Old Jul 26, 2008, 09:49 PM
Crazy Eight is offline
Find More Posts by Crazy Eight
The "K"minator
Crazy Eight's Avatar
Frostbite Falls,MN
Joined Sep 2006
I was thinking (hoping)you might find a signal that could be used with one of the converters that you sell.
Crazy Eight is offline Find More Posts by Crazy Eight
Old Jul 26, 2008, 10:13 PM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
That should be no problem for adding a brushless ESC, the converter would connect to the gate pin of the existing ESCs mosfet. The new 1 gram 3 amp brushless esc would work fine and is only 0.42 grams with all wiring removed.
I'll convert one of my Vapors to brushless but think I'll let someone else experiment with it first. I already spend too much time trying ESCs and motors for my helicopters. Once the ideal motor/prop combo is found I'll do it.
TheSteve is offline Find More Posts by TheSteve
Old Jul 26, 2008, 10:29 PM
termite is offline
Find More Posts by termite
Utica Il.
Joined Dec 2002
Steve,
Can you show us what pin that would be on the Vapor board?
Randy
termite is offline Find More Posts by termite
Reply With Quote  (Disabled)
Old Jul 26, 2008, 10:58 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
The one I have marked with the little red line appears to be the gate.(I think?)
Old Jul 26, 2008, 11:11 PM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
Originally Posted by TheSteve
The receiver makes no difference in this case, its all up to the transmitter. The receiver just outputs whatever the transmitter sends it.
Best I can suggest it DIP 1 on, DIP 2 off and then try turning 3 and/or 4 on to see if it makes any difference on the output. You should probably power cycle the transmitter after each change.
I'd check it out myself if I still had a LP5DSM. I ripped the 2.4ghz transmitter out of mine and made it into a module for a Futaba radio. The LP5DSM chassis/microcontroller itself got turned into a trainer box with a USB interface for my father(which worked out really well as the radio runs perfectly off 5 volts)
Steve- What kind of range do you get with the LP5 Tx module? I thought it was prety low powered since the BCX2 is for indoor and backyard flying.
minirips2 is offline Find More Posts by minirips2
Old Jul 26, 2008, 11:29 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Yeppers, thats it.
Old Jul 26, 2008, 11:38 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
The module is very low power - only 1 or 2 milliwatts. I usually get between two and three hundred feet of range.
I originally worked on the mod because I already had a Futaba 9CAP transmitter and also had the LP5DSM that came with my Blade CX2(and I have a tough time not modifying stuff) I have since retired the 9CAP for heli flying and bought a full range Jr/Spektrum transmitter. The 9CAP is still great for a grab and go kit with the Vapor or similar when I don't want to worry about my Jr 12x. With any luck the transmitter board can be removed from the RTF Vapor transmitter. If you happen to have a Futaba 9CAP or similar kicking around it makes for a fun project and gives you access to a nice flight timer, mixing, expo, dual rates etc.
Here is a link to the project in the DIY forum:
http://www.rcgroups.com/forums/showthread.php?t=721024
The Atmel code is posted a few pages in so anyone can build it.
Something else I forgot to mention in my last post to Crazy Eight - while you have the brick out fully clear the black goop off the red LED - makes for better night flying.
Old Jul 26, 2008, 11:49 PM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
Thanks for suggestion.By the way,this brick won't be going back in the Vapor it came from,the airframe met an untimely demise by trying to fly through the blades of a CX2 that was in flight.The RX brick and lipo was all that survived.
Old Jul 27, 2008, 12:03 AM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Ouch! I can see the Blade CX2 winning that battle...
I just grabbed a brushless converter from the bin and installed it in my spare brick(with a defective servo) Here is a picture of a possible installation.
The white wire would go to the signal input of the brushless ESC. The power wires for the brushless ESC should be connected to the same place on the brick where the battery wires connect.(more scraping of black goop!)
termite - good to see you in the thread, need any more AR6300s?
edit - updated the picture, this one is a little better.
Old Jul 27, 2008, 12:09 AM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
I'll second that move.. I just did it after Steve mentioned it.. I never realised before that it was gooped over..
Here's a few shots of it in my dark living room.. really lights the wing up nicely and makes night flights tons easier.. the camera really doesnt do it justice however..
~Kev
darksiede is offline Find More Posts by darksiede
Old Jul 27, 2008, 12:13 AM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
~Kev
When I bought my second Vapor I opened four BindNFly versions and 3 of the 4 had the red completely covered over, it couldn't be seen at all. I rejected those ones and found a nice one
Old Jul 27, 2008, 10:18 AM
termite is offline
Utica Il.
Joined Dec 2002
Steve,
I'm always watching and trying to learn!!!!
I may take you up on that if you have some sitting around!?!?!?
I'll be ordering a couple of the converters for sure!
Randy
Old Jul 29, 2008, 01:23 PM
b36roxs is offline
Find More Posts by b36roxs
Joined Sep 2006
edit
b36roxs is offline Find More Posts by b36roxs
Old Jul 29, 2008, 02:35 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Originally Posted by b36roxs
jesus christ has nobody thought of this? brushless motor
Yeh, its been thought of, the stuff exists to do it, though I've yet to see pics of anyone having done it.. all based off making the C210/Citabria brushless setups..
I made an "Oh $(*@" mod on mine last night.. Flying past my bathroom door when it got opened from the inside, sucking my plane through the door, and onto the lightbar above the medicine cabinet.. left side of the main wing got stretched tight from the heat of one lightbulb almost touching it, the right side got a 1/2" circular hole melted into it + stretched tight from touching anoter bulb.... Really put alot of washout into it via warping the wings frame with the tighter film.. the outter tips are also lifted almost 1/2" from the stretching as well.. made it handle totally different.. It'll high alpha like no ones business now.. strange.. and no, I haven't taped over the hole, and likely won't.. This wing will be ran till it fails lol..
~Kev
Old Jul 31, 2008, 05:04 PM
msburko is offline
Find More Posts by msburko
Syracuse NY
Joined Dec 2002
V-tail mod?
so I thought.. V-tail!
Darksiede:
Any word on the V-tail mod. Seems very promising.
msburko is offline Find More Posts by msburko
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1563 Aug 02, 2016 11:51 AM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 01:00 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
