Old Jul 01, 2008, 05:06 PM
hockmasm is offline
Find More Posts by hockmasm
Flying since Dec '07
hockmasm's Avatar
Joined Nov 2007
charging time for Mystery 7.4V 900mAh 15C Lithium Polymer Rechargeable Battery
just bout 2 Mystery 7.4V 900mAh 15C Lithium Polymer Rechargeable Battery.
how long do i charge them for? with this charger:
http://www.act-labs.com/scripts/proddetails.asp?Pid=991
hockmasm is offline Find More Posts by hockmasm
Old Jul 01, 2008, 05:09 PM
R/C_Addict is offline
Find More Posts by R/C_Addict
That's me.
R/C_Addict's Avatar
San Francisco Area, CA
With a fully discharged battery, it will take a little over an hour. But because you never discharge a li-po completely, I'd say 45 min- 55min. It will tell you when its done.
R/C_Addict is offline Find More Posts by R/C_Addict
Blade_Killer is offline
Find More Posts by Blade_Killer
innocent victim
Blade_Killer's Avatar
Houston TX
Joined May 2007
that charger will tell you when it's done charging. Usually for the 900mah it's about an hour or maybe a little less.
Blade_Killer is offline Find More Posts by Blade_Killer
Old Jul 01, 2008, 05:14 PM
anatoly is online now
Find More Posts by anatoly
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
It looks like it has a red light that goes on when the charge is done, so the easy answer is "until the red light turns on".
If you want to figure it out, divide the pack capacity (900 mAh) by the charge current (0.8 A or 800 mA) so you get about 900/800 hour, or a little over an hour. But it probably has a trickle charge mode that kicks in at some point in the process, so will probably be longer. Larger packs will take longer because it has a constant charge rate, and you should not charge any packs smaller than 800 mAh on it for the same reason.
If you're going to stick with LiPo packs for any length of time, I would recommend a good balancing charger such as a CellPro 4s. The 4 amp version will charge packs upto about 4000 mAh to 90% in under an hour, and will take an extra 10 to 20 minutes to balance the packs as it heads toward 100%. Plus it's a very safe charger; if the pack can not be charged to 100% it stops.
anatoly is online now Find More Posts by anatoly
Old Jul 01, 2008, 05:50 PM
innocent victim
Houston TX
Joined May 2007
the only problem I have with the cellpro (and all the high end chargers might be this way) but you have to buy the charger $80 and then the lipo balance plug adapter to fit it, and then buy or find a power supply to run the cell pro.
Old Jul 01, 2008, 08:19 PM
hockmasm is offline
hockmasm's Avatar
Joined Nov 2007
with the chargger i mentioned. do i have to monitor it until it turns red? or if i leave it on the charger it will eventually burn the housse down?
Old Jul 01, 2008, 08:59 PM
Xrayted is offline
Find More Posts by Xrayted
Closed Account
Joined Dec 2007
The charger will slowly reduce the charge rate and then stop when the battery is done but you should NEVER leave the lipo unattended. If you cant be there or dont have time to monitor it, then dont try and charge it.
I would not trust any charger to just shut off and leave them on the charger (although this is what good chargers do)......I just wouldnt do it myself just in case.
Xrayted is offline Find More Posts by Xrayted
Old Jul 01, 2008, 09:04 PM
RC Addict
anatoly's Avatar
Falls Church, VA
Joined Jul 2006
Yeah, it's not the cheapest solution, it just works well.
Well, they say never to leave your charger unattended, although I'm so confident in my CellPro that I've left it unattended many times, even overnight, with zero problems. It just stops charging and that's it. I haven't used the Esky charger, so I can't really say anything about it.
Old Jul 01, 2008, 09:14 PM
Xrayted is offline
Closed Account
Joined Dec 2007
My DN charger shuts off just like it should, but If im in another room and hear the finish alarm go off, I will sit and think about it until it drives me crazy
Maybe its just the OCD, but I HAVE to get up and go unplug the batts when they are done. I live in a high rise condo so all I can think about are the 380 other people looking at me for burning their house down too
Sold New Mystery 7.4v 900mAh 15C LiPo $11 Shipped xwingnut Aircraft - Electric - Batteries & Chargers (FS/W) 0 Feb 01, 2008 01:51 PM
For Sale FS: 7.4V 9000mah 20C Lithium Polymer Lipo Pack paulsrc Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 20, 2008 11:02 PM
For Sale FS: 7.4V 9000mah 20C Lithium Polymer Lipo Pack paulsrc Boats (FS/W) 0 Jan 19, 2008 01:50 PM
For Sale FS: 7.4V 9000mah 20C Lithium Polymer Lipo Pack paulsrc Cars - Cars and Parts (FS/W) 0 Jan 19, 2008 01:49 PM
Wanted Fast Charger for 10C 7.4V 900mah lipo adslparts Aircraft - Electric - Batteries & Chargers (FS/W) 3 Dec 17, 2007 09:29 PM
