Old Jul 22, 2008, 11:12 PM
penguin71 is offline
Find More Posts by penguin71
Joined Jul 2008
Tried night flying with glowsticks.
Bought some bracelet glowsticks from the $1 section at target.
Taped 1 color to the leading edge of the wing and another color to the fuselage. Adjust the fuselage one to get a decent center of gravity.
Looked kind of neat and flew good, loops and all.
Major drawback - the extra weight did some damage to the gear mount on a pavement crash.
Well now I can say I did a night flight. Back to fun I can actually see in the daytime. (As soon as I repair the mount.)
penguin71 is offline Find More Posts by penguin71
Old Jul 23, 2008, 01:42 PM
RNAF is offline
Find More Posts by RNAF
RNAF's Avatar
The Netherlands
Joined Dec 2003
Originally Posted by msburko
Specs of parts as lifted from a post by Mike Taylor:
http://www.rcgroups.com/forums/showt...77#post8426577
Part numbers were lifted from post by glenn2626:
http://www.rcgroups.com/forums/showt...2#post10070932
PKZ3001 2.2g 70mah Battery
PKZ3302 0.6g Prop
PKZ3351 3.25g Rx Brick
PKZ3327 Gearbox w/o motor
PKZ3316 Main Motor
-------> 2.2g Motor/Gearbox
glenn2626:
You might want to add links to the list of useful posts in your post #1. I just figured it out today.
1) click on the post number.
2) Right click on the thread title in the upper right. Copy the shortcut. That is a link to the post.
If you already knew...... Nevermind
That's an extremely helpful post you've got there. Thanks a bunch
The vapor's RX brick is bindable to any Futaba 2.4gHz tx, right?
RNAF is offline Find More Posts by RNAF
Old Jul 23, 2008, 02:13 PM
healthyfatboy is offline
Find More Posts by healthyfatboy
Joined Jan 2007
It can only bind to the Spektrum transmitters.
healthyfatboy is offline Find More Posts by healthyfatboy
Old Jul 23, 2008, 02:28 PM
RNAF is offline
RNAF's Avatar
The Netherlands
Joined Dec 2003
Well that's crap. Can't find any KYOSHO Minium replacement bricks Those are 2.4 gHz (non DSM2).
Any suggestions
Old Jul 23, 2008, 06:23 PM
Fig Jam is offline
Find More Posts by Fig Jam
I am UNIQUE!
Fig Jam's Avatar
Kentucky
Joined Feb 2008
Any suggestions
Buy a decent Radio (Spektrum/JR) . Only kidding!
Fig Jam is offline Find More Posts by Fig Jam
Old Jul 23, 2008, 06:39 PM
Darth_Elevator is offline
Find More Posts by Darth_Elevator
How do I change this text?
Darth_Elevator's Avatar
The Beautiful Mountains of Utah
Joined Oct 2006
To power your LED's did you just tap into the leads of the battery plug? Also, what size LED's did you use? I have some 5mm UV LED's I thought I'd try with a little bit of glow in the dark paint I got from a hobby shop. I was also thinking about just using a white LED. I can just about fly it in the dark with just the receiver light and I figured even adding a white LED lighting up the bottom of the wing would add enough extra light to do the trick. Any thoguhts?
Originally Posted by stanordave
I added two UV LEDs just now. Waiting for dark to see just how well they work. In the garage w/some light, they work OK but I don't think the flourescent Sharpies I used are doing a good job glowing. Any ideas on something that will glow well under UV?
Darth_Elevator is offline Find More Posts by Darth_Elevator
Old Jul 23, 2008, 09:52 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
I think the white LED will be best.
I made a jumper like Ched's but it's not working so I just tapped into the red/blk leads.
Never had much luck w/the UV's. They're bright but the beam needed to be more diffuse to illuminate more than a spot on the wing. Didn't use a resistor w/them because their forward voltage was 3.2V
Currently using red green and orange LEDs (ea wing and tail). The sizes are mixed (1 5mm and 2 smaller size)
It would be nice if Parkzone offered a jumper for the battery connection to allow a LED harness to easily be attached.
stanordave is offline Find More Posts by stanordave
Old Jul 23, 2008, 10:04 PM
stanordave's Avatar
Joined Jan 2006
A quick photo of the current setup. The yellow glow is the rear LED shining on the concrete floor.
Old Jul 24, 2008, 12:12 AM
Joined Oct 2006
Thanks for the infor, I'll try tapping into the wires with a white LED to see how that works. I'll see if I can find a smaller LED, I think 5mm might be too heavy.
Old Jul 24, 2008, 01:33 AM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
The missing channel, where did it go?
I spent some time this evening probing the Vapor DSM2 brick with my O'scope.
Found some interesting stuff, but so far no missing channel we can use.
I did find that there is in fact a nearly servo compatible signal being generated and its only present when the brick is receiving a signal.
It appears to have two values, roughly 1.0ms or 1.3ms. Its connected to both the main processor and the RF processor. With a fully charged battery the value is 1.0ms, with an 80% discharged battery its 1.3ms. It may have another value when the battery reaches the cutoff voltage but I haven't explored any further.
I was really hoping the rudder signal may have been present somewhere but so far I haven't found it if its there...
btw, main processor is an Atmel Mega48, RF processor looks like a Cypress CYRF6940 however that part doesn't appear to exist. Both of the processors have had the part # scraped off.
TheSteve is offline Find More Posts by TheSteve
Old Jul 24, 2008, 02:06 AM
Crazy Eight is offline
Find More Posts by Crazy Eight
The "K"minator
Crazy Eight's Avatar
Frostbite Falls,MN
Joined Sep 2006
Steve,on mine it looks like it reads CYRF6910.
See what you think.
Crazy Eight is offline Find More Posts by Crazy Eight
Old Jul 24, 2008, 02:15 AM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
See what you think.
Awesome macro - With your info I think its actually a CYRF69103
http://download.cypress.com.edgesuit...yrf69103_8.pdf
The pin connections appear to match up.
Old Jul 24, 2008, 02:28 AM
The "K"minator
Frostbite Falls,MN
Joined Sep 2006
After reading through that info quickly,it looks like the power management uses the 1.3ms signal.
Thanks for the link.
Old Jul 24, 2008, 12:00 PM
msburko is offline
Find More Posts by msburko
Syracuse NY
Joined Dec 2002
What does the CYRF send to the Mega48?
If the CYRF outputs the full serial stream then possibly the Rudder channel can be constructed from it.
msburko is offline Find More Posts by msburko
Old Jul 24, 2008, 02:48 PM
leliommarino is offline
Find More Posts by leliommarino
leliommarino
leliommarino's Avatar
United States, MA
Joined Nov 2007
the best mod is i put one of thoes CF props from MicroInvent
i think it was one of the 4" ones but this thing BOOTS it does loops like it is
its job
- http://airmidimicros.com/MIProps.htm
leliommarino is offline Find More Posts by leliommarino
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1561 Jul 23, 2016 02:00 PM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 01:00 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
