View Poll Results: Cast your vote to be able to use your tx on walkera heli's
I am all for it 44 86.27%
I dont care 7 13.73%
Voters: 51. You may not vote on this poll
Old Jun 30, 2008, 02:08 PM
nexgen is offline
Find More Posts by nexgen
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
Poll
**PETITION** Aftermarket tx with Walkera rx
I'm sure everyone who flys Walkera heli's have asked themselves this question at one time or another:
"Why cant I use my own tx with this heli?"
lets create a petition to Walkera to have them make some sort of adapter, or even a rx version without the dummy channels. I would pay for it. I bet LOTS of folks would pay for it.
I have created this petition style post for "signatures" for this type of product/feature to be added. Of course we would still be using their products, but just want to have the option of using our own tx to fly this brand.
There are enough Walkera vendors here that could pass the petition, and info to Walkera.
You'd think they'd want to play nicely with other brand tx's like many other heli manufacturers do.
Let's all chime in with our vote to have this feature. Hopefully if we get enough, we can make some headway with Walkera.
Also admins, do you think we could make this a sticky for a little while?
nexgen is offline Find More Posts by nexgen
Old Jun 30, 2008, 02:24 PM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Walkera likely has no interest in changing now, in a year or less it will be cheaper for them to sell all helicopters as 2.4ghz which reduces the odds of using a different tx to pretty much zero.
TheSteve is offline Find More Posts by TheSteve
Old Jun 30, 2008, 02:28 PM
nexgen is offline
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
2.4 Ghs folks will want to use their own futaba or jr or spectrum tx in this case as well. Maybe I'm missing something on 2.4 ghz, can any tx bind to a Walkera 2.4 ghz rx? If not then this poll would apply.
Besides, there will still be lots of folks ( myself included, for now) that cant or wont go to 2.4 ghz for some time, and they would benefit from this type of feature without having to go full seperates.
Think of the weight involved with a regular FM seperates setup compared to a spectrum 2.4 setup.
Old Jun 30, 2008, 03:31 PM
spinup is offline
Find More Posts by spinup
hover happy
spinup's Avatar
over under
Joined Aug 2007
Isn't this just a positive-shift vs negative-shift question? So either JR or Futaba will work, but not both? I dunno, never used a walkera radio, just wondering...
To answer your question: I'd assume that the RTF heli vendors (walkera, esky, horizon/eflite) all have back-scratching agreements with manufacturers in one camp or the other. Locking you into their "standard" is good for business.
2.4ghz is whole new level of lock-in, not as simple as the old positive/negative shift. The signal is encoded. It could even use encryption to ensure incompatibility.
-Jeff
spinup is offline Find More Posts by spinup
Old Jun 30, 2008, 03:42 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Walkera actually uses a slightly non-standard version of PPM. Positive or negative shift is an issue but on top of that they also require the transmitter have 11 channels of PPM. On a 4#3 or 5#6(4 channel) transmitter the first 4 channels are real, the other 7 are just dummy channels with narrow pulses. The receiver units won't arm unless they see all 11 channels with the correct pulse widths.
Old Jun 30, 2008, 03:56 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Those !
village_idiot is offline Find More Posts by village_idiot
Old Jun 30, 2008, 04:01 PM
nexgen is offline
Put a Quark in it!
nexgen's Avatar
USA, MN, Brainerd
Joined Feb 2008
So that's why I want to see if Walkera will at least budge a little and make an adapter or upgrade of sorts to the rx so it can play nicely with other tx's. Or maybe someone can program something to introduce those dummy channels, and put it up for sale.(TheSteve? ).
Old Jun 30, 2008, 04:42 PM
mahbouni is online now
Find More Posts by mahbouni
Heli Hooligan
London
Joined Dec 2006
I think it's a good idea but I would actually prefer Spektrum to make a DSM2 4-in-1 that could fit into any small heli like the 52.
mahbouni is online now Find More Posts by mahbouni
Old Jun 30, 2008, 05:08 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
Spektrum does make a DSM2 4in1, its just a little big for anything under 150 grams.
They are coming out with a 1S compatible unit for airplanes, I doubt there is demand for a helicopter version with a gyro though.
Walkera could just change the software in there 2.4ghz 4in1s and make it DSM2 compatible
Until then contacting Conny is our best shot. If I find some time I`ll consider it.
Old Jun 30, 2008, 05:45 PM
spinup is offline
hover happy
spinup's Avatar
over under
Joined Aug 2007
OMG, that's hilarious. So you can fly one of these cheap RTF helis if you have an expensive 12-channel radio with the correct shift?
-Jeff
Heli Hooligan
London
Joined Dec 2006
I knew about the 2-in-1 from the new BCP2 but I didn't know there is a 4-in-1. Do you have a link?
Old Jun 30, 2008, 06:01 PM
Hellraser is offline
Find More Posts by Hellraser
Hellraser's Avatar
UK
Joined Jul 2007
Walkera have always used there own specific radio setup - I cannot see them changing now - the nearest to a comprimise you are likely to get is once walkera have all there models inclusive of the 7 channels on 2.4Ghz then they will probably come out with a computerized 2.4 Ghz transmitter so you can use 1 transmitter for all your walkera models.
Regards David
Hellraser is offline Find More Posts by Hellraser
Old Jun 30, 2008, 06:20 PM
TheSteve is offline
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
-Jeff
You bet!
Old Jun 30, 2008, 06:24 PM
Heli Hooligan
London
Joined Dec 2006
Normally companies that use their own proprietary standards are ones that have some sort of edge over the competion, e.g. Sony or Apple. Walkera are amongst the worse manufacturer of Tx I can think of. Actually I can't think of anyone worse. Most people who hate Walkera hate them for the crap quality of their electronics. They would sell much more helicopters if they did a deal with a known brand of Tx. Even Hitec would be an option.
As for the other brands like Futaba, Spektrum, and JR, I can't understand why they haven't jumped all over this opportunity to supply these sort of products. There's much more money to be made in micro helicopters than big ones. They may cost only $99 ready to fly but the volume of sales is much higher and the typical customer is a new pilot who's gonna crash every day. Within 6 months he'll have bought enough spare parts to build the POS 5 times over.
Old Jun 30, 2008, 06:35 PM
philosophicle_1 is offline
Find More Posts by philosophicle_1
Slowly Approaching 1,000
Detroit (area), MI
Joined Mar 2004
Looks like this turned into more of a discussion than a petition, good luck Nextgen.
BTW, I did vote (all for it) and think it should be capable. I would be much more likely to buy one then. As the programmers would say, "Open source baby!" As for the 2.4 stuff, currently Spectrum will only bind with Spectrum, Fut with Fut, etc. if I'm not mistaken. So it's no different than +/- really.
philosophicle_1 is offline Find More Posts by philosophicle_1
Sold Walkera WK703 computer TX with 2 RX's heli-parkflyer Aircraft - General - Radio Equipment (FS/W) 2 Apr 29, 2008 03:04 PM
WTB: 2 Sub-micro servos, 3 or 4 channel TX with small RX and a small battery.. Nik-rc Aircraft - Electric - Airplanes (FS/W) 0 Oct 23, 2003 09:08 AM
HiTec Focus III TX with Feather RX, Ch. 40 ben1000 Aircraft - Electric - Airplanes (FS/W) 2 Mar 09, 2003 06:52 PM
Synthesized Module TX with Berg RX Richard Ingram Electric Heli Talk 4 Sep 10, 2002 06:49 PM
FS: 3ch Tx with 4ch Rx and 2 servos from a megatech merlin- cheap! Etonic Aircraft - Electric - Airplanes (FS/W) 9 Sep 05, 2002 06:16 PM
