup on Doc Austin's SR, and from the brief flights he's had on it, he liked it as well.
Hi BoneDoc. For the expo, it is negative or positive? I use JR transmitter. Thank you
yaktork is offline Find More Posts by yaktork
Old Oct 06, 2013, 11:19 AM
stokesrl is offline
Find More Posts by stokesrl
United States, TN, Franklin
Joined Apr 2013
so where did all the videos go?
stokesrl is offline Find More Posts by stokesrl
Old Oct 06, 2013, 12:02 PM
C_Watkins is offline
Find More Posts by C_Watkins
This is NOT a TOY?
C_Watkins's Avatar
United States, GA, Atlanta
Joined Jul 2011
Looks like his domain expired and one of the domain squatters picked it up before it was renewed.
Meantime, there are quite a few of his videos out on YouTube
https://www.youtube.com/user/bonedoc1/videos
C_Watkins is offline Find More Posts by C_Watkins
Old Jun 14, 2014, 06:11 PM
CC268 is online now
Find More Posts by CC268
United States, AZ, Cave Creek
Joined Aug 2011
Links don't work?
CC268 is online now Find More Posts by CC268
Guillow's FOKKER DR-1 TRIPLANE Randall Parkflyers 8 Mar 03, 2010 06:15 PM
Question What parts needed to convert night ranger 3d's 4 in 1 system to seperate or similar? delamar Micro Helis 0 May 07, 2006 07:26 AM
Wayne's Gulp Pictures #1 LWThompson Slope 39 Mar 15, 2005 03:28 PM
F/S: Aiptek Pencam 1.3 $95 New In Box bankitguy Aircraft - Electric - Airplanes (FS/W) 3 Dec 31, 2002 04:06 PM
WTB: Guillow's Fokker DR-1 TriPlane Plans or kit. d_trafalgar Aircraft - Electric - Airplanes (FS/W) 1 Nov 11, 2001 01:52 PM
