Old Jan 28, 2003, 10:00 AM
dirtdiver is offline
Find More Posts by dirtdiver
Throttle,,What's that?
dirtdiver's Avatar
Joined Sep 2002
Master Airscrew or APC?
Im wondering what some of you think. I have been using APC thin E props and breaking them about every 3 flights. On a whim i bought some MAS wood E props. I have about 20 flights with the same prop. There lots stronger but there balance stinks some are almost perfect others need lotsa tape added to balance.
What type of non folder prop do you use?.
Pat
dirtdiver is offline Find More Posts by dirtdiver
Old Jan 28, 2003, 10:31 AM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Hi Pat
I only tried an APC-E on a bellyflopper for three flights - guess what happened
My best results next to APC-E in the air have been with "Aeronaut" fixed blade props - doesn't seem to matter whether you go for the white, slightly cheaper, 'glass or the black, more expensive ones either! One lasted me three years and lots of flying on my bellyflopping Embat, before it succumbed to rough grass. Hobby Lobby sell them.
MAS wood/E, where it counts, suck juice hard once you get them above 6000 RPM. You'll find much higher current draws at higher RPM, for little gain. Wood, being a really variable kind of material, is more likely to lead to the imbalance you've seen than 'moulded' props.
Regards
Dereck
Dereck is offline Find More Posts by Dereck
Old Jan 28, 2003, 11:22 AM
mickydee is offline
Find More Posts by mickydee
Hemet, California, United States
Joined Aug 2001
Hi Dirt Diver,
Check out the "Throw away you speed 400 motors" (or something like that) thread. Sal C did alot of testing and found in many cases the regular nylon Master Airscrew props out performed the APC E props.
He included lots of tables so you can compare the date for yourself.
Best Regards, Mickydee
mickydee is offline Find More Posts by mickydee
Old Jan 28, 2003, 12:36 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Ah. The snapping APC syndrome.
Touch wood () I haven't broken one in a while. The secret is to not brake them Gosh those freudian slips...and kill the throttle just before touchdown.
Then they get flicked out of the way.
Old Jan 28, 2003, 07:14 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
So it's not just me then?
My little Minibat flies superbly on a 7x5 APC, except that it would be cheaper to run a glo-motor! (Did I really say that? )
I'm trying to find a comparable folder - the Aeronaut 7.5x4 comes closest so far - but it seems a shame that each flight can cost around 4 for a prop. It would be cheaper to fit those draggy wheel-things to it!
tim
tim hooper is offline Find More Posts by tim hooper
Discussion Master Airscrew Vs. APC MTXMUGEN North Coast Electric Flyers 3 Aug 07, 2007 08:20 AM
Wanted Master Airscrew or Astro gearbox imsofaman Aircraft - Electric - Power Systems (FS/W) 6 Mar 02, 2007 11:18 PM
Question APC or Master Airscrew - who has the better 3-blade prop? gromitvt10 Electric Plane Talk 5 Aug 30, 2006 11:33 AM
which is better APC, APC slow, master airscrew??? Julian537 Power Systems 2 Sep 02, 2004 03:09 PM
APC 5.5x4.5 or Master Airscrew 5.5x4.5 ? Al P Electric Plane Talk 4 Jun 22, 2002 06:15 PM
