Old Jan 04, 2013, 02:31 PM
karfrik is offline
Find More Posts by karfrik
karfrik's Avatar
United States, TX, Fort Worth
Joined Apr 2009
Originally Posted by TjW View Post
Just the J3 motor. It slides in slick as snot. The motor leads are a little short. You can either splice in more wire, or bend the pins on the brick up to about a 45 degree angle.
As long as you're messing around up there, though, stick a short piece of the red tubing that comes with a can of WD-40 over the propeller shaft in between the propeller and the large gear.
You'll need a good battery to really get all the benefit. I use the MiniAviation 180. I understand the newer ones are 190s, but my 180s still work well enough I can't justify buying new ones.
Thanks!!...
karfrik is offline Find More Posts by karfrik
Old Jan 04, 2013, 04:55 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
If and when you go to replace the 180's, you will find the MiniAviation 190's are really very good. I have used them on my UM P-51 and Pole Cat. The Ember will haul the 190 w/o problems, and provide some decent flight times, well over 20 minutes at or near WOT. FWIW
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Jan 17, 2013, 04:37 PM
t.edwards is offline
Find More Posts by t.edwards
Joined Aug 2005
Has anyone run the vapor gearbox and prop on their Ember? I have the J-3 motor installed and would like more thrust, like my J-3 motored Vapor has. How does the Ember fly with the lesser down thrust of the Vapor gearbox assy? Has anyone tried this?
t.edwards is offline Find More Posts by t.edwards
Old Jan 17, 2013, 09:41 PM
coreman is online now
Find More Posts by coreman
Kit Manufacturer
coreman's Avatar
United States, MA, Southbridge
Joined Feb 2010
I cobbled a 4-Site gearbox and motor on mine and got vertical performance out of it. Weird seeing an Ember hover. I kept the downthrust when I attached it
coreman is online now Find More Posts by coreman
Latest blog entry: BluFO review by Jim T Graham
Old Jan 17, 2013, 10:52 PM
Joined Aug 2005
Ember with just a J-3 motor doesn't have enough thrust to hover. Vapor, with it's different gearing, larger diameter prop, and the J-3 motor will.
I'm just wondering how the Ember flies with the Vapor gearboxes' lesser down thrust. The Ember gearbox has a bunch of down thrust.
Old Jan 18, 2013, 05:32 AM
Kit Manufacturer
coreman's Avatar
Joined Feb 2010
I would think you would still want the Ember down thrust because that is more a function of the wing camber and AoA.
Old Jan 18, 2013, 07:48 AM
Joined Aug 2005
Maybe. We can both speculate, I was wondering if anyone had tried it. I could also replace the front wing mount with a rear mount to take the AOA out of the wing. I know my Slow Stick flies better that way and needs no down thrust.
The reason for wating to change was for the gearbox and prop, The down thrust change happens to be built into the gearbox.
Old Jan 19, 2013, 06:34 PM
Joined Aug 2005
Bump. Anyone played with the Ember in terms of thrust angle and the wings' AOA? I still (I started with a slow stick) regularly fly a brushless motored slow stick with equal height front and rear wing mounts, 20 deg dihedral, and a "barn door" rudder that is really fun to fly. The Ember seems it could be a mini equivalent.
Old Jan 20, 2013, 11:01 AM
TjW is offline
TjW
Find More Posts by TjW
TjW
USA, CA, Riverside
Joined Mar 2006
Mine's fun to fly. But I didn't change the thrust angle or decalage or dihedral. And it's not brushless. And it's a reasonably large rudder, but I wouldn't call it a barn door.
But it's fun to fly.
TjW is offline Find More Posts by TjW
Old Feb 03, 2013, 04:07 PM
Joined Aug 2005
Mine's fun to fly.
Mine is too. Both my modded slow stick (great fun in the wind) and my modded Ember, calm or indoor only. I mostly fly bigger stuff but the Ember 2 with a Vapor/ Night Vapor gear box and prop, J-3 motor, is neat. Does require trimming down the Embers' CF fuse to accept the vapor gearbox.
Old Mar 29, 2013, 08:17 PM
Sabin is offline
Find More Posts by Sabin
Every pilot has his crash
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
hey guys. I just acquired an ember 2 brick (found that out after digging around for about half the day) and I was wondering is it possible to add a third servo to the empty channel?
Sabin is offline Find More Posts by Sabin
Old Mar 31, 2013, 07:35 AM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
If you have the 'green dot' Brick then yes additional servos may be added because this is a 6-channel design. Makes for careful soldering onto the circuit board traces where the servo-connectors were left off.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Mar 31, 2013, 07:59 AM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
The extra channels on the green dot brick have opposite polarity as the 6400 so be careful when hooking extra servos up.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Apr 08, 2013, 05:53 AM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Here is the Thread with all you need to know.
UNGN is offline Find More Posts by UNGN
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1560 Jun 07, 2016 03:00 PM
Discussion Official Parkzone Vapor Mods thread !! glenn2626 Scratchbuilt Indoor and Micro Models 1655 Feb 10, 2016 04:13 PM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 01:00 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
