Old Dec 09, 2008, 02:18 AM
cptdragn is offline
Find More Posts by cptdragn
If it flys,I can crash it
cptdragn's Avatar
USA, AL, Fairhope
Joined Jul 2007
Originally Posted by jbourdon
I think,
according to: http://www.motionking.com/Products/H..._0.9degree.htm
my motionking stepper (23HM6403) is rated: 2.5A
acording to: http://www.easy-cnc.com/web/download/Manual3Axis(NEW).pdf
page 1, max current is 2.5A per axis
page 4, vref is 2*desired current
so 5v isn't a crazy value for me, unless I miss something. But I could be mistaken
Teach me to try to answer something half asleep.
You are correct,
The manual says that to have 1.8a you would adjust the V-ref to 3.6 VDC on your voltmeter. I know I remember somewhere back in this or one of the other phlat threads that hector ( easy-cnc ) said not to exceed the 1.8a setting as it could damage the board if not the motors.
In my case, I have them set for 2.5 vdc on each axes and they seem to be running fine. That is very close to the setting ( arrow on V-ref set to stright up and pointing at the chips ) Mark called for in the setup video.
When I was adjusting them, you really had to bearly move the v-ref to get a major jump in volts. Took a few mins to get it dailed in.
Tony
cptdragn is offline Find More Posts by cptdragn
Old Dec 09, 2008, 02:23 AM
cptdragn is offline
cptdragn's Avatar
USA, AL, Fairhope
Joined Jul 2007
Originally Posted by Kwok_Yu
Isn't the labeled setting 1.2V not Amps, so the orginal motors are running at 0.6A?
That I can't answer as I can no long see those labels to look. Still, it does not "sound" like thats correct because setting the V-ref to what mark called for will give you 2.5vdc on a voltmeter.
Tony
Old Dec 09, 2008, 01:50 PM
Kwok_Yu is offline
Find More Posts by Kwok_Yu
Maryland, USA
Joined May 2004
Tony
A few people have also burned up their motors, but with no conclusion as to why. The problem is there is no data sheet on the orginal motor. But having recently researched a few replacements, I wouldn't be surprised if this motor can't take more than 1 amp. For one thing the resistance seems high at 10 ohms. Also, from this post easy-cnc says max is 1.6V Vref, which means 0.8A max:
http://www.rcgroups.com/forums/showp...postcount=1684
Here is a pic of the label:
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Dec 09, 2008, 03:43 PM
cptdragn is offline
cptdragn's Avatar
USA, AL, Fairhope
Joined Jul 2007
I see what you are saying and it would appear that you are correct about the settings on the motors. I know on mine they have been set to 2.5 vdc since day one and they do not even get very warm. Either the motors or the heat sinks.
It may be that I got lucky or for whatever reason my motors are happy at that setting.
In any case, it has been my understanding that anyone that has been having problems seems to have had them addressed promptly by Mark. I know he did when I had my board problem.
Tony
Old Jan 10, 2009, 10:07 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Thanks Tony. We do try to offer the best customer service that we can.
kram242 is offline Find More Posts by kram242
Old Jan 20, 2009, 10:07 AM
Taoweiji is offline
Find More Posts by Taoweiji
Dark Lord of the Sith
Taoweiji's Avatar
Conifer, CO
Joined Sep 2008
Ok, the wife won't let my get my own Phlatprinter, something about forgetting an anniversary...so:
I am looking for somebody who can cut me some foam for a few models, specifically the Dash-8 Q400 and Isreali Kfir or Mirage III....any takers?
Taoweiji is offline Find More Posts by Taoweiji
Old Jan 21, 2009, 10:18 AM
edge5foamy is offline
Find More Posts by edge5foamy
There is no place like Hodges!
edge5foamy's Avatar
United States, GA, Byron
Joined Mar 2007
Just ordered my Phlat-Premium kit! Cant wait!
edge5foamy is offline Find More Posts by edge5foamy
Old Jan 21, 2009, 12:38 PM
edge5foamy's Avatar
Joined Mar 2007
Also, I will be using all differint size sheets of foam with mine. What do I need to do on the computer to set what size sheet I am using at the time?
Old Jan 21, 2009, 06:07 PM
66tbird is offline
Find More Posts by 66tbird
To many projects
66tbird's Avatar
USA, AZ, Litchfield Park
Joined Aug 2004
The Phlatprinter sketchup plugin makes that real simple. Also check out the phlatforum, lot of great info and peeps
66tbird is offline Find More Posts by 66tbird
Old Feb 23, 2013, 03:54 PM
garrcass is offline
Find More Posts by garrcass
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
Bump
garrcass is offline Find More Posts by garrcass
Old Feb 23, 2013, 10:09 PM
dz1sfb is online now
Find More Posts by dz1sfb
Ken's CAD Models
dz1sfb's Avatar
Attica, MI
Joined Dec 2006
Nice to see this thread get a bump. Still using the Iron Phlatprinter and have cut around a thousand kits since its start up.
Ken
dz1sfb is online now Find More Posts by dz1sfb
Latest blog entry: Mini H Quad Project
Old Feb 24, 2013, 01:42 AM
garrcass is offline
bucket of prop wash
garrcass's Avatar
reddinng CA
Joined Nov 2007
Ken
I am looking to talk to some phlat printer owners about a part I want to make. http://www.rcgroups.com/forums/showthread.php?t=1838376
Old Feb 24, 2013, 10:03 AM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Ken
How about posting some pictures of your machine and kits?
bz1mcr is offline Find More Posts by bz1mcr
Old Jun 03, 2013, 05:58 PM
L0keman is offline
Find More Posts by L0keman
L0keman's Avatar
Keesler AFB, Biloxi MS
Joined Sep 2004
Hey guys. Will this cut through thin pieces of carbon fiber (for quad frames and such)?
Also, does phlatprinter ever run any sales? I have a specific number I won't go above and they are close, but not quite.
L0keman is offline Find More Posts by L0keman
Old Jun 03, 2013, 08:29 PM
kram242 is offline
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Hello L0keman. The Phlatprinter was specially designed to cut sheets of foam. Carbon Fiber is a very hard material and is not an ideal cutting material.
Currently, we are in the process of redesigning the Phlatprinter using V-Slot which is an aluminum extrusion. We are then going to be releasing the Phlatprinter OpenSource so you can pick and choose what materials you want to include in your build. The total cost of the Aluminum Phlatprinter is yet to be determined because the design is not complete. We hope to have this done in time for the indoor cold months that will be upon us before we know it.
Thank you for your interest!
If you or anyone would like to be added to the waiting list, please contact us at phlatboyz@phlatboyz.com.
Thank you,
Mark and Trish Carew
Phlatboyz, LLC
