Old Jul 02, 2008, 01:59 PM
sr71fan is offline
Find More Posts by sr71fan
Flying...Pushing Air Down
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
piPlane (Because It's Round)
A few people have showed an interest in my little round UFO-type (thanks GPW!), so here is a guick build-guide.
This is a really fun plane to throw in the back of the car to fly practically anywhere.
Indoor Video:
http://www.rcgroups.com/forums/showt...1#post10143610
Build sequence:
1. Cut an 18-inch diameter disc from Bluecor.
2. Cut and hinge elevons with Scotch tape (over-under method).
3. Cut upper fuselage from Bluecor.
4. Cut and hinge rudder with Scotch tape (over-under method).
5. Glue upper fuselage onto disc.
6. Mount elevon servos.
7. Mount receiver.
8. Mount rudder servo.
9. Cut lower fuselage from Bluecor.
!0. Glue lower fuselage onto disc.
11. Mount motor to small piece of 1/32 ply. I used 1.3 X 1.3 inches.
12. Glue motor mount to front of disc.
13. Mount ESC on right side of lower fuselage using hook and loop (Velcro).
14. Install control linkages.
15. Adjust throws for at least 30 degrees travel each direction (45 or more, if you dare).
16. Attach battery to lower left fuselage (opposite the ESC) using hook and loop.
17. Balance at 25%.
18. Go fly !
Equipment:
E-Flite Park 300 outrunner
9/4.7 SF prop
tiny servos
tiny receiver (I like Berg 4L or Spektrum 6100E)
tiny ESC (CC TB-6 or TB-9)
tiny battery (2S 300 to 620 LiPoly)
Yes, you can add landing gear; I prefer to save the weight
Have FUN !
Gary
sr71fan is offline Find More Posts by sr71fan
Old Jul 02, 2008, 03:39 PM
raythomas is offline
Find More Posts by raythomas
KZ RIDER
raythomas's Avatar
United States, MS, Tupelo
Joined Nov 2001
SWEET
I have a question or two.
If you have elevons on it, whats the rudder for?
In the side view the elevons are drooped. Is this to make it like a slowfly highlift airfoil for slow flight?
I thought anything that had elevons neede a small amount of reflex (up) in the elevons.
Great design and fun I bet.
If you had the time, could you give us a heads up on how you made and mounted your LED'S ????
I can hear my neighbors on the phone now!!!
"Sheriff, you gotta get out here, its a UFO I tell ya" ha ha ha ha
Thanks Ray
raythomas is offline Find More Posts by raythomas
Old Jul 02, 2008, 05:06 PM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Ray,
Elevons only control pitch and roll. The rudder controls the yaw axis.
The elevons are drooped because they got knocked around during transport. They are slightly up when flying.
For the lights, I tap off +5V and - (ground) from the receiver, and run two wires all the places I want lights. Solder the LED (with a 100 ohm 1/8 watt resistor) between the two (observing proper polarity), and tape them down. See photos.
Gary
P.S. Blinking LEDs don't need the resistor.
Old Jul 02, 2008, 06:34 PM
youth must fly is offline
Find More Posts by youth must fly
feel no remorse
youth must fly's Avatar
underground
Joined Jun 2004
here we go again
youth must fly is offline Find More Posts by youth must fly
Old Jul 02, 2008, 07:09 PM
leebospeed is offline
Find More Posts by leebospeed
leebospeed's Avatar
Yorkshire, UK
Joined Dec 2006
I just could not resist!
Hi Gary,
Hope you dont mind but i did a pdf for everyone!
All the best,
Leebospeed.
leebospeed is offline Find More Posts by leebospeed
Old Jul 02, 2008, 07:26 PM
flying-llama is offline
Find More Posts by flying-llama
Sopwith Camel's Cousin
Between my tx and crashed aircraft
Joined Mar 2006
Useful for a maneuver where the roll and rudder go in 'opposite' directions: one such maneuver is a flat turn:
the rudder turns the plane, but the elevons roll to the outside of the turn
so that the wings stay level during the turn: can make for a very tight turn.
flying-llama is offline Find More Posts by flying-llama
Old Jul 02, 2008, 08:06 PM
tymbrewolf is offline
Find More Posts by tymbrewolf
Joined Feb 2007
Howe does it compare to the Itza?
tymbrewolf is offline Find More Posts by tymbrewolf
Old Jul 02, 2008, 09:14 PM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
'Bout the same.
Old Jul 02, 2008, 09:18 PM
Daddy-O is offline
Find More Posts by Daddy-O
John 3:16
Daddy-O's Avatar
Dom. Rep.
Joined May 2003
That is a very nice, controlled-flying video. Congratulations on a good flying, fun plane! Thank you for putting it up for all of us.
Daddy-O
*EDIT* The shape of the fuse in the video looked kind of like a bean. The flying bean!
Daddy-O is offline Find More Posts by Daddy-O
Old Jul 02, 2008, 10:31 PM
thermal is offline
Find More Posts by thermal
thermal's Avatar
Maryland's eastern most shoreline
Joined May 2004
Are you running all the LED's in the video from one unused channel on your receiver? It really looks great!
thermal is offline Find More Posts by thermal
Old Jul 02, 2008, 10:38 PM
KZ RIDER
raythomas's Avatar
Joined Nov 2001
Ray,
Gary
Man I been on this site since it first began.
And I bet I've read every thread and post on HOW TO LED'S.
And you got it all down to one picture.
You are a GENIUS!!!!!!!
So what your saying is the plane will fly with elevons only? And you
just use the rudder for flat turns?
Thanks Ray
Old Jul 03, 2008, 12:44 AM
sr71fan is offline
sr71fan's Avatar
Clovis, NM, USA
Joined Nov 2000
Thermal,
Yes, all the LEDs are powered by the receiver 5 Volts. I don't have a spare channel on this one, so I just tapped the rudder channel connector by soldering the wires to the pins under the servo connector. You could use a Y-connector, but I was trying to save weight.
Ray,
I did not say I use the rudder only for flat turns. I said it is used for yaw. That includes any time you want to move the nose left or right. Comes in really handy while hovering. Very effective in harrier, too. Yes, you can fly the plane with elevons only, but I would rather have rudder and elevator than no rudder and elevons. To each his own, I guess.
Old Jul 03, 2008, 06:16 AM
gpw is offline
gpw
Find More Posts by gpw
gpw
“There’s no place like Foam”
gpw's Avatar
United States, LA, New Orleans
Joined Jul 2002
We've been having so much FUN with the Itza' (Thanks SR71) This one is just so Cute !!! We'll have to make one ...
gpw is offline Find More Posts by gpw
Old Jul 03, 2008, 06:41 AM
mthomas is offline
Find More Posts by mthomas
Hi I am Mark & I am an addict
mthomas's Avatar
USA, KY, Louisville
Joined May 2007
This is completely awesome.. thanks for posting. I do have one quesiton about hinging... what exactly is the over/under method? Isnt' that just regular singular sided tape?
Mark
mthomas is offline Find More Posts by mthomas
Old Jul 03, 2008, 07:23 AM
DRITCH is offline
Find More Posts by DRITCH
DRITCH's Avatar
ST.LOUIS
Joined Aug 2006
slightly technical question.
Got the resistor part and power supply.
1. Do you hook up the led's in series or parallel in the whole circuit. Can't quite see it in the pics?
2. Are the led's rated for a certain voltage/wattage?
3. Radioshack?
4. Love the plane.
DRITCH is offline Find More Posts by DRITCH
Discussion UK teachers forbidden from referring to pupils' parents as "mom and dad" because it's Astroguy Life, The Universe, and Politics 27 Oct 21, 2008 10:47 AM
Discussion ANy honey bee fp video's round here? slo123 Micro Helis 3 Apr 16, 2007 04:05 AM
Discussion Atlanta Pilots first dib's round 2 Mike Parsons Atlanta Area RC 7 Feb 03, 2006 07:24 AM
Ray! Where's round III? Pismo Slope 26 Jun 17, 2004 08:06 AM
