Old Jul 28, 2009, 07:47 PM
Kamov is offline
Find More Posts by Kamov
Kamov's Avatar
CA
Joined May 2007
Ok i posted this topic about alternate props on the Vapor thread but i'll post it here so some of you might have seen this.
i broke my prop 2x and now LHS does not have them in stock so i used whatever i have a GWS4040 w/c i trimmed the width but kept the lenght its heavier compared to the stock but it flies well
anybody else using an alternate prop that works?
Kamov is offline Find More Posts by Kamov
Old Jul 29, 2009, 10:51 AM
MikeW9 is offline
Find More Posts by MikeW9
Joined Jan 2009
Hot Ember
I haven't seen anyone put a brushless motor on this plane in this thread.
Here's a Mighty Midget 13/4/15 with a 1S ESC that helps this plane go way faster. I had to shorten the motor mount to balance the CG, but it handles well. It kept wanting to climb every time I throttled up, so a mix a little down elevator in from the throttle and now it just goes faster when I increase throttle..
MikeW9 is offline Find More Posts by MikeW9
Old Jul 29, 2009, 12:35 PM
Kamov is offline
Kamov's Avatar
CA
Joined May 2007
looks like you've got a hot rod there with appropriate flames decal
BL motor brand/source? Hobbycity ?
are you using 110mah lipos? 10c or 15c ? flight times?
i like your nose spinner[bumper] idea
what GWS prop?
got a video ?
Old Jul 29, 2009, 10:01 PM
MikeW9 is offline
Joined Jan 2009
what GWS prop?
got a video ?
I tried one of the 2gm HobbyCity BL and it drew over 2A, got very hot, and I only got about 15gm of thrust. This is a Mighty Midget 13/4/15 ($$$) with the single LiPo ESC from same ($). Can't program it and when the batt drops, the brick dies and the Ember wanders off on it's own for about thirty sec then the ESC dies.. So I don't let it go more than about 10min and then bring it down. I use either the Tenergy 130 or the Lightning Power 130 that is 15C and the batt droops less. The prop is a 4025 for ground landing clearance, but it will swing a 5043 no prob. Thrust is ~30gm.
The spinner is a must indoors (for me :-) and is carved from EPP and glued on.
Old Jul 30, 2009, 10:27 AM
Kamov is offline
Kamov's Avatar
CA
Joined May 2007
MikeW9
thanks for the info
im impressed being direct drive it would swing a heavy 5043 prop. the $$$ Carbon Fiber props would probably even make it work better
are the Lightning Power 130mah really rated 15C? do you recommend this battery over the Tenergy
Old Aug 05, 2009, 07:00 PM
rcairplanenut2 is offline
Find More Posts by rcairplanenut2
Wyoming USA
Joined Aug 2009
I took the nose cone off to make mine lighter. And to rebalance it I moved the battery all the way forward.
rcairplanenut2 is offline Find More Posts by rcairplanenut2
Old Sep 14, 2009, 10:18 PM
gbass01 is online now
Find More Posts by gbass01
Gloucester, VA
Joined Jun 2009
Please help! Ember 2 from parts
Building an Ember 2 from parts.
Need a little help, please.
What [if any] adhesives would you recommend for attaching the control horns to the stabs and the stabs to the fuse? CA? Epoxy? Or do these little guys just snap on and stay put?
The wing attaches to the to the wing mount with tape strips, right? What kind would you use, blenderm, or office scotch tape, or blue painter's tape?
Thanks in advance!
Greg
gbass01 is online now Find More Posts by gbass01
Old Sep 15, 2009, 10:26 AM
Bing44 is offline
Find More Posts by Bing44
Bing44's Avatar
United States, OR, Independence
Joined Feb 2008
I use foam safe CA and a Scotch brand tape called MultiTask Tape. It is 3/4" wide, clear, and comes in a Scotch Tape style dispenser. It sticks like crazy and is tough as packing tape.
jim
Bing44 is offline Find More Posts by Bing44
Old Sep 15, 2009, 05:39 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Finally got to install a new lighting set on my Ember 2. I figure this time, with better lights, I hopefully won't lose the plane again as happened a week or two ago. I purchased the Micro Lighting set from TinyBriteLights, the set that is designed for both the Vapor and the Ember. Really amazing how well these lights perform. Very small mini-diode type lights, a green, red, and strobing white. Flew the Ember 2 early evening, and it looked OK. But, as darkness increased (7:45 PM EST), the lights really showed their stuff. Actually flew until it was almost total darkness. Wish I had a video of it, might get that made in the near future, a video camera and extra person willing.
The next concern was flying the Ember inside, at a gymnasium setting. I got the lights primarily for this venue, as our club has monthly indoor flying events scheduled for about 6 months, starting in late October. In order to keep an eye on my plane when flying in a cloud of other Embers, Vapors, homemade specials, I wanted the lights to give the plane some ID. I'm happy to report the lights showed up very well under typical indoor recreational gymnasium illumination. The blinking white strobe on the tail fin really looked neat, and the green and red lights were not only clearly seen, but also helpful in orientation of the plane.
Here's a link to the supplier, go take a look. www.tinybritelights.com
The attached photos do not do justice to the actual brightness of these lights, and I was not able to get a photo of the plane in flight.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Last edited by Doug Sipprell; Oct 16, 2009 at 02:23 PM. Reason: correction to link for TinyBriteLights
Old Oct 16, 2009, 01:14 PM
fyter889 is offline
Find More Posts by fyter889
You can't handle the truth!
fyter889's Avatar
Joined Sep 2009
I am thinking of getting a bnf vapor or Ember for indoor flying this winter, I work in an auto shop which is long but only about 100 ft wide and 30ft tall. How fast is the stock Ember? Or would the vapor work better in this atmosphere? PM me with your answers please, as I don't check here much. Andy
fyter889 is offline Find More Posts by fyter889
Old Oct 19, 2009, 03:49 PM
Sir Raleigh is offline
Find More Posts by Sir Raleigh
Raleigh, NC
Joined Apr 2007
Has anyone made a prop saver for the Ember 2?
Bill
Sir Raleigh is offline Find More Posts by Sir Raleigh
Old Oct 21, 2009, 06:28 PM
MikeW9 is offline
Joined Jan 2009
MikeW9
thanks for the info
Kamov;
Sorry for the late reply to your question. I've not looked at this thread for a while. Been working on some other indoor flying projects.
The Tenergy is only rated at 10C and gets a little puffy if I try to run them at 1.5 - 2A while the Lighting Power units seem to hold up better.
I use a Watts Up to check the performance.
Old Oct 28, 2009, 11:06 PM
lovespicyfood is offline
Find More Posts by lovespicyfood
USA, CA, Westlake Village
Joined Sep 2004
RD
That is SO COOL! Were you ever able to get a night flight pic of it? I think this would be a neat plane to fly at night as I could easily toss it up in my neighborhood without worrying about it too much.
I'm going to build a night flying heli, but I figure I'll retrofit my Ember2 also...
lovespicyfood is offline Find More Posts by lovespicyfood
Old Oct 28, 2009, 11:08 PM
Joined Sep 2004
Has anyone used white glue to put on the horizontal/vertical stabilizers? I recently purchased a fuselage set and I'm trying to transfer the wings/tail over.
Old Oct 29, 2009, 10:14 AM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
Flying an Ember with lights, at dusk or early evening is more than possible via the use of these tiny LED lights. Just be sure conditions are calm outside.
Both of my Ember 2's now have the updated #2022 Micro Light Set from www.tinybritelights.com, and 90% of the flying is done outdoors. Ember 2 #2 recently flown at an indoor event. Even with the gynmasium lights on, the LED's are clearly visable. The best of the indoor flying was when all but one of the gym lights were turned off and two Ember 2's with identical lighting systems were buzzing around. Neither hit anything during the "night flying" session.
Ember 2 #1 was up last evening, 23 minute flight using a ParkZone 120 mAh 1S Lipo (as supplied with the UM P-51 Mustang).
RD
Latest blog entry: Big Red Cadillac
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1563 Aug 02, 2016 11:51 AM
Discussion Official Parkzone Vapor Mods thread !! glenn2626 Scratchbuilt Indoor and Micro Models 1655 Feb 10, 2016 04:13 PM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 01:00 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
