Old Jul 26, 2008, 02:03 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
LOL
Well hybrids are the current thing aren't they?
stanordave is offline Find More Posts by stanordave
Old Jul 26, 2008, 02:09 PM
minirips2 is offline
Find More Posts by minirips2
Chicago Northwest subs
Joined Jan 2007
Originally Posted by stanordave
LOL
That, and hydrogen-which would work in the balloon! Don't do the Hindenburg thing, though.
minirips2 is offline Find More Posts by minirips2
Old Jul 26, 2008, 03:36 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
Great mod, penguin. I can't wait to try it.
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Jul 26, 2008, 04:08 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
I just cooked up a new idea, and when my LHS has the parts, I will do it.. Just waiting on them to get another rudder in, so I can steal the hinge from its kit..oh wait! I need to check since I just replaced my rudder & elevator 2 days ago, I may have a spare hinge......
Since I have the LP5DSM, I can do rudder & elevator mixing, so I thought.. V-tail!
reduce 1/3rd of the tails weight at least.. Use the standard rudder/elevator hinge, rotate it 45 degree, trim off extra parts, and use 2 rudders.. would need to trim and relocate the control horn on the right side rudder to the inside I think..
I've already tested the CCPM mixing of the Tx on the Vapor board, and confirmed it will work the two servos in unison.. can't wait to try this out, and shave some more weight!
~Kev
Edit:
Oh snap, I do have the spare hinge, but my original rudder's post isn't log enough to reach through and secure.. could trim the hinge down a bit tho..hmmm
darksiede is offline Find More Posts by darksiede
Old Jul 26, 2008, 05:06 PM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
darksiede, sounds like a fun project. I've never tested any v-tail mixing with a LP5DSM. I do know it does not do proper CCPM though, you can turn it on but it will not command the three servos properly.
Hopefully the v-tail function does work properly. I'd fully test it before modifying the Vapor.
TheSteve is offline Find More Posts by TheSteve
Old Jul 26, 2008, 05:15 PM
Torx is offline
Find More Posts by Torx
Torx's Avatar
United States, TN, Memphis
Joined Apr 2007
Use a prop guard, the first 4 tries were a bust
i see what you did there. its puntastic!
lmao
Torx is offline Find More Posts by Torx
Old Jul 26, 2008, 05:31 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Well, if I turn it on right now with the vapor un-modified..
#2 and #4 dips up...
If I push the stick:
down: left rudder + up ele..
up: right rudder + down ele
Right: right rudder + down ele
left: left rudder + up ele
top left or bottom right on stick: nuetral control surfaces (no movement)..
top right: right rudder + down ele
bottom left: left rudder + up ele...
So hmm, it doesn't seem to me that is properly mixed.. correct me if im wrong tho.. perhaps if my LP5DSM won't do it, someone with e DX6I/DX7 can and reports back!
~Kev
PS: what exactly does "CCPM" mean & do anyways?
Old Jul 26, 2008, 05:47 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Its Cyclic Collective Pitch Mixing for use in helicopters:
http://en.wikipedia.org/wiki/Cyclic/...e_pitch_mixing
I know the LP5DSM pcb has lots of features labeled but I'm not how many are implemented in the software as Horizon only sells the LP5DSM with the Blade CX2 which requires no mixing at all.
No question it can be done with the higher end Spektrum transmitters - DX6i, DX7, x9303 and 12x.
btw, you don't want switch 2 up, the radio should be in airplane mode for the mixing you're trying to get.
Old Jul 26, 2008, 05:55 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Ah, 'splains that right up! lol.. I thought sw 1 was ap/heli, and 2 was ccpm on/off?.. regardless, even with sw 2 off, the results are still the same as posted above..
~Kev
Old Jul 26, 2008, 07:20 PM
crabfu is offline
Find More Posts by crabfu
crabfu's Avatar
Joined Nov 2005
found a way to slow down the vapor biplane even more:
vapor biplane in the wind (4 min 4 sec)
-Crabfu
crabfu is offline Find More Posts by crabfu
Old Jul 26, 2008, 07:22 PM
Veteran is offline
Find More Posts by Veteran
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
Sounds like the poor little motor is under some stress in the balloon clip.
Veteran is offline Find More Posts by Veteran
Old Jul 26, 2008, 07:31 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Lol crabfu.. I almost bought the wing today at my LHS to do that.. ended up buying props for my SS instead.. the big bird needed a new puller!
Steve... do you know if the LP5 will mix properly on an AR6100, or any "regular" spektrum Rx? I was really hoping it would so I could make up a nutball or something and not have to get a Tx to do the mixing.. I'm wanting working elevons without building a sliding tray..
I could always go small scale on my SD idea, having ailerons and an elevator centered between them.. then for 40 bucks I can have an in-betweener for my vapor and SS..
~Kev
Old Jul 26, 2008, 09:04 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
~Kev
The receiver makes no difference in this case, its all up to the transmitter. The receiver just outputs whatever the transmitter sends it.
Best I can suggest it DIP 1 on, DIP 2 off and then try turning 3 and/or 4 on to see if it makes any difference on the output. You should probably power cycle the transmitter after each change.
I'd check it out myself if I still had a LP5DSM. I ripped the 2.4ghz transmitter out of mine and made it into a module for a Futaba radio. The LP5DSM chassis/microcontroller itself got turned into a trainer box with a USB interface for my father(which worked out really well as the radio runs perfectly off 5 volts)
Old Jul 26, 2008, 09:14 PM
Crazy Eight is offline
Find More Posts by Crazy Eight
The "K"minator
Crazy Eight's Avatar
Frostbite Falls,MN
Joined Sep 2006
Steve,any news on the fourth channel?
Crazy Eight is offline Find More Posts by Crazy Eight
Old Jul 26, 2008, 09:41 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
I wish there was! I've probed the brick for hidden signals and found none. Its possible I missed it but at this point I'm willing to say its not there.
My dream was to find a regular servo signal for the aileron channel and a jumper to convert what is now controlled by the aileron channel back to proper rudder control. This would have allowed us to use the built in servos for rudder/elevator and plug in a micro servo for aileron use.(Are you listening Horizon engineers?)
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1559 Jul 20, 2015 09:46 PM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 01:00 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
