Old Jul 17, 2008, 08:54 AM
eander315 is offline
Find More Posts by eander315
My other heli is a Vapor
eander315's Avatar
Houston, TX
Joined Dec 2007
Originally Posted by tdearth
HI eander,
It is not a stupid question but I am not sure why you would want to.
The Vapor will hover with the motor it has and it looks like the set up is pretty near optimal for that airframe.
Tim
The stock motor is great, but with just a little more oomph I could power through maneuvers that I execute incorrectly. I mostly fly in a large empty area in my office, and because the ceilings are not tall enough, I have little room for error when looping or doing anything vertical. Of course, learning to fly better would be cheaper
eander315 is offline Find More Posts by eander315
Old Jul 17, 2008, 08:55 AM
PietenpolAC is offline
Find More Posts by PietenpolAC
PietenpolAC's Avatar
Budapest, Hungary
Joined Mar 2005
Not a stupid question. One may want to use the brick in other planes with different motors. That's what I'll do. I don't have a Vapor brick yet, but I'm sure someone has the answer. Sounds like the Minium bricks can handle larger motors than the one supplied with the Cessna with no problem. I will want to use mine with a 7mm orange or red, 4:1 gearbox and 5X3 prop.
Bruce
PietenpolAC is offline Find More Posts by PietenpolAC
Old Jul 17, 2008, 10:35 AM
Ched is offline
Find More Posts by Ched
Shawnee, Kansas
Joined Oct 2005
Do you need it to loop tighter? Have you moved the control rod to give the elevator more travel? It helps a lot. You might try removing weight too. Only one gram removed makes the plane 7% lighter and it will feel like it gained 7% more power. I think it would be hard to come up with a better set up than it has. If you add weight with a bigger motor, prop, etc then you won't gain much and you will mess up the CG and have shorter run times.
Ched is offline Find More Posts by Ched
Old Jul 17, 2008, 12:27 PM
eander315's Avatar
Houston, TX
Joined Dec 2007
I completely forgot to try moving the control rod to the closest hole. That should give me more control and will negate the need for more power I think. I might try a larger motor in the future for laughs, but it looks like I won't nee dit for now. Thanks!
Old Jul 17, 2008, 02:21 PM
penguin71 is offline
Find More Posts by penguin71
Joined Jul 2008
Who needs LEDS. It's a full moon out. What a neat flight silhouetting the vapor in front of the full moon at 100ft up.
Tonight I'll try the glow sticks.
penguin71 is offline Find More Posts by penguin71
Old Jul 18, 2008, 12:11 PM
scharlach is offline
Find More Posts by scharlach
United States, GA, Sharpsburg
Joined Jan 2005
What is the weight of the Vapor receiver/servo assembly? Has anyone
checked the range with DX6i transmitter?
scharlach is offline Find More Posts by scharlach
Old Jul 19, 2008, 09:14 AM
glenn2626 is offline
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
Mine is 3.3 grams with antenna and battery cable/plug. Don't know the range yet.
glenn2626 is offline Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Jul 19, 2008, 04:13 PM
Joined Jul 2008
dumped my vapor in the lake.
it was under for about 30 seconds.
blew it off and used a semi cool hot hair dryer.
was flying again in 15 minutes.
is this thing indestructible? knock on wood.
Old Jul 19, 2008, 05:42 PM
clt12981 is offline
Find More Posts by clt12981
Retired RC Flyer
clt12981's Avatar
Jacksonville, Florida
Joined Jul 2008
Vapor
It's a Blast
clt12981 is offline Find More Posts by clt12981
Old Jul 20, 2008, 06:11 AM
Veteran is offline
Find More Posts by Veteran
Mc-Fly
Veteran's Avatar
Melbourne-Australia
Joined Mar 2008
Heres a fantastic step by step guide to repairing your Vapors.
http://www.modelflight.com.au/manual...0tutorials.pdf
Heres a few Pics from the Document
Veteran is offline Find More Posts by Veteran
Old Jul 20, 2008, 12:41 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Thanks!!
stanordave is offline Find More Posts by stanordave
Old Jul 20, 2008, 05:28 PM
msburko is offline
Find More Posts by msburko
Syracuse NY
Joined Dec 2002
Component Specs
Specs of parts as lifted from a post by Mike Taylor:
http://www.rcgroups.com/forums/showt...77#post8426577
Part numbers were lifted from post by glenn2626:
http://www.rcgroups.com/forums/showt...2#post10070932
PKZ3001 2.2g 70mah Battery
PKZ3302 0.9g Prop + 0.3g spinner, 140mm x 45mm
PKZ3351 3.25g Rx Brick
PKZ3327 Gearbox w/o motor, 6:1
PKZ3316 Main Motor, 6mm, 3 ohm
-------> 2.2g Motor/Gearbox
PKZ3320 Main Wing: Vapor 15x37 cm, ~0.54 Sq ft (~1oz/sf wing loading)
PKZ3307 0.1g Tail Wheel: Vapor
edit: adding spec's as I get them
msburko is offline Find More Posts by msburko
Old Jul 21, 2008, 12:36 PM
asylum5 is offline
Find More Posts by asylum5
Joined Jul 2008
Hey thanks for that .pdf, that really helps. I am a total noob and tried to search for this but no luck. How do I remove the motor from the fuselage? I broke my landing gear and got a replacement set. I thought I could just clip it on the fuselage and use some CA, but you actually have to slide it on from the front, which means removing the motor. I tired some CA remover as a test on the broken landing gear and it just melted the plastic, which means it must be acetone. I don't want to melt my motor mount with acetone. Any suggestions?
asylum5 is offline Find More Posts by asylum5
Old Jul 21, 2008, 12:46 PM
Ched is offline
Shawnee, Kansas
Joined Oct 2005
Don't use the acetone,(CA remover) it eats the glue out of the carbon fiber fuselage too. Then it swells and becomes tighter in the gearbox. I don't have the answer to removing the gearbox. I think I would cut the bottom of it off so that it could be twisted around until it let go. Then I would glue it back on and wrap it with unwaxed dental floss. Then soak the dental floss in CA. I broke my gearbox and fixed it that way. Wait !! just found this post by Butters
Ok gents for removing CA and all super glues use this: Purell Hand Sanitizer.
It won't harm the parts and it breaks down the CA really fast.
AWESOME!!!
http://www.brands2liveby.com/brand.aspx?id=310
Oh also mines in the mail! Oh yeah!
Old Jul 22, 2008, 01:41 PM
asylum5 is offline
Joined Jul 2008
I don't think I want to use dental floss to secure my motor mount back on. Surely people have been removing the motor successfully?
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1562 Jul 27, 2016 06:17 PM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 01:00 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
