Old Jul 10, 2009, 05:58 PM
Bajora is offline
Find More Posts by Bajora
AA6JB
Bajora's Avatar
Joined Sep 2004
I have the long screws for the axels but no donuts in sight. Nada problem, LHS to the rescue!
Bajora is offline Find More Posts by Bajora
Old Jul 10, 2009, 06:07 PM
lance dalton is offline
Find More Posts by lance dalton
C.H.E.A.P.
lance dalton's Avatar
Chino Hills, CA.
Joined Nov 2004
Dubro makes a nice set of large wheels. You'll probably have to get bigger bolts to fit the hub mounting hole. I think the bolts for the Yak are 2mm, pretty small.
Lance
lance dalton is offline Find More Posts by lance dalton
Old Jul 10, 2009, 08:15 PM
Ron Williams is offline
Find More Posts by Ron Williams
slow but inefficient
Ron Williams's Avatar
Riverhead NY USA
Joined Dec 2000
Lance
Yes, the Yak/Flash axles are skinny and break too easily. I second the DuBro wheels. I saw a similar L.G. with a piece of music wire all the way across between the legs with heat shrink or something similar locating the wire and holding the wheels on. It made the L.G. much stronger.
Ron Williams is offline Find More Posts by Ron Williams
Old Jul 10, 2009, 08:39 PM
groovejet is offline
Find More Posts by groovejet
How many planes is too many?
groovejet's Avatar
Australia, VIC, Melbourne
Joined Aug 2007
I use these cheap Hobby City 50mm wheels:http://www.hobbycity.com/hobbycity/s...idproduct=3895
I attach them using a small piece of CF rod poked through the wheel and the LG axle hole. I put fuel tube on each end of the CF rod and use a drop of CA to hold it on. I find that this setup is more durable than the flimsy bolts that ship with the Flash and Yak.
groovejet is offline Find More Posts by groovejet
Old Jul 10, 2009, 10:07 PM
C.H.E.A.P.
Chino Hills, CA.
Joined Nov 2004
I used these 65mm and upgraded the bolts to 2mm allen head with locknuts. I've broke two wheels, one at a time, but the bolts have held up. Adds about a gram from the stock wheels I received.
Lance
Old Jul 11, 2009, 03:50 AM
Mike Smart is offline
Find More Posts by Mike Smart
Mike Smart's Avatar
Aylesbury, Buckinghamshire, Great Britain (UK)
Joined Jan 2000
Mine are the same as Groovejet's but 45mm diameter. I still use the supplied bolts without a problem.
Mike Smart is offline Find More Posts by Mike Smart
Old Jul 11, 2009, 04:02 AM
groovejet's Avatar
Joined Aug 2007
Mike,
That's coz you haven't learnt to crash like me
Your spats look nice. I didn't bother using spats on the Yak coz my Flash spats only lasted a few days as you might recall
Old Jul 11, 2009, 08:02 AM
Jeremy05 is offline
Find More Posts by Jeremy05
Joined Aug 2008
I just got my RC Factory Yak kit a few days ago and noticed that it did not have any push rods for the ailerons. The instruction say that there should be push rods. Did anyone else have this problem? Did it have micro push rods with the kit, or full size?
Jeremy05 is offline Find More Posts by Jeremy05
Old Jul 11, 2009, 08:16 AM
Bajora is offline
AA6JB
Bajora's Avatar
Joined Sep 2004
Ditto for me (Post 747 above)
Thanks for all of the help on the wheels/tires folks.
Old Jul 11, 2009, 12:36 PM
paintball_kidz is offline
Find More Posts by paintball_kidz
Epic Huckin'
paintball_kidz's Avatar
Surrey, BC
Joined Jun 2007
same for me, and thats the only part i cant make
paintball_kidz is offline Find More Posts by paintball_kidz
Old Jul 11, 2009, 01:12 PM
Neil Morse is online now
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
The control rods for the ailerons are just pieces of music wire with a Z bend at one end. Here's a pic of my old Flash that shows a typical set up. Very easy to make.
Neil
Neil Morse is online now Find More Posts by Neil Morse
Old Jul 12, 2009, 09:41 AM
74pb63695669 is offline
Find More Posts by 74pb63695669
74pb63695669's Avatar
Leeds
Joined Nov 2008
I have also purchased a Yak 54 and i think that it is the easiest plane to achieve 3D manoeuvres with. I used the most of a nice calm day and created a video and some images of the plane. I hope that you enjoy the video.
http://www.rcgroups.com/forums/showthread.php?t=1078471
Matthew Scott
74pb63695669 is offline Find More Posts by 74pb63695669
Old Jul 12, 2009, 11:24 AM
Registered Snoozer
Neil Morse's Avatar
Joined Jul 1999
Very impressive flying, Matthew!
Neil
Old Jul 12, 2009, 11:32 AM
Epic Huckin'
Surrey, BC
Joined Jun 2007
how well does this thing do ke spins, blenders and all those high stress stuff
Old Jul 12, 2009, 12:58 PM
Leeds
Joined Nov 2008
While i was flying the model i found that the plane coped very well with the high stress manoeuvres. The blenders work perfectly until opposite aileron is applied to flaten the model it then quickly flicks out. Inverted flat spins are more like very tight control line circles. Knife edge spins only work from a normal spin and apply opposite rudder, it's not quite perfectly knife edge but close enough to know what it is. Knife edge is great and KE loops are easy and KE to KE snaps are easy to catch but the flying speed quickly reduces.
Discussion New “Flash” from Super Zoom designer David Kyjovsky Neil Morse 3D Foamies 4807 Aug 03, 2014 11:53 PM
New Product New Yak-54 3D 25 From Raidentech & Nitroplanes Yardbee 3D Flying 17 Jun 19, 2010 12:23 PM
Discussion New Yak-54 micro from HL MKH 3D Flying 59 May 05, 2007 07:32 PM
Discussion New YAK 54 E From Extremeflightrc extraedge 3D Flying 4 Jun 05, 2006 11:50 PM
Quique's New Yak 54...hhmmm rmm Sport Planes 4 Mar 19, 2004 05:09 PM
