Old Jan 28, 2003, 02:53 PM
thazy2 is offline
Find More Posts by thazy2
thazy2's Avatar
Pueblo Colorado
Joined Mar 2002
any good link on How to balance blades?
Some pics would b nice......
I have a couple of balancer but they dont seem to move or shift untill i put a lot of tape on one or the other.
Ep concept has vibration at low head speed. Vibraition gone at half stic. Tracking is dead on even w/ the foam blades.
Current balancer:
Dubro
and Helimax
thazy2 is offline Find More Posts by thazy2
Old Jan 28, 2003, 06:20 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
I would recommend using the KSJ-528 blade balancer...it works very well for me.
Toshi
TMorita is offline Find More Posts by TMorita
Old Jan 29, 2003, 12:24 PM
thazy2 is offline
thazy2's Avatar
Pueblo Colorado
Joined Mar 2002
thats the one i have...........already
OMG you almost half to put the entire roll of tape on the blade the to get it to move. I think there is too much friction. It seems smooth enough but i guess the foamy blades r too light...
Old Jan 29, 2003, 01:33 PM
K.C. is offline
Find More Posts by K.C.
Victim of Gravity
K.C.'s Avatar
Cary, NC
Joined Sep 2001
I balanced my Raptor blades using a threaded rod with a couple of washers & nuts, a small hobby vise, and a razor blade. HEre's my method:
1) Bolt the blades together with the threaded rod. I do this with the leading edge down on a flat surface to make sure they're straight, and the tips pointing away from each other. The rod acts like a balance so I can figure out which blade is heavier and mark it as such.
2) Clamp a razor blade in the vise, and balance the blades on it individually to find their spanwise CG's.
3) If the CG's are noticably different, hold the blades together and mark the CG from the heavy blade on the lighter blade.
4) Add tape to the tip/root of the lighter blade until it's spanwise CG matches the heavy blade.
5) Bolt the blades back together and add tape at the spanwise CG's to get the blades to the same weight.
Obviously, this method doesn't match the chordwise CG's - but I don't think I'll notice at my skill level.
If you're gonna buy a balancer, I hear the KSJ-528 (Toshi's recommendation) is very good.
KC
K.C. is offline Find More Posts by K.C.
Discussion Any good deals on HB FP2 Main Blades? Discusman Micro Helis 0 Nov 24, 2006 08:09 PM
Know of any good deals on power supplies? Ben74 Batteries and Chargers 7 Aug 06, 2003 01:28 PM
Any Good Deals on Minimax's HobbyWatch Parkflyers 1 Oct 10, 2002 06:48 AM
Any new ideas on how to stiffen a Zagi wing any further? slowflyer Foamies (Kits) 60 Jan 05, 2002 08:26 PM
