New Yak 54 from RC-Factory
RC-Factory, maker of the Flash, has come up with something new. Here’s what it looks like.
11/19/09 update: here's a link to the E Zone review of the Yak 54 by Jon Barnes David Kyjovsky and RC-Factory EPP Yak 54 Review 8/14/08 update: here's a link to a new Zak West video of the Yak: http://www.rcgroups.com/forums/showt...1#post10342325 11/22/08 update: Northeast Sailplanes is now carrying the Yak. http://www.nesail.com/detail.php?productID=5804 8/4/09 update: Here's a general list of modifications that have been done by various Yak owners (compiled courtesy of "Leadfeather"). These (and other mods) are discussed starting at Post #830. 1) Stronger motor mount; either a stronger wagon wheel or a mod to a traditional type motor mount. If you never crash you can ignore this one. 2) Main landing gear bracing for those less than perfect landings. 3) Plastic wall plugs to reinforce motor mount screws into foam 4) Battery cut into fuse foam once battery location is nailed down. cg at 10 cm from leading edge. 5) Reinforce ailerons (not actually totally clear on this one). Also check wing/aileron for warping 6) Larger main wheels, probably more important for rough field flying. 7) Reinforced tail wheel assembly, sterrable tail wheel, for those guys who taxi to the strip at their flying field. 8) Light weight (and extended) tail skid in lieu of tail wheel for those flying off of grass/rough fields. 9) Push rods to replace pull pull on tail feathers. |
Oakland/Berkeley CA
Joined Oct 2007
Awesome. I almost bought another flash, but now I think I will wait.
What is the purpose of the cowl other than for looks? One of the great things about the flash is that it is so easy to tape back together. I have broken off the motor mount more times than I can remember. I am betting that when/if I get the yak, my cowl won't last too long. Where are the tests flights going to be???? |
The cowl is more than just decorative -- it is also motor mount support. This plane really has to have the motor mounted behind the firewall (or major reworking done) since the whole thing locks together very nicely.
I'm sure this will become clearer as Neil posts more pictures. I got to look at the kit at RSA. I was dubious about the mounting system at first glance, but when you bone it out the whole thing looks like it ought to work pretty well! Proof's in the pudding though. Dave |
Mike |
| Thread Tools | |
| Discussion New “Flash” from Super Zoom designer David Kyjovsky | Neil Morse | 3D Foamies | 4798 | Mar 15, 2013 06:54 AM |
| New Product New Yak-54 3D 25 From Raidentech & Nitroplanes | Yardbee | 3D Flying | 17 | Jun 19, 2010 12:23 PM |
| Discussion New Yak-54 micro from HL | MKH | 3D Flying | 59 | May 05, 2007 07:32 PM |
| Discussion New YAK 54 E From Extremeflightrc | extraedge | 3D Flying | 4 | Jun 05, 2006 11:50 PM |
| Quique's New Yak 54...hhmmm | rmm | Sport Planes | 4 | Mar 19, 2004 05:09 PM |
