Old Jul 03, 2008, 10:03 AM
TerryE is offline
Find More Posts by TerryE
Glassman
TerryE's Avatar
Leesburg, VA
Joined Aug 2004
Mark;
That is just soooooo cool.
Definately interested. Will be watching, and wishing you the best.
Terry
TerryE is offline Find More Posts by TerryE
Old Jul 03, 2008, 10:25 AM
j2m2t2 is offline
Find More Posts by j2m2t2
j2m2t2's Avatar
AZ
Joined Feb 2007
Amazing, well done.
j2m2t2 is offline Find More Posts by j2m2t2
Old Jul 03, 2008, 10:30 AM
OFFA 1 is offline
Find More Posts by OFFA 1
Joined Dec 2003
Will your cutter work with AutoCad or TurboCad drawings, or does everything need to be done in Sketch Up?
..................Moose...................
OFFA 1 is offline Find More Posts by OFFA 1
Old Jul 03, 2008, 11:12 AM
weflyon is offline
Find More Posts by weflyon
Woodland, CA , USA
Joined Sep 2001
Well done, mate!
weflyon is offline Find More Posts by weflyon
Old Jul 03, 2008, 11:30 AM
ChrisFP is offline
Find More Posts by ChrisFP
Joined Sep 2006
Looks great.
Any reason for such a large gap in the cuts?
ChrisFP is offline Find More Posts by ChrisFP
Old Jul 03, 2008, 11:37 AM
newblet27 is offline
Find More Posts by newblet27
Canada, eh?
Very cool! I can see a lot of people using this, especially kit builders. However about the plans if I payed $40+ dollars I would want a hard copy or at least a CD. I'm sure a lot of people who experience computer crashes or forget their passwords feel the same way. For about $20-$30 an electronic copy would be fine.
But I can't express how cool it is!
newblet27 is offline Find More Posts by newblet27
Old Jul 03, 2008, 12:01 PM
High Flyin' is offline
Find More Posts by High Flyin'
Out the Window
High Flyin''s Avatar
United States, FL, Alachua
Joined Jul 2004
Well I am just blown away!!! What a great design. The possibilities are tremendous, I can see other foamie builders sharing the code for aircraft and they all have one of these Phlatprinters to turn out the aircraft. Have you tried to cut EPP yet? I really like the bipe...you should produce some kits to sell to others also.
Model airplane clubs could put one together and share the costs and still turn out LOTS of airplanes.
Ray
High Flyin' is offline Find More Posts by High Flyin'
Old Jul 03, 2008, 12:38 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
akmoose43 does everything need to be done in Sketch Up?
No as long as you can save as a dwg or a dxf you can load it into Sketchup and lay it on the cutting template your ready to apply the plugin to convert the part files into Phlatcode
ChrisFP reason for such a large gap in the cuts?
The gap I think you are referring to is the cut? The bit I use is 1/8" fishtail grout removal bit from Lowes. You could use a smaller bit. We are writing the plugin to compensate for that.
newblet27 I would want a hard copy
The plans are a part of the build, what I mean to say it that you spray the wood and attach the plans right to them and in turn they are a part of the final printer. You would get the plans in a tube 2'x3' and then follow the build log from there.
Ray I have not tried EPP yet but I suspect that it will work fine. The foam I was using in that last video (How it works) was all I had left from a really crappy stack of fan fold. It had more and deeper waves than any other fan fold I have had. But Depron on the other had works great, I only had a sample pack and now that is gone. I wanted to do that test of cutting two stacks at once of black and white and it exceeded my expectations.
After I had used it all up I had the idea to create a chess set out of foam
So I now if you tape two sheets of Depron together, and make one cut for each piece you get the entire board with both players and all the squares. Its pretty cool and I can't wait to get some more Depron to try it out.
Thank you all for the questions and great remarks.
kram242 is offline Find More Posts by kram242
Old Jul 03, 2008, 12:47 PM
kwinters is offline
Find More Posts by kwinters
Autryville, NC
Joined Dec 2006
I'm phlabbergasted - absolutely awesome job.
KW
kwinters is offline Find More Posts by kwinters
Old Jul 03, 2008, 12:56 PM
kram242 is offline
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
lol thanks Winters
Mark
Old Jul 03, 2008, 01:03 PM
totalywicked is offline
Find More Posts by totalywicked
Insert comment here:
totalywicked's Avatar
Placentia, CA
Joined Feb 2006
This is amazing.
totalywicked is offline Find More Posts by totalywicked
Old Jul 03, 2008, 01:10 PM
kwinters is offline
Autryville, NC
Joined Dec 2006
Just checked out your website and learned...it's your birthday. So....
Old Jul 03, 2008, 01:14 PM
kram242 is offline
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Hey Thanks Winters,
its also the Phlatprinters Birthday!
BTW I have a ton of designs that are sketchup models that I have not posted and Im sure the guys over at the Skechup parts thread would want to share as well at I am thinking about posting another thread for just sharing the sketchup files ready to be printed.
Sound good to you guys?
Mark
Old Jul 03, 2008, 01:16 PM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
OK....as soon as the plans are available I'm buying them. (Yes I voted in your poll) I love the rapid prototyping this will allow me to do....plus I hate cutting foam.....
When will the plans be available?
Iíll be an early adopter!!!!!!!
thewz is offline Find More Posts by thewz
Old Jul 03, 2008, 01:19 PM
kram242 is offline
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Soon very soon
Thanks!
Mark
