Old Jul 03, 2008, 07:41 AM
tdearth is offline
Find More Posts by tdearth
USA, IN, Nineveh
Joined Apr 2002
Originally Posted by bas10an
Is there no bind plug?
There is no bind plug on mine.
You only have to plug the plane in first and then turn on the tx to get them to bind.
Tim
tdearth is offline Find More Posts by tdearth
Old Jul 03, 2008, 08:39 AM
glenn2626 is online now
Find More Posts by glenn2626
RC Connectors dot com
glenn2626's Avatar
United States, CO, Colorado Springs
After running thru the battery twice, that velcro's got to go. (the velcro that holds the battery in its holder)
It falls off at the slightest bump!
glenn2626 is online now Find More Posts by glenn2626
Latest blog entry: Horrible "MX" connector on...
Old Jul 03, 2008, 09:33 AM
leliommarino is offline
Find More Posts by leliommarino
leliommarino
leliommarino's Avatar
United States, MA
Joined Nov 2007
usea small ruber band like the ones that hols on micro props
leliommarino is offline Find More Posts by leliommarino
Old Jul 16, 2008, 09:13 AM
msburko is offline
Find More Posts by msburko
Syracuse NY
Joined Dec 2002
Wanted: 4 channel mod for Vapor Rx brick
Slightly off topic.
Wanted: A Mod for the Vapor Rx brick (pkz3351) to output a/the 4th channel.
msburko is offline Find More Posts by msburko
Old Jul 16, 2008, 12:30 PM
Ched is offline
Find More Posts by Ched
Shawnee, Kansas
Joined Oct 2005
Here are my mods so far. I removed the battery tray, velcro and stickers from the battery and removed the prop spinner. It now weighs 14 grams and I can tell the difference. I used metanol to remove some of the graphics. It wipes off very easy and leaves the covering clear as glass. I use tape to hold the battery. I fold it to make taps for easy removal. It holds better than the velcro and I replace it about every 10 battery changes. I am going to use UV ink to cover the clear parts of the covering and then use an onboard LED black light to make the vapor glow at night. The ink will not show up with out a black light. I am going to work on making it lighter too, by getting a carbon fiber prop and using a smaller battery from a piccoz. I would like to make the LG removeable so I can use it or not. (again to save weight ) It looks like I will have to break it off though.
Ched is offline Find More Posts by Ched
Old Jul 16, 2008, 02:23 PM
edu01jose is offline
Find More Posts by edu01jose
Damn....
edu01jose's Avatar
Puerto Rico
Joined May 2008
where can i get lights for the vapor?
what lights are you using?
thanks
edward
edu01jose is offline Find More Posts by edu01jose
Old Jul 16, 2008, 02:42 PM
penguin71 is offline
Find More Posts by penguin71
Joined Jul 2008
you could strap a few of the fishing bobber glow sticks to the wing tips.
haven't tried it.
penguin71 is offline Find More Posts by penguin71
Old Jul 16, 2008, 05:25 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
I added two UV LEDs just now. Waiting for dark to see just how well they work. In the garage w/some light, they work OK but I don't think the flourescent Sharpies I used are doing a good job glowing. Any ideas on something that will glow well under UV?
stanordave is offline Find More Posts by stanordave
Old Jul 16, 2008, 09:57 PM
stanordave's Avatar
Joined Jan 2006
Filmed a night flight but the hatcam's batteries died! Took a still of the UV LEDs. They're not as bright as in the photo. Think part of the problem is the beam comes out the dome of the bulb. Will grind it to make it more diffuse and try again.
Old Jul 16, 2008, 10:08 PM
Ched is offline
Shawnee, Kansas
Joined Oct 2005
I have been looking for magic markers or something that wasn't heavy. Paint would be too heavy. I found some invisible ink, like they use to stamp your hand at a concert. That might be good. I don't know. You are ahead of me. I haven't got the UV LED yet.
Old Jul 16, 2008, 11:21 PM
stanordave's Avatar
Joined Jan 2006
Here's a very jerky nite shot. If I can't get more of the wing lit, I'll add another to the tail to help w/orientation.
vapor led test (0 min 46 sec)
Old Jul 17, 2008, 02:12 AM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Cool!
SebastianJ is offline Find More Posts by SebastianJ
Old Jul 17, 2008, 02:38 AM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Originally Posted by msburko
Slightly off topic.
If I can get a spare brick from the local hobby store this weekend I'll be probing it for a sign of the missing channel. I will report back with my findings.
TheSteve is offline Find More Posts by TheSteve
Old Jul 17, 2008, 08:32 AM
eander315 is offline
Find More Posts by eander315
My other heli is a Vapor
eander315's Avatar
Houston, TX
Joined Dec 2007
Has anyone replaced the motor with a slightly more powerful one? Can the ESC handle the current draw or is it just a bad idea? I am very new to micro planes and planes in general, so excuse the very possibly stupid question
eander315 is offline Find More Posts by eander315
Old Jul 17, 2008, 08:45 AM
tdearth is offline
USA, IN, Nineveh
Joined Apr 2002
HI eander,
It is not a stupid question but I am not sure why you would want to.
The Vapor will hover with the motor it has and it looks like the set up is pretty near optimal for that airframe.
Tim
Discussion Official Parkzone Ember Review Thread! obiwan22 Micro Ready-to-Fly 1563 Aug 02, 2016 11:51 AM
Discussion Official parkzone vapor review thread! lightspeeddud Micro Ready-to-Fly 1399 Jul 02, 2015 01:00 PM
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Official Parkzone P-51 Owners Thread monitor Parkflyers 913 Oct 04, 2005 09:02 PM
